Fokker Dr. I 'Skeletal'
kkarlsen
The fuselage frame has these 'eyelets' welded to some of the corners for the rigging attachments...
So I had to come up with a way to produce some 'rings'
Ii reminded be of when making buckles and handles from lead wire. Some stretched sprue is coiled around a fitting shaped  tool
and this is placed over the flame of a candle to reheat the stretched sprue to make it keep the shape...
This way I'm able to produce as many 'eyelets' as I need.
The fuselage frame is slowly beginning to come together...
Cheers: Kent
23 hours ago, Madmax said:
Oh my word!
This is like watching childhood dreams turn into reality. Scratch-building from another planet, and very inspiring. Keep going Kent...
Thank you Sean, appreciate it. It's also one of my 'childhood dreams' - Now it's finally time to go for it...
And I will, continue to the 'bitter end' :-)
Cheers: Kent
Edited by kkarlsen
First little test of fitting the resin spars...
The axle fairing has been strengthened with a piece of brass rod.
The cast resin spars fits nicely on the axle-
The outer spars are held in place by some stretched sprue. This technique seems to work very well, which is a great encouragement
for the upcoming wing assembly's...
For the Wheels I have been casting some tyres + wheel rims and I will be using the Part photo etched wire wheels and spokes.
First attempt at the tail plane, it's not as complicated as it looks...
I may have to change some of the 'stringers' with resin ones, they are not 'behaving' as I would like them to.
Cheers: Kent
22 hours ago, Wouter said:
Now this is something you don't see every day! Fantastic work Kent, you're a brave man.
Thanks Wouter, hopefully I will not break my neck or something on this! ;-)
Cheers: Kent
Edited by kkarlsen
Couldn't resist, I just had to try the fitting of the tail plane...
Looking very 'Fokkerish'. Now I'm headed for the Wing assembly's...
This book about the Fokker Dr. I  is just great!
Plans and details of the constructions.
I'm trying to get as close to real thing as possible.
A little example of the work involved for the wing tips.
Ready to make copy's of the wingtips.
The assembly of the top wing begins.
More wing spars in place. No real challenges yet. It's just hours of fiddly work ;-)
Cheers: Kent
Edited by kkarlsen
