Trak-Tor Posted October 15, 2018 Share Posted October 15, 2018 That's quite impressive reconstruction! Juraj Martinnfb 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 15, 2018 Author Share Posted October 15, 2018 7 hours ago, blackbetty said: depending on the price i would maybe be in for an MF would the nose fit a UB? I did not figure a price yet, as it will depend on all the parts needed in the set. I just found out a new nose cone is needed and there could be more of the kit parts replaced to fit the conversion. I will try to keep the price reasonable. I think the new fuselage fits the UB kit. The UB has the small F intake so I wonder if there could be an issue with the front wheel well and gear lenth? I have the F kit and I can compare the respective parts to see if there is any problem. Alain Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 15, 2018 Author Share Posted October 15, 2018 6 hours ago, Trak-Tor said: That's quite impressive reconstruction! Juraj Thanks Juraj! I think the more difficult part will be to recribe the whole front fuselage. The rest of the kit is nice, the front fuselage sections are really the disappointing parts in it. Alain Martinnfb 1 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted October 15, 2018 Share Posted October 15, 2018 Super Stuff Alain, typical that the second go - or other half goes better. Now curious about the F-13! Martinnfb 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted October 15, 2018 Share Posted October 15, 2018 Stellar work all round Allan, can I please add my name to the list for a copy? Martinnfb 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 7 hours ago, phasephantomphixer said: Super Stuff Alain, typical that the second go - or other half goes better. Now curious about the F-13! Thanks, and I cut many of the styrene bits for the second half at the same time as the first. In what way are you curious of the F-13? Martinnfb 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 6 hours ago, Kagemusha said: Stellar work all round Allan, can I please add my name to the list for a copy? Thank you! Yes I will add your name to the list! Alain Martinnfb and Kagemusha 1 1 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted October 16, 2018 Share Posted October 16, 2018 31 minutes ago, Alain Gadbois said: Thanks, and I cut many of the styrene bits for the second half at the same time as the first. In what way are you curious of the F-13? Of similar dimension issues. I have a couple of them, only one MF and UB. Martinnfb 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 37 minutes ago, phasephantomphixer said: Of similar dimension issues. I have a couple of them, only one MF and UB. I didn't check the F-13 kit's dimensions but I know there's a problem in the cockpit area. The canopy should be angled downward and it's shape is bad. It's missing the bubble shape it should have, obvious when looking at photos. Alain Martinnfb 1 Link to comment Share on other sites More sharing options...
dora9 Posted October 16, 2018 Share Posted October 16, 2018 Alain do you think that the Black Box interior will still fit after all the modif you did? Nice work so far! Alain Gadbois and Martinnfb 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 The cockpit area will not change ( the original kit parts will fit perfectly in the new fuselage halves) appart for some slight modifications on the edges of the opening to correct the fuselage shape. The kit's clear parts will fit the resin parts also. dora9 and Martinnfb 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 On 10/15/2018 at 1:50 AM, blackbetty said: depending on the price i would maybe be in for an MF would the nose fit a UB? I checked a bit more about your question about the UB and the new fuselage. A sprue common to all MiGs versions has the rear fuselage parts and front wheel well parts. So there will be no problem with using a UB kit as a base. Martinnfb 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 14 hours ago, phasephantomphixer said: Of similar dimension issues. I have a couple of them, only one MF and UB. Checked the length according to MiG official dimensions and it seems the F-13 kit is a bit short by 3.5mm. Here are 2 photos of the F-13 at the Smithsonian in Washington DC to show what I meant by canopy shape. The kit fuselage: Greg W, Martinnfb and phasephantomphixer 2 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted October 16, 2018 Author Share Posted October 16, 2018 Hi all! Here's the top of the front fuselage. I will replace the panel with a new one that will be longer and will also feature the correct concave area where the oval is scribed at the front of the part. The inner detail in the kit still fits correctly if you move it back a bit . So if you have a resin replacement, it will fit also. I don't plan to do all the structural detail on the inside though. André, while looking in the box, I remembered I have the black box set!!! So here it is in place and it fits well when enough resin is removed from the bottom. The only thing is the back part is too vertical. I don't know if it is bent or what, so check yours to be sure. See how it sticks out ... Bye for now! Alain johncrow, Greg W, Menelaos and 4 others 7 Link to comment Share on other sites More sharing options...
dora9 Posted October 16, 2018 Share Posted October 16, 2018 Nothing that a bit of hot water won't fix! Nice work! Harold and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
