acresearcher
Hobby Boss 1/32 B-24J - Initial Observations
5 minutes ago, SimonCornes said:
Just seen a very good thread on LSP about a chap who restores turrets. Well worth watching!
This B-24 is a kit that screams 'Start me' because its all there but then I cant because I want metal inserts for the gear, resin wheels, better guns and maybe a Zoom instrument panel. Still not sure if I can live with the engines but, to be honest, you could just build it and have a very big B-24! If you do it properly you could even build it with the kit turrets and make it possible to lift them out and replace with the aftermarket versions - which will hopefully arrive! So mine will sit in its box until I can get the extras I want. But hopefully someone will start a build thread?
Ahem
1 minute ago, Madelf75 said:
I just wonder if anyone has came up with a fix for the wings ,I dont feel that is a big deal but i am sure it is something that can be done .
Hey Steve, yes indeed there is! See Andy's link below for Iain's WIP thread were is is indeed attempting a fix for the wings.
6 hours ago, Kagemusha said:
Ahem
Just now, Iain (32SIG) said:
Yes - next question?  :)
Iain
OK, so can we talk about the other big error now?
Does that look even slightly like this to you?
b24-1-jpg.463387
b24-consolidated-liberator-ww2-bomber-pl
Notice how the cowl profile is wrong - too rounded on the sides vs the almost flat sided profile of the real thing?  Never mind how the side air inlets are the wrong shape and lack interior finishing?
I know,  I just can't lave bad enough alone
Joe
OK, I started to read the thread from Page 1, paragraph 1. Spent like 10 minutes and got a headache.
It is obviously very complex project, due to discrepancies, embedded errors, complexity of the subject etc.
I have simple question, if anybody or even many-bodies can reply, I would be more than grateful:
Can HB B-24J kit be turned into e decent J variant and is it suitable for modifications to be built into H and L variants?
Thank you in advance and Happy New Year!
Joe
Yes - aware of cowl fronts - and have a fix planned.
Do you have the kit Joe? There are inserts for those intakes that improve the look - but far from perfect.
Iain
Iain
A flat bit on the top and bottom between the sides? It looks like they've maintained the radius on the plastic part but the plane has a decreasing one? Nightmares of decreasing radius corners riding sportbikes.
I wonder how much it's actually off when viewed square to the end of the prop shaft.
Matty
It's a complex shape Matty - my thoughts are to cut away the inner sides of those intakes and install a new, complete, ring inside the cowl to form a curved liner that will form the inner faces of the intakes.
This will then need to be re-profiled as the front edges of these intakes curve in a little when viewed from the side.
Slice of brass for the splitter...
The liner will either be based on a suitable spare cowling 'rim' (if I have one of a suitable size), or I'll turn up a pattern on the lathe and vac one.
This will then be put in rubber and copies made.
But all fixable IMHO.
Will cover off in my Liberator GR Mk.VI build - after wings and turrets.
Privateer ones are different again, in addition to being rotated 90 deg...  :)
Iain
Yes, I believe so - with work.
How much depends on how much you want to do re. fixing some of the shapes, and which particular airframe you wish to build?
Depending on airframe you may need new turrets/gun positions/nose glazings.
Iain
Iain
Actually I am researching for potential masks sets for various stabilizer art works which will be ugly view if done with decals.
I think H,J and L have the greatest potential.
Some Skulls will look awesome. From what I know, H and L differ slightly from J. For the untrained eye they don't.
And I am guessing a lot of folks out there will consider doing HB J-variant into some of these to take the path less known.
However, I am no expert /nor big fan/ of Liberator planes and I could use some knowledge in that matter.
We are starting work on some J masks next week.
But maybe I can widen the perspective on the subject.
My assumption is that there will be tons of wrong details, starting from rivets and panel lines, up until major flaws.
But it is Hobby Boss after all, not Tamiya or ZM.
And it is /at least I got it for/ 1/3rd of the Lancaster's price.
Anything better in 32nd scale on the subject? So either bite the bullet or...
