pg265
Ferrari 312F1, Chris Amon, Monaco 1967. 1/12, MFH.
Me again.
Engine progress.
I was not that happy with the kit throttle linkage... So I decided to build new ones with machined parts from RBMotion.
It was also necessary to show a bit of interest regarding the exhaust and prepare the white metal parts of the Spaghetti:
To prime and paint them:
Other parts are just treated to be left with a natural metal finish:
I prefer soldering them instead of gluing for évident reasons:
I played a bit with the iron in order to replicate weld seams :
The engine connected to the gear box and vice versa, and install for test fit in its compartment:
Next to the small 1/20 sister :
Rear brake discs before assembly on the gear box:
... and few accessories:
Modification of the rear hubs in order to adapt machined parts:
Time for primer:
The body is drilled in order to be riveted with MFH aluminium rivet:
The engine is... big. Almost the size of the 1/20 kit:
More soon.
I hope you enjoy this WIP.
Pascal
Edited by pg265
Sorry... but me Agaaaain!
 Rosso Corsa GC and  Semi Gloss Black ZP on the rear shocks and the steering wheel.
Dull Aluminium (Alclad) on the rear hubs
Test fit of the front end:
Thermic screen adjusted and drilled for the roll cage:
 (Titanium White GC):
 Not very happy with the Dull Alu, so black Alclad is sprayed:
Tubes installed in the radiator and started to work on the rear suspension components:
Front brakes scoops are painted white:
test fitting of the bathtub:
Weld seams on the 3in1 exhaust parts:
Pascal
Beautiful detail work! Going to be a stunner! :thumbsup:
MFH make some neat kits, I have the Daytona Cobra that I hope to work on one day...:shrug:
Dan
Hi,
Thanks a lot to all of you for the kind comments Mates.
Alclad White Alu and Klear Kote.
Wheels prep & paint session:
Primer
fe4bfa10.jpg Alclad Black:
Pale Gold Alclad:
Liquid mask and tape removed:
Time for oils:
Test fit of anti roll bar, gearbox and half side transmission.
Pascal
Me again...
I’ve modified the throttle linkage.
The White Metal original ones were not that good, so I replaced them with machined parts.
The mesh over the stacks is now done, and I must admit it was pretty fun to form and install: I’m mot unhappy with the result.
Oils have also been applied on the heat shield as well as a portion of aluminium tape on both external sides.
I really like the view of the trumpets through the mesh.
The rear stab bar has been remade with 1mm ø brass, which was later chemically burnished.
Now working on the connection rods.
One started compared to raw white metal original part.
Voilà, voilà.
More soon!
Pascal
