Out2gtcha 35,244 Posted November 25, 2018 Share Posted November 25, 2018 .....I need your help...... Im about to start the nacelles on my F7F and found a problem with my port nacelle , and was hoping someone with the kit could see if theres is the same way. On my copy, the starboard nacelle is perfectly fine: The port nacelle on in my kit however has a nasty surprise in the back end. It appears to be a resin copy of a temporary plug that should have been removed before casting: If anyone who has this kit could check their kit and see if theirs has the same issue as mine does it would be greatly appreciated. Cheers, Link to post Share on other sites
Rick Griewski 3,589 Posted November 25, 2018 Share Posted November 25, 2018 Ouch... Could be Dremel time. It will be easier if both need the plug. Good luck Sir. Rick Out2gtcha 1 Link to post Share on other sites
Out2gtcha 35,244 Posted November 25, 2018 Author Share Posted November 25, 2018 Thanks Rick. I'm hoping its just my kit and I can order a replacement port nacelle......... But in my experience so far, these issues are across the run of the kit. I sincerely hope I'm wrong, I'd love to be able to just order a new nacelle. Harold 1 Link to post Share on other sites
Tnarg 1,603 Posted November 25, 2018 Share Posted November 25, 2018 I think you can ask them to fix this. I see all the way to the end on both of mine. Tnarg Gazzas and Out2gtcha 2 Link to post Share on other sites
Out2gtcha 35,244 Posted November 25, 2018 Author Share Posted November 25, 2018 18 minutes ago, Tnarg said: I think you can ask them to fix this. I see all the way to the end on both of mine. Tnarg Thanks, that is what I was hoping for! I'll see about asking them for a replacement port nacelle. Link to post Share on other sites
LSP_Ray 8,291 Posted November 25, 2018 Share Posted November 25, 2018 Brian, my kit does not have the plug, both nacelles are open. I can't tell the two apart - are they handed? Out2gtcha 1 Link to post Share on other sites
kalashnikov-47 666 Posted November 25, 2018 Share Posted November 25, 2018 (edited) Brian, mine is the same as yours. Edited November 25, 2018 by kalashnikov-47 Out2gtcha 1 Link to post Share on other sites
Harold 3,564 Posted November 25, 2018 Share Posted November 25, 2018 (edited) It may be that the rubber tore at some point as they were casting. Any castings after that tear will be like yours. Edited November 25, 2018 by Harold Out2gtcha 1 Link to post Share on other sites
Out2gtcha 35,244 Posted November 25, 2018 Author Share Posted November 25, 2018 12 hours ago, LSP_Ray said: Brian, my kit does not have the plug, both nacelles are open. I can't tell the two apart - are they handed? Thanks Ray....yes, the port and starboard nacelles each have opposite facing upper rear areas that but up to the trailing edge of the wing. 11 hours ago, kalashnikov-47 said: Brian, mine is the same as yours. Bummer! Im thinking something along what Harild mentioned that something happened in the mold process, and it appears some kits have it and sime dont. I'll definitely drop HpH a line and see if I can get a replacement nacelle with no plug. Harold, kalashnikov-47, LSP_K2 and 1 other 4 Link to post Share on other sites
MikeMaben 7,583 Posted November 26, 2018 Share Posted November 26, 2018 Out2gtcha 1 Link to post Share on other sites
thierry laurent 6,626 Posted November 26, 2018 Share Posted November 26, 2018 Damn it! I have the same plug in BOTH nacelles of my kit! LSP_K2 and Out2gtcha 1 1 Link to post Share on other sites
Markjames1968 201 Posted November 26, 2018 Share Posted November 26, 2018 the plug is probably from a mould that gets damaged as production runs increase in number, early kits will be fine, mid batch kits will have 1 plug, late batch will have 2, its where there a piece of mould missing from being damaged when extracting it from the part.. nothing they can do UNLESS they have made a new mould from their masters Out2gtcha 1 Link to post Share on other sites
Out2gtcha 35,244 Posted November 26, 2018 Author Share Posted November 26, 2018 15 minutes ago, thierry laurent said: Damn it! I have the same plug in BOTH nacelles of my kit! Damn Theirry..............that stinks! There is a triangular resin plate piece that goes into that area that simulates the upper surface of the wheel well, and Im not sure it will fit in the upper part of the nacelle with those plugs in. 11 minutes ago, Markjames1968 said: the plug is probably from a mould that gets damaged as production runs increase in number, early kits will be fine, mid batch kits will have 1 plug, late batch will have 2, its where there a piece of mould missing from being damaged when extracting it from the part.. nothing they can do UNLESS they have made a new mould from their masters Well that would be a disappointment (once again) if true and they come back (once again) and tell me the messed up part I have is not possible to replace. I love LOVE the Tigercat. I hate to say it, but it really seems like its one thing after another with this kit. Link to post Share on other sites
PhilB 1,599 Posted November 26, 2018 Share Posted November 26, 2018 (edited) I think you need to think about what can be seen in there on the 1/1 thing. Firstly, it needs to come out as the extra weight might affect it's need for extra noseweight. I don't know the aircraft but I would assume there is a bulkhead or two down there for structural strength? If you dremel out the plug, will this extra piece you mention cover it up or how about using the opening as a guide for a bulkhead then reducing it's overall size to slide down in there to cover up yer drillin? Edited November 26, 2018 by PhilB Out2gtcha 1 Link to post Share on other sites
Out2gtcha 35,244 Posted November 26, 2018 Author Share Posted November 26, 2018 1 minute ago, PhilB said: I think you need to think about what can be seen in there on the 1/1 thing. Firstly, it needs to come out as the extra weight might affect it's need for extra noseweight. I don't know the aircraft but I would assume there is a bulkhead or two down there for structural strength? If you dremel out the plug, will this extra piece you mention cover it up or how about using the opening as a guide for a bulkhead then reducing it's overall size to slide down in there to cover up yer drillin? Actually there is a surprising amount you can see if you stick your head in the well of the real deal. In this one, there is a plate blocking the full view, but you can actually see down there. Never thought of the weight aspect of it really. I dont think it weights a lot, but the perforated section you see above, is the resin plate HpH have you slide along the top of the well and gets incorporated to make the roof of the well. I dont think it will fully slide all the way back where it needs to go with that plug still in place. Link to post Share on other sites
