LSP_K2 Posted September 18, 2018 Share Posted September 18, 2018 I've heard that Gunze Mr. Color leveling thinner works great with Gunze and Tamiya, but is the plain Mr. Color thinner as good? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 18, 2018 Share Posted September 18, 2018 I only use the plain stuff, not for any other reason than the levelling variety seems so much harder to get here (it's always sold out). It works fine for me. Kev LSP_K2 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted September 19, 2018 Share Posted September 19, 2018 I bought 400ml of standard thinner by mistake and it dries a bit too quickly for my taste. So, I added a bunch of Mr. Retarder and all is good. Try saying Mr. Retarder outside the modeling community and stand by for adverse reactions! ivanmoe, LSP_K2, Woody V and 5 others 3 5 Link to comment Share on other sites More sharing options...
Greg W Posted September 19, 2018 Share Posted September 19, 2018 Here in the States, you can get Mr. Leveling Thinner through Sprue Brothers. scvrobeson and LSP_K2 2 Link to comment Share on other sites More sharing options...
Gazzas Posted September 19, 2018 Share Posted September 19, 2018 2 hours ago, LSP_Kevin said: I only use the plain stuff, not for any other reason than the levelling variety seems so much harder to get here (it's always sold out). It works fine for me. Kev I ordered some from BNA Sunday. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
CANicoll Posted September 19, 2018 Share Posted September 19, 2018 What paints do you use it with? Does it work with the Vallejo Model Air acrylics? Just curious! Chris Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 19, 2018 Share Posted September 19, 2018 8 minutes ago, CANicoll said: Does it work with the Vallejo Model Air acrylics? That's a big fat NO in my experience! Kev CANicoll 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted September 19, 2018 Share Posted September 19, 2018 I would agree with Kev. Using one manufacturer's lacquer paint with another's acrylic is asking for it. Tamiya lacquer thinner works with their own acrylics, but I believe it was designed to do so. CANicoll 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 19, 2018 Author Share Posted September 19, 2018 2 hours ago, GDW said: Here in the States, you can get Mr. Leveling Thinner through Sprue Brothers. Yes, and I'll be ordering a bottle, but probably not until next month. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 19, 2018 Share Posted September 19, 2018 In my experience, the Gunze lacquer thinners work well with lacquer- and alcohol-based acrylic paints (Tamiya, Gunze aqueous, MRP, SMS, etc) , and I've even used it successfully with enamels. It doesn't, however, work well with latex-based acrylics such as those that generally tend to come in the little eye-dropper bottles. Kev CANicoll, ivanmoe and LSP_K2 3 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 19, 2018 Author Share Posted September 19, 2018 9 minutes ago, LSP_Ray said: I would agree with Kev. Using one manufacturer's lacquer paint with another's acrylic is asking for it. Tamiya lacquer thinner works with their own acrylics, but I believe it was designed to do so. I've heard that the leveling thinner also works great for Tamiya, but it may have been the Tamiya lacquers (which I love), that was being referred to. I really have no idea. ivanmoe 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 19, 2018 Author Share Posted September 19, 2018 Thanks for the inputs, fellas, I appreciate it. I'm beginning to suspect that a G-14 I'm working on, is going to be a blend of Tamiya and Gunze acrylics, Model Master enamels and Gunze and Tamiya lacquers. Since to me, the exterior finish on this model is critical, I'll be using every trick that I know. Link to comment Share on other sites More sharing options...
modelingbob Posted September 19, 2018 Share Posted September 19, 2018 (edited) To answer your direct question, Mr Color Levelling Thinner is nothing more than Mr Color Thinner with an added retarder. The formulaes are virtually identical (except for the added retarder!). The added retarder helps prevent tip dry on your airbrush, helps prevents "stringing" (the paints solvent evaporating inside your airbrush causing the paint to thicken) , and also slows the drying rate down on the painted surface so it will self level better. You can buy Mr Color Retarder as a stand alone product and add it to both versions to slow down the drying time of the paint. I will even add Mr Retarder to Mr Color Levelling Thinner to make a higher glossy shine when I require it. As previously mentioned, Gunze and Tamiya alcohol based acrylics can be thinned with either version of the thinner (in addition to the other alcohol based acrylics). In addition, it is my preferred thinner for Testors enamel paints (including Model Master), working better than mineral spirits and even Testors own thinner. IMNSHO, Mr Color Leveling Thinner performs better than the "regular version" and is my preferred choice for thinner since it helps solve the above issues. Edited September 19, 2018 by modelingbob ivanmoe, D.B. Andrus, LSP_K2 and 2 others 5 Link to comment Share on other sites More sharing options...
ringleheim Posted September 20, 2018 Share Posted September 20, 2018 On 9/18/2018 at 8:23 PM, GDW said: Here in the States, you can get Mr. Leveling Thinner through Sprue Brothers. It's way cheaper from Scale Hobbyist. The big 400 ML bottle is $18.99 at SB, but only $12.29 at Scale Hobbyist. I swear by Mr. Color Leveling Thinner and always have 2 of 3 of the big bottles on hand; use it constantly. Greg W and LSP_K2 1 1 Link to comment Share on other sites More sharing options...
ringleheim Posted September 20, 2018 Share Posted September 20, 2018 23 hours ago, LSP_Typhoonattack said: I've heard that the leveling thinner also works great for Tamiya, but it may have been the Tamiya lacquers (which I love), that was being referred to. I really have no idea. The Tamiya "acrylics" work beautifully with Mr. Color Leveling thinner. I used to shoot them with X20A, but not anymore. The leveling thinner with that retarder results in a much better paint finish, and also one that is more durable. KUROK, ivanmoe, LSP_K2 and 1 other 4 Link to comment Share on other sites More sharing options...
