Sign in to follow this
Archer Fine Transfers
FINALLY, Archer rivet sets for aircraft
Greetings from the edge of nowhere. :rolleyes:
We've been in business for 29 years and selling our resin rivets and other Surface Details to armor and railroad modelers since 2007. We know that a lot of aircraft modelers have purchased them for use on their model aircraft. Well, you can stop doing that now because we now offer them specifically for you in oversized sheets in appropriate sizes and spacing for y'all.
FREE PDF MANUAL
We spent a months experimenting with our resin rivets to address the issues specific to model aircraft and developed two no-sanding methods for filling in the recessed rivets found on some models, and it's a lot easier than you my think. Six pages of detailed instructions and tips.
Specifically for 1/32 aircraft:
Spiral and circular pattern rivets AR88142
$21.95
Sheet of aircraft rivets .014" (.34 mm) in diameter in three different spacings to match the spacings on AR88143 and AR88144Includes a transparent guide to match sheet layout to aid in selecting the appropriate diameter for your model.
Single row rivets AR88143
$21.95
Sheet of aircraft rivets .014" (.34 mm) in diameter. There are 132 linear inches (335 cm) of the tightest spacing, 49 linear inches (125 cm) of the internediate spacing and 53 linear inches (135 cm) of the widest spacing to match the spacings on AR88142 and AR88144.
Double Row rivets AR88144
$21.95
Sheet of aircraft rivets .014" (.34 mm) in diameter. There are 40 linear inches (100 cm) of each of the three different spacings to match the spacings on AR88142 and AR88143.  Can also be cut into individual rows if you need more single row rivets to match the spacing and diameter of the rivets on AR88142
Buy all three sheets (AR88142, 143 and 144) and save over 25%
$48.95 (Regular price if purchased separately, $65.85)
For 1/48 and 1/32 aircraft:
If you're building in 1/32 these smaller diameter rivets are perfect for super detailing cockpits, wheel wells, canopy frames, etc., or to add contrasting texture to the airframe by mixing them with the 1/32 scale rivets. Aircraft are not riveted with the same size and pitch rivets so you may consider these as a compliment to the 1/32 scale rivets.
Spiral and circular pattern rivets. AR88139
$21.95
Sheet of aircraft rivets .009" (.23 mm) in diameter in three different spacings to match the spacings on AR88140 and AR88141Includes a transparent guide to match sheet layout to aid in selecting the appropriate diameter for your model.
Single row rivets. AR88140
$21.95
Sheet of aircraft rivets .009" (.23 mm) in diameter. There are 132 linear inches (335 cm) of the tightest spacing, 49 linear inches (125 cm) of the internediate spacing and 53 linear inches (135 cm) of the widest spacing to match the spacings on AR88139 and AR88141.
Double row rivets. AR88141
$21.95
Sheet of aircraft rivets .009" (.23 mm) in diameter. There are 40 linear inches (100 cm) of each of the three different spacings to match the spacings on AR88139 and AR88140. Can also be cut into individual rows if you need more single row rivets to match the spacing and diameter of the rivets on AR88140
Buy all three sheets (AR88139, 140 and 141) and save over 25%
$48.95 (Regular price if purchased separately $65.85)
Thank you,
Woody Vondracek, owner
Archer fine Transfers
