Padubon Posted August 25, 2018 Author Share Posted August 25, 2018 Here the tail assembly and the adjustments made. The gray stuff is actually old enamel paint, which I use to fill small seams. It works great and it shows well when is sanded down. KiwiZac, Alain Gadbois, LSP_Kevin and 6 others 8 1 Link to comment Share on other sites More sharing options...
1to1scale Posted August 25, 2018 Share Posted August 25, 2018 Looks good so far, I might be building this exact same version, I ordered the same decals earlier today. Link to comment Share on other sites More sharing options...
Padubon Posted August 26, 2018 Author Share Posted August 26, 2018 On 8/24/2018 at 9:49 PM, 1to1scale said: Looks good so far, I might be building this exact same version, I ordered the same decals earlier today. The P-40 is one of those aircraft I can't get enough of it! Link to comment Share on other sites More sharing options...
Padubon Posted August 30, 2018 Author Share Posted August 30, 2018 Getting there! just some putty and sanding here and there. I was carried away and added the exhaust stacks too early in the build. I had to remove them to sand the forward plate. Enjoy! KiwiZac, LSP_Kevin, Out2gtcha and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 30, 2018 Share Posted August 30, 2018 Looks great Paul. That forward cowl area and the quarter windows on the Has kit can be problematic for sure. Model on! Link to comment Share on other sites More sharing options...
Alain Gadbois Posted September 1, 2018 Share Posted September 1, 2018 Great progress! The P-40 looks great in desert colors! Alain Link to comment Share on other sites More sharing options...
Padubon Posted September 2, 2018 Author Share Posted September 2, 2018 (edited) On 8/29/2018 at 9:10 PM, Out2gtcha said: Looks great Paul. That forward cowl area and the quarter windows on the Has kit can be problematic for sure. Model on! I mentioned earlier, this is not my first Hase P-40. I don't understand why but this sucker does not fit anywhere. Edited September 3, 2018 by Padubon Misspelled Link to comment Share on other sites More sharing options...
1to1scale Posted September 2, 2018 Share Posted September 2, 2018 I have found that mine fit everywhere except the tail plug, the issue I discovered, was that the fuselage and the tail plugs are different shaped ovals. So far the best method I found was to bend the fuselage slightly and glue the plug to each side. Other than that, everything else is fitting perfectly. I suspect sometimes a few kits here and there get pulled out of the molds a little too early and may warp. KiwiZac 1 Link to comment Share on other sites More sharing options...
Padubon Posted September 3, 2018 Author Share Posted September 3, 2018 5 hours ago, 1to1scale said: I have found that mine fit everywhere except the tail plug, the issue I discovered, was that the fuselage and the tail plugs are different shaped ovals. So far the best method I found was to bend the fuselage slightly and glue the plug to each side. Other than that, everything else is fitting perfectly. I suspect sometimes a few kits here and there get pulled out of the molds a little too early and may warp. I envy you. Mine is weird all over. Link to comment Share on other sites More sharing options...
DesTROYer Posted October 27, 2018 Share Posted October 27, 2018 On 8/23/2018 at 3:38 AM, Padubon said: I finally figure out about the pictures. I will do a little better with the quality of the pictures later. Here it is, the Hasegawa P-40K with some aftermarket details. Outstanding. Gazzas and BiggTim 2 Link to comment Share on other sites More sharing options...
Padubon Posted November 26, 2018 Author Share Posted November 26, 2018 All primed! LSP_Kevin, BradG, Shawn M and 3 others 6 Link to comment Share on other sites More sharing options...
1to1scale Posted November 27, 2018 Share Posted November 27, 2018 On 9/2/2018 at 8:27 PM, Padubon said: I envy you. Mine is weird all over. I am going back on what I said earlier, of the 7, one of them fits wonky in a few places. I believe the N’s fit the best, then the K’s, the worst being the E’s. But it hands down the worst fit the F/L conversion, once you cut those front parts, the damn thing springs loose and twists on both sides. Link to comment Share on other sites More sharing options...
Padubon Posted November 27, 2018 Author Share Posted November 27, 2018 9 hours ago, 1to1scale said: I am going back on what I said earlier, of the 7, one of them fits wonky in a few places. I believe the N’s fit the best, then the K’s, the worst being the E’s. But it hands down the worst fit the F/L conversion, once you cut those front parts, the damn thing springs loose and twists on both sides. I wanted to do the F/L conversion but I heard the stories that you confirmed. I think I’ll pass on that, I am quite limited with my time as it is. BiggTim 1 Link to comment Share on other sites More sharing options...
1to1scale Posted November 27, 2018 Share Posted November 27, 2018 1 hour ago, Padubon said: I wanted to do the F/L conversion but I heard the stories that you confirmed. I am going to wait on the Trumpeter F. While the Gray Matter conversion is good, it does require a lot of work to make it fit perfect. It requires, fitting, sanding, filling, scribing, modification, surgery, and then repeat. The one advantage, it gives you a long tail. I wanted to build "MAD KOT" French P-40L, so it was my only choice. Link to comment Share on other sites More sharing options...
Padubon Posted November 30, 2018 Author Share Posted November 30, 2018 On 11/27/2018 at 8:58 AM, 1to1scale said: I am going to wait on the Trumpeter F. While the Gray Matter conversion is good, it does require a lot of work to make it fit perfect. It requires, fitting, sanding, filling, scribing, modification, surgery, and then repeat. The one advantage, it gives you a long tail. I wanted to build "MAD KOT" French P-40L, so it was my only choice. I will do the same. Link to comment Share on other sites More sharing options...
