Bill_S Posted August 30, 2018 Share Posted August 30, 2018 A question for the experten: How do you deal with decals that meet at the trailing edge of a wing? I'm thinking WWI lozenge. Any tips would be appreciated! Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 30, 2018 Share Posted August 30, 2018 I normally set the underside of the wing decal first, cutting it so it ever so slightly overlaps the edge, then I apply the top wing decal so it does the same only overlaps on the bottom just a smidgen, so in the end if anything is visible seam-wise, it will be on the bottom of the wing and potentially less noticeable than the top. Bill_S 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 30, 2018 Share Posted August 30, 2018 FYI, I know they say dont use setting solutions on the lozenge decals, but Ive found some kind of solution seems to help snuggle things down too. Sol seems to work well in most cases, but Ive had to use Solvaset in a couple instances. MikeMaben 1 Link to comment Share on other sites More sharing options...
Gazzas Posted August 31, 2018 Share Posted August 31, 2018 This is a really good question. I was wondering about the tape that goes along the front edge... does another one follow the trailing edge? Link to comment Share on other sites More sharing options...
Bill_S Posted September 5, 2018 Author Share Posted September 5, 2018 Those scalloped trailing edges give me fits! Link to comment Share on other sites More sharing options...
