Pastor John Posted November 4, 2018 Posted November 4, 2018 (edited) Hi everyone, well as many of you know I started a model in the summer with every intention of just enjoying modelling for myself but what always happens happened - I started thinking of products! It is the nature of the beast I guess but I really do want to crack on with the Revell bf 109 G-10 Erla and I have three new products at hand to help me along with the fantastic Barracuda items.I really need to set aside days that are for me, not AIMS otherwise I will never get anything built other than un-painted display models. I enjoyed painting the Aires cockpit - the fit caused problems and I still have large gaps in the canopy sill to work on but I was able to get the fuselage closed up fairly quickly. I wish I had not as when I decided I wanted a 'hatches and latches' set I now have lots of holes in the fuselage with no pre-installed interior detail so I will have to do the best I can. The upper cowl, whilst not perfectly addressing the width of the engine cowl does however trick the eye into thinking the cowl is much wider than it was, it isn't but the flatness of the resin part really helps together with the gun openings being further apart. Sadly after production was well underway I was informed that on Erla machines the gun opening is not straight cut at the back like on the U4 so I have rounded off mine a little and also made the cut outs for the weapons. Next up is post filling some of the interior areas and then onto laying in the PE hatch rims, all good fun! Edited November 4, 2018 by Pastor John Martinnfb, Kagemusha, chukw and 12 others 15
John1 Posted November 4, 2018 Posted November 4, 2018 That's an awesome looking cockpit. Which specific aircraft will you be building?
Pastor John Posted November 4, 2018 Author Posted November 4, 2018 Hi John, I like the controversial Yellow 9, I like my Blue 2 of JG 3 better but it has the small wheel bulges and I have already done the wheel bay work I wanted to do and I not have the conversion for that anyway Out2gtcha and Rick Griewski 2
Pastor John Posted November 6, 2018 Author Posted November 6, 2018 Hi everyone, I can't believe it! I have managed to get a few more hours modelling done! What is happening? Dany Boy, LSP_Kevin, MikeC and 3 others 6
Pastor John Posted November 6, 2018 Author Posted November 6, 2018 and the other side... Martinnfb, MikeC, XOPCT and 5 others 8
dodgem37 Posted November 6, 2018 Posted November 6, 2018 Nice clean work, John. The etch will be a nice addition. Sincerely, Mark Pastor John 1
Shawn M Posted November 6, 2018 Posted November 6, 2018 very nice John, I like all the open hatches and internal detail
Pastor John Posted November 6, 2018 Author Posted November 6, 2018 I needed to do something Shawn to break up the boring Monotone RLM 81 'green' fuselage on Yellow 9, hope it works Shawn M 1
Kais Posted November 7, 2018 Posted November 7, 2018 Pastor John, Great work. Check your references though, if you use the upper filler hole for the forward oil tank on the nose, I think the lower should be absent. Your MG131s look a little undernourised as well. Keep at it, the result will be memorable.
Pastor John Posted November 7, 2018 Author Posted November 7, 2018 (edited) Hi Kais, thanks - I not have any specific info on the Erla machines - I not know if the filler hatch was filled over or not so had to leave it at Revell have done it - as a simple plate rather than a hatch, same for another fuel hatch below the upper one on the right side of the spine????? MG are from Quickboost Edited November 7, 2018 by Pastor John
Pastor John Posted November 7, 2018 Author Posted November 7, 2018 Hi Klais - you were right about the Quickboost MG 131s, next to the Master product they are a little underfed poor souls! Difficult for me to change them now as I made the complete cut out in the bottom of the gun troughs the length of the weapons barrel so I can neither snap out the resin weapons cleanly or balance new heavy material replacements. Please do not look at this area again lol
