blackbetty Posted July 12, 2018 Author Posted July 12, 2018 (edited) i will construct the main parts first and then start detailing them these are the walls of the pit 009 by karl holubar, auf Flickr inserted into the fuselage they give the front part the needed strenght. lower part is the wheelwell/gun compartment 008 by karl holubar, auf Flickr Edited July 13, 2018 by blackbetty LSP_Kevin, BradG, sandokan and 5 others 8
BradG Posted July 12, 2018 Posted July 12, 2018 Wow, cool, never seen one of these built. blackbetty 1
blackbetty Posted July 16, 2018 Author Posted July 16, 2018 for finding the right spot to fix the wings i think i will construct a spar that also fixes the dihedral of the wings. so next i cut out the wings and the main wheel wells. the wells will be boxed in for strenght and to have a locating point for the spar 010 by karl holubar, auf Flickr BradG, Alain Gadbois, Out2gtcha and 6 others 9
blackbetty Posted July 19, 2018 Author Posted July 19, 2018 wings and fuselage temporarily joint. there is a locating spar inside and a bulkhead in the middle to keep everything square. glue is now drying overnight, then i will drill locating pins into the wings from the inside 011 by karl holubar, auf Flickr 012 by karl holubar, auf Flickr BradG, LSP_Kevin, sandokan and 9 others 12
Out2gtcha Posted July 19, 2018 Posted July 19, 2018 Neat! This is looking super cool in LSP form blackbetty 1
blackbetty Posted September 12, 2018 Author Posted September 12, 2018 back to this one. after figuring out how to join the main parts i will concentrate on scribing this thing. the outer wing profile has been altered with miliput to make it look more like the real thing 013 by karl holubar, auf Flickr 014 by karl holubar, auf Flickr still have to work on the trailing edge Out2gtcha, BradG, Starfighter and 5 others 8
Out2gtcha Posted September 12, 2018 Posted September 12, 2018 Excellent work on Willie Karl. I still have to get the courage up to start my first vac. blackbetty and Shawn M 2
blackbetty Posted September 12, 2018 Author Posted September 12, 2018 its not as complicated as you think, you just have to plan ahead and live with some shortcuts boxing in the wheelwells 015 by karl holubar, auf Flickr johncrow, MikeMaben, BradG and 6 others 9
blackbetty Posted September 14, 2018 Author Posted September 14, 2018 kicking around ideas how to scribe the fuselage, i decided to join the halves before scribing. before i can do that i have to fabricate the intake trunking and engine faces. these are pretty much burried up way inside the fuselage and the intake has a noticeable bend upward so i found some plastic pipe of the right size and epoxied it in, being careful not to cover up the little auxiliary intake on the inner side 017 by karl holubar, auf Flickr Starfighter, MikeC, AEROPOXY and 5 others 8
blackbetty Posted September 14, 2018 Author Posted September 14, 2018 (edited) the faces are mig 15 parts from the trumpy kit with a 125lb bomb as the inner nose and some sheet for the little wings the pipe tapers downward for the engine to sit in the axis of the fuselage 016 by karl holubar, auf Flickr Edited September 14, 2018 by blackbetty sandokan, BradG, Starfighter and 4 others 7
Shawn M Posted September 14, 2018 Posted September 14, 2018 nice work Karl! Out2gtcha and blackbetty 2
Out2gtcha Posted September 14, 2018 Posted September 14, 2018 12 minutes ago, Shawn M said: nice work Karl! +1! blackbetty 1
blackbetty Posted September 20, 2018 Author Posted September 20, 2018 (edited) upon looking at scribing options it dawned to me that the intakes of the vac are not even close to the shape of the real thing, so i broke out the miliput and tried to reshape them first try 18 by karl holubar, auf Flickr 19 by karl holubar, auf Flickr not satisfiying, second try, we will see how i can sand this to shape: 20 by karl holubar, auf Flickr Edited September 20, 2018 by blackbetty mozart, Out2gtcha, Alain Gadbois and 7 others 10
LSP_Kevin Posted September 20, 2018 Posted September 20, 2018 Courageous and inspiring work, Karl! Kev blackbetty 1
