ScottsGT Posted July 12, 2018 Share Posted July 12, 2018 I swear, I will finish this one before starting another kit! I don't remember the last time I felt this motivated to build a kit. Sorry for the clutter, I'm going at it so fast, I'm not even taking time to clean up!! Quite a bit has been done since this on. I'll up date later with new pics. BloorwestSiR, mustang1989, NukerDan and 9 others 12 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 12, 2018 Share Posted July 12, 2018 The Nautilus, neat! Is that the MM kit? Link to comment Share on other sites More sharing options...
Guest Posted July 12, 2018 Share Posted July 12, 2018 Please post more as you go. Very interested in this......Harv Link to comment Share on other sites More sharing options...
ScottsGT Posted July 12, 2018 Author Share Posted July 12, 2018 1 hour ago, Out2gtcha said: The Nautilus, neat! Is that the MM kit? Yes, its the 31". I've been eyeing it for probably close to a year. One of the 15% eBay discounts drove me over the edge. Being a cottage industry kit that is cast, there is a whole lot of clean up and corrections and scratch building that I'm having to do as I go along. At first I thought about buying all the interior salon details and lighting it up, but something about that reminds of of "toy" and not display piece. Out2gtcha 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 12, 2018 Share Posted July 12, 2018 Very cool project. I've seen more than a few Nautilus kits built, and they can look just great. Link to comment Share on other sites More sharing options...
mustang1989 Posted July 12, 2018 Share Posted July 12, 2018 2 hours ago, ScottsGT said: I swear, I will finish this one before starting another kit! Believe me pal..... I know the feeling. Looking forward to your progress. LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 12, 2018 Share Posted July 12, 2018 12 minutes ago, mustang1989 said: Believe me pal..... I know the feeling. Looking forward to your progress. As do I. The number of kits that I've started, far exceeds the amount that I've actually finished,... by like 40 to 1. Jeff, Out2gtcha and Tnarg 3 Link to comment Share on other sites More sharing options...
Gazzas Posted July 12, 2018 Share Posted July 12, 2018 This is something unusual. Looking forward to more. Gaz Link to comment Share on other sites More sharing options...
ringleheim Posted July 13, 2018 Share Posted July 13, 2018 So far she's coming along great! I'd be happy to see any and all photos you have of this build, along with your commentary. It's a nice impressive size! Link to comment Share on other sites More sharing options...
ScottsGT Posted July 13, 2018 Author Share Posted July 13, 2018 Quick update.... Took a few photos last night. first one is of the tail section and how I had to modify things to fit. The circular prop protector (lack of better words?) wasn't even large enough to fit into the vertical fin location points. The horizontal fins had notches cut out for them to fit into. I wound up cutting the half circles in half, epoxying into place and using styrene card stock glued together as a filler on the horizontals. I then shaped the styrene to blend with the fins. Half circles get support bars. Here's a shot of the really nasty part they cast from this plastic feeling resin laying under the part I made of brass rod and Evergreen stock. It was horrible looking and was not straight. One I get my parts fitted, shaped and trimmed (I had just epoxied them in place here) I'll add tiny white glue drops for more rivet detail so they will blend in. Main wheel house- comes with a vacuum formed sheet of "bubbles" you have to cut out. Unfortunately, after I cleaned up the very rough casting on the inside of the windows, there was no way to get the bubbles to fit so large of an opening. I again used Evergreen stock, epoxied into place to take up the space. I'll paint these areas and then glue in the bubbles with RC56 glue designed for cluing canopies on R/C airplanes. I have dental syringes on order from Amazon so I can squirt the RC56 out like a caulk gun. Back of the wheel house gets a window. I guess I was supposed to just use the scrap from the bubbles to cut a glass out for this. There was no way to hold the glass in place though! This opening had a frame with rivet details all around it. I filed them off and I'm going to use glass from microscope slide covers and cut a window. I'll then add evergreen stock to the edge of the glass along with more white glue rivets then I'll glue it in place. That's all for now. The real treat will be seeing how I fix the horrible bubble frames for the big salon bubbles on the side. They sent resin cast frames, but they are not even symmetrical. Got plans on more Evergreen stock and stretched and bent sprue to fix these areas. Trak-Tor, Out2gtcha, BloorwestSiR and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 13, 2018 Share Posted July 13, 2018 Nice work! Its tough TOUGH going with kits like this that have such unusual clear parts like 1/2 spheres. Polishing out, and making said parts even remotely clear is a job to itself. Model on! Link to comment Share on other sites More sharing options...
ScottsGT Posted July 13, 2018 Author Share Posted July 13, 2018 No kidding, for the smaller half rounds that go around the salon window for lights and the crocodile eyes on top of the wheel house, they send you an assortment of the "googly eyes" that you have to cut apart and use the lenses off of. Have not tried to size them yet, but I've read that none of them are the correct sizes. I might just round off the end of correct size wood dowel and press some out of clear blister packing material instead. Link to comment Share on other sites More sharing options...
ScottsGT Posted July 15, 2018 Author Share Posted July 15, 2018 Tail section almost completed. BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 16, 2018 Share Posted July 16, 2018 Scott Super progress and enjoying following your progress. One tough build for sure Keep ‘em comin Peter Link to comment Share on other sites More sharing options...
ScottsGT Posted July 16, 2018 Author Share Posted July 16, 2018 Here's my rebuilt rear glass. As luck would have it, I noticed that I cracked it when I was trimming the Evergreen stock for the edges. So now I have to slice it all off and start over. I think I'll switch over to some of the clear plastic since slide covers are so fragile. BiggTim and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
