Out2gtcha Posted August 29, 2018 Share Posted August 29, 2018 45 minutes ago, Dandiego said: It is not a Sharpie. I use a water based marker that is made to use on vellum. I will get the exact type and post info when I get home tonight. Good stuff Dan. That makes it much more plausible to work with nearly all top coats. Please do let us know when you get the info. Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted August 30, 2018 Author Share Posted August 30, 2018 (edited) OK so here is the marker that I use. I think I bought it at Michaels craft store. I have only used this marker with Model Master enamels. Your mileage may vary. And a few pictures of the big beastie masked up. I have already sprayed the Dark Ghost Grey. I then apply these paper masks and will spray the Light Ghost Grey in very thin coats until I have the desired coverage of the preshading. I think this answers the question " what do you do with old kit instruction booklets". Dan Edited August 30, 2018 by Dandiego LSP_K2, MikeC, Out2gtcha and 1 other 4 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted August 30, 2018 Share Posted August 30, 2018 8 hours ago, Dandiego said: ... OK so here is the marker that I use. I think I bought it at Michaels craft store. I have only used this marker with Model Master enamels. Your mileage may vary. And a few pictures of the big beastie masked up. I have already sprayed the Dark Ghost Grey. I then apply these paper masks and will spray the Light Ghost Grey in very thin coats until I have the desired coverage of the preshading. I think this answers the question " what do you do with old kit instruction booklets". Dan It also answers THE other big question : « what do you need instructions for ? » Neat work Hubert MikeC, Out2gtcha and Dandiego 2 1 Link to comment Share on other sites More sharing options...
Dandiego Posted September 5, 2018 Author Share Posted September 5, 2018 (edited) Got a little time to start painting the camo. To say the least this paint scheme is intense. Besides the application of the colors much masking is needed to reproduce the look of the jet. Many panels needed to have their edges masked off and hundreds of stencils need to have the grey masked off so that it shows through and forms a grey area that surrounds each stencil. I have gone a little nuts trying to figure out the best way to do this. Anyway I have begun to add some of the simpler white areas that do not have much stenciling. And I got that mucked up right off the bat. I forgot to mask off some stencils on the elevators. Oh well I will just have to mask off and spray these areas grey. I believe that I will mask off the main camo colors and then slowly, carefully mask off individual panels and stencils. Should take just short of forever. Dan Edited September 5, 2018 by Dandiego Out2gtcha, MikeMaben, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
Dandiego Posted September 7, 2018 Author Share Posted September 7, 2018 Masking Spraying Creamsicle Crap, masking again.... Dan Daniel Leduc, Greg W, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 7, 2018 Share Posted September 7, 2018 Nice! Dandiego 1 Link to comment Share on other sites More sharing options...
ssculptor Posted September 7, 2018 Share Posted September 7, 2018 l love the paint job. Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted September 12, 2018 Author Share Posted September 12, 2018 More masking Nose Top of the wing Control surfaces. This area needs to be masked where the " No Step" markings will be. Fun huh? I may need to do about 300 of these small masks for the stencils. Later, Dan Out2gtcha, Greg W, Kagemusha and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 12, 2018 Share Posted September 12, 2018 That is some serious masking work there Dan! Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted September 13, 2018 Author Share Posted September 13, 2018 OK after some serious pondering and a hard look at the Twobobs decals I have decided that I will not need to mask for each stencil. Most of the decals already have a grey surround so they can be applied directly to the camouflage colors. I don't like the Two bobs No Step decals. They are very non-distinct, can't really tell what they are and they seem a little small to me. However the No Step decals that come with the kit are in English and that just won't do. So, with the tip of a new blade I will be cutting out the English lettering. This will be tedious but will hopefully give me the look that I am going for. This will speed up the entire build. Just a few more stencil masks instead of hundreds. Dan dmthamade 1 Link to comment Share on other sites More sharing options...
Madelf75 Posted September 13, 2018 Share Posted September 13, 2018 (edited) On 8/28/2018 at 9:01 PM, Dandiego said: A little progress.... I have put some dark Ghost Grey on the upper fuselage. I have preshaded the panel lines with a marker!! I know that some consider this as a bad move but it works for me. I was able to apply the shading over the entire airframe in only 20 minutes. The marker seems to soak in to the flat paint and does not present any problems on the color coats to follow. Anyway here are the photos. Go ahead....Fire away. Dan I use to do my pre shading this way This is a good way to find what works for you, one of the issues I had was the black would soak through the paint months after I painted it. Just remember got to do what you like Edited September 14, 2018 by Madelf75 Greg W, Out2gtcha and AlexM 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 13, 2018 Share Posted September 13, 2018 1 hour ago, Madelf75 said: one of the issues I had was the black would soak through the paint months after I painted it. Dan is actually using a marker for Vellum without the same permanent type bleeding issues as say a Sharpie has. On 8/29/2018 at 9:46 PM, Dandiego said: Saves a lot of headache later on! Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted September 14, 2018 Author Share Posted September 14, 2018 Hello Madelf75, everyone has their little cheats for building models and this is one that I have used before. I have built other models using this technique and have had no bleed through after 3 years. I did say that I use only Model Master paints and maybe that is the secret, who knows. Anyway this is a really fast way to do pre-shading and I thought I would share it with the group. Dan Out2gtcha and Madelf75 1 1 Link to comment Share on other sites More sharing options...
Madelf75 Posted September 14, 2018 Share Posted September 14, 2018 11 hours ago, Dandiego said: Hello Madelf75, everyone has their little cheats for building models and this is one that I have used before. I have built other models using this technique and have had no bleed through after 3 years. I did say that I use only Model Master paints and maybe that is the secret, who knows. Anyway this is a really fast way to do pre-shading and I thought I would share it with the group. Dan Cool i am sure when it is done it will look really good Link to comment Share on other sites More sharing options...
dmthamade Posted September 15, 2018 Share Posted September 15, 2018 On 9/12/2018 at 8:42 PM, Dandiego said: OK after some serious pondering and a hard look at the Twobobs decals I have decided that I will not need to mask for each stencil. Most of the decals already have a grey surround so they can be applied directly to the camouflage colors. I don't like the Two bobs No Step decals. They are very non-distinct, can't really tell what they are and they seem a little small to me. However the No Step decals that come with the kit are in English and that just won't do. So, with the tip of a new blade I will be cutting out the English lettering. This will be tedious but will hopefully give me the look that I am going for. This will speed up the entire build. Just a few more stencil masks instead of hundreds. Dan Yeah, the Two Bobs stencils are poorly done. Compared to newer sheets they are lacking. If they bother you that much, you could try and get a sheet from the Tamiya F-15J, the stencils are better, though some are a little squiggly. They don't have the grey background, so you would have to mask for that. Small improvement, probably not worth the extra work...was the orange an out of bottle color? Don Link to comment Share on other sites More sharing options...
