SapperSix Posted October 17, 2018 Share Posted October 17, 2018 (edited) The Monogram PBJ(B-25H conversion) and the Accurate Miniatures TBM-1C where built in parallel as best as possible. They were both test beds as I get ready for my 1/32 Tamiya Corsair, version TBD. Testing included: 1.) Density of floor wax and Tamiya X-20A thinner mix. Currently 60% Floor wax, 40% thinner spray as needed. In the past I had been just coating the heck out the subject making a really glossy subject. I read and learned that such actions can kill many subtle details and is not required for a good decal set. However, I love the way a diluted form strengthens the base coat and makes decals, sludge wash and oils work on the base coat. Matching the coat with the sludge wash is a matter of touch. Meaning that the more wax you put on the more of your sludge will not stick and will come off easier. The less wax and the sludge wash will sink right in to the paint and you will not be able to remove it from the flat paint. The PBJ is less wax, the TBM (I would like to think) was almost right. I am not sure how to scientifically quantify the math in the was vs the sludge wash other than to say experiment. 2.) Sludge was vs Oils. I haven't been able to get oils in Alaska, outside of internet. However, Michael's just opened and I was able to get true oils and water based oils. This has lead to a ton of messing around both on these aircraft and on a M4A1 76MM am also building. 3.) I had been fighting my airbrush and have finally found the key for my set up. So I did the PBJ with lose fitted paper to get the over spray control and I did the TBM with masking tape. I will need these skills for a SEA Phantom II build that's about to kick off. I prefer to free hand as I believe that this scale is large enough to be able to see the border collision of colors as they are more or less in real life, not a hard boarder in most cases that I have seen. 4.) Panel scribing was supposed to happen for the PBJ as it had raised panel lines coming from a old beaten B-25H kit. The panel lines on the TBM that had been sanded out also need to be rescribed. I did buy a scriber and try to make one but too late in the game and will have to come back to that idea in a future build. 5.) Building my own canopy mask with Tamiya tape. I was able to that with the PBJ pretty well but it was painstaking. At times I had a hard time seeing the birdcage and had to vary lighting to be sure what was the boarder. The TBM was bought with a Eduard Big Ed kit so that made life grand. 6.) Photography. I know that I need to build a photography stage if you will. I find that my phone camera betrays me and aids me. I see all my mistakes with a photo, so I think I will take pictures in the future to knock out what my failing eyes are missing and only after call it done and re shoot pictures. It doesn't capture the fine details and seems to over emphasize the harsh details. Missing much subtly my eye sees, maybe I am bias. 7.) Decals. I am going to move to painting my own as much is possible and reasonable. There is too many things that are at issue (See right side fuselage star and bar on the TBM and under the underside of the PBJ.). I have never painted my own at any scale and will need to look at this over the next couple of projects. 8.) The PBJ is a nose sitter thanks to a lot of lead weight secured with testors body putty, no CA. The PBJ was converted from a Monogram B-25H model I got about 10 years ago. It had been abused and parts lost as I used it as my test spray plane. I found some parts for it along with a Corsair -5 Radar and stuck that on the wing. Not to speck but it was a good lesson in moving a fair amount of plastic and building it up to look natural. One can see on the bomb bay door my lack of floor wax and how the sludge was sunk in more than I would have liked. I chose not to fix that as I will right if off on a dirty ground crew...... I tried to recreate fuel spill clean up, using oils paints, around the fuel cells. Its faint and the base matches well with it when seen with the eye. The top and side Stars and Bars were taken from another kit. The decal under the wing was from the original kit and is very yellowed despite trying to use microsol to fix it. Also many of the machine guns are cut up paper clips as the originals were long lost. The props are just pressed on, this one started to come off while moving for pictures, so be it. The door gunner windows have gone missing so I set up the waist gunners with a gun post. The lack of panels looks odd to me but made for good ground to test color variation with the sludge wash. The top of the cockpit bird cage was a little rough as was the turret gunner. Many lessons learned with custom made masking. I used thread for the antennas I am going to look in to wire in the future. One can see the lack of floor polish