alaninaustria Posted July 30, 2018 Share Posted July 30, 2018 Damn, this looks like a great build thread!! Cheers Alan Link to comment Share on other sites More sharing options...
seiran01 Posted August 1, 2018 Author Share Posted August 1, 2018 Skyraider experten, did the AD5s retain the flaps (armor?) inside the front of the cowl? Thanks Link to comment Share on other sites More sharing options...
otis252 Posted August 2, 2018 Share Posted August 2, 2018 I would say so. They were not armor. they were closed to warm up the engine faster in cold temperatures. Someone might expand on this more. Chuck LSP_K2 1 Link to comment Share on other sites More sharing options...
John1 Posted August 2, 2018 Share Posted August 2, 2018 Gonna be a lot of weight with that solid resin radome. Think the kit landing gear will be up to the challenge? Looking forward to this build, always liked the family version Spad. Link to comment Share on other sites More sharing options...
seiran01 Posted August 2, 2018 Author Share Posted August 2, 2018 The radome is hollow, two pieces and barely any added weight KiwiZac 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 2, 2018 Share Posted August 2, 2018 18 hours ago, seiran01 said: Skyraider experten, did the AD5s retain the flaps (armor?) inside the front of the cowl? Thanks Well Navy planes typically had them whereas AF ones deployed in SEA had them removed for an obvious reason: the permanently hot climate. LSP_K2 1 Link to comment Share on other sites More sharing options...
seiran01 Posted August 2, 2018 Author Share Posted August 2, 2018 Great thank you Thierry. Got something special going on in the kitchen. Paul recommends bleach to clean the parts, I’m going to see how well dish soap does first. LSP_K2, Dragon and scvrobeson 3 Link to comment Share on other sites More sharing options...
Simmo.b Posted August 2, 2018 Share Posted August 2, 2018 Of all the resin kits I've built I've had the biggest issues with paint lifting on Fisher kits......clean those parts well!! LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted August 3, 2018 Share Posted August 3, 2018 2 hours ago, Simmo.b said: Of all the resin kits I've built I've had the biggest issues with paint lifting on Fisher kits......clean those parts well!! I've used the bleach as recommended on my two Fury's without issue. But I use enamels. LSP_K2 1 Link to comment Share on other sites More sharing options...
seiran01 Posted August 3, 2018 Author Share Posted August 3, 2018 Well, soap ain’t going to cut it... Tamiya tape made quick work pulling a chunk of Mr Surfacer 1000 off. What options will work well with minimal fumes? I don’t have a garage to work in and not great ventilation in the basement Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 3, 2018 Share Posted August 3, 2018 Its not bleach caustic, but a friend in the movie prop business HIGHLY recommend Westleys (now Black Magic) "Bleache Wite" (yes its spelled like that) white wall tire cleaner to remove the massivly industrial mold release agents used in the prop biz. I tried it on my Fisher September Fury and it worked SO well, I think I've used it on every single resin kit since. While you probably wouldn't want to get it on your hands for any extended period, the fumes/smell are pretty minimal. paul fisher and LSP_K2 2 Link to comment Share on other sites More sharing options...
seiran01 Posted August 3, 2018 Author Share Posted August 3, 2018 Have read good things about Bleche White for resin cleaning so I’m going to try and find a bottle over the weekend. In the meantime, I’ve started working on the underside of the wing for the trainer. Catapult hook recesses have been filled with CA and sanded smooth, along with the seams of the new gear and oil cooler bits. I had to sand a little off the front end of the pylon to match the fuselage contour. Guppy radome also solidly glued with CA; I don’t like to use epoxy when I don’t have to so instead I added additional strips inside to strengthen the join. Again all is in process of being sanded flush. That’s it for tonight! Dragon, johncrow, scvrobeson and 4 others 7 Link to comment Share on other sites More sharing options...
seiran01 Posted August 3, 2018 Author Share Posted August 3, 2018 Lol and now I see Brian’s post about bleache white after I posted the last comment- thanks Brian :-) Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 3, 2018 Share Posted August 3, 2018 Its pretty good stuff and really does the trick on mold agents. It is still a bit caustic so keep it off your skin if possible. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted August 3, 2018 Share Posted August 3, 2018 Cool project, Mike. I'll be eyeballing, for sure. Link to comment Share on other sites More sharing options...