under coat didn't match with my sludge wash make up, more dish soap for the sludge maybe, or more floor wax prior to sludge washing .... I used sand paper and the boiling water method in an attempt to make my own weighted wheels. I was overly cautious in my first attempt but see how it can work and maybe save a few bucks down the road. The TBM was a joy to build with the eduard big ed kit. I did stop building for awhile and came back after a few months. This created a few problems in continuity. I tried the paint brush method to recreate chipping instead of the hairspray method. I can see it has many advantages. More practice is needed. The eduard interior for this model was very good. I cant seem to get my camera in there to do it justice. Worth the buy for this kit. I need to learn/practice how to weather munitions. The wheels are after market, don't remember from whom. Recribing the panels at the joint is a must, a bit of practice is on the way. The brush chipping method was a bit of a struggle to get right. Too much, too little....I found myself looking at a lot of reference photos. I left the door open as there is a lot of really good detail in there. You can see that the stars and bars decal wrinkled a bit and captured air unlike any of the others. I fought it and made it a little better but never got it it right. I am not sure what I did or what happened but it has motivated me to try and paint them in the future. The Plane number was put on before the sludge was but I couldn't get the sludge to match the remainder of the fuselage. Another reason to start painting. Regardless of the checklist of improvement they were a very fun build. And they helped me get a little better. It has made me much more confident for the future Corsair project. I cant wait to crack that Tamiya F4U box, but also want my skills to be on par with that great kit. Any advice and improvements very much welcome. Lord knows I have learned a ton while on this site. Edited October 17, 2018 by SapperSix LSP_K2, Gazzas, Big Texan and 1 other 4 Link to comment Share on other sites More sharing options...
Gazzas Posted October 17, 2018 Share Posted October 17, 2018 (edited) Two nice looking builds, Sapper. I don't know much about USN aircraft or colors, and I find the Mitchell conversion very interesting. Some 2lb test monofilament works fine for for aerials. And doesn't have any nasty vices (Stretched sprue is very fragile and elastic lines have a flat cross section). Another method for chipping is to use a small piece of small-pored sponge. Dip the sponge in paint, then blot on a piece of dry cardboard until you're leaving no paint. Then you gently dab it where you want some chipping. A question: Did you seal the decals with a clear coat before the sludge wash? Being able to paint markings is all good until there is something small and intricate where you want to use the decal. Gaz Edited October 17, 2018 by Gazzas typo Link to comment Share on other sites More sharing options...
SapperSix Posted October 18, 2018 Author Share Posted October 18, 2018 (edited) 16 hours ago, Gazzas said: Two nice looking builds, Sapper. I don't know much about USN aircraft or colors, and I find the Mitchell conversion very interesting. Thank you Gaz. As I think about it I cant say its a true conversion outside of the color and the addition of the radom (which isn't even in the right place but was a great test.). I certainly didn't do any real research as to the differences from the B-25H to the PBJ. But I like the color and had built many B-25s in the same old olive drab throughout my life. So it was time for a change and it worked well in to my practice. Quote Some 2lb test monofilament works fine for for aerials. And doesn't have any nasty vices (Stretched sprue is very fragile and elastic lines have a flat cross section). Perfect!! Thank you, I will give this a go. Quote Another method for chipping is to use a small piece of small-pored sponge. Dip the sponge in paint, then blot on a piece of dry cardboard until you're leaving no paint. Then you gently dab it where you want some chipping. I have been watching tons of modeling videos on YouTube. I saw this method performed on a tank the other day. I have stolen a few of my wife's sponges in preparation of trying this out. This should be interesting in more ways than one.....I will be testing this out on a M4A1 Sherman I am in the middle of trying out oil dots and pastel weathering on. Thank you for the insight. Quote A question: Did you seal the decals with a clear coat before the sludge wash? Being able to paint markings is all good until there is something small and intricate where you want to use the decal. Ummmmmmmmmmm........Nope. Note to self.... Quote Gaz Thank you for the help Gaz. Edited October 18, 2018 by SapperSix Gazzas 1 Link to comment Share on other sites More sharing options...
