Greg W Posted July 5, 2018 Share Posted July 5, 2018 (edited) In February, I decided I wanted to take a stab at building one of Trumpeters 1/32 Skyhawk kits. After seeing a build of the Hasegawa 1/48 Skyhawk in Brazilian Markings, I knew that I had found the version of the aircraft and paint scheme I wanted to portray. Now that it is June, I will have to take a hiatus from modeling but come September, this project will pick up steam again. In the meantime, I thought I would post some pictures of the project up to now. Kit: 1/32 Trumpeter A-4M Here are some of the additions... -Eduard photoetch sets: A-4M interior A-4M slats A-4M exterior - Profimodeller set: 32098 Gun Barrels and Fuel Port - Avionix A-4M Skyhawk cockpit BLC32058 - AMS resin intakes - Wolfpack A-4H/N IDF conversion set Edited August 7, 2018 by GDW Whitey and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) Nothing like a new kit and a clean workbench! Edited July 5, 2018 by GDW Marcel111, Michael931080, HerculesPA_2 and 3 others 6 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) Normally I start with the cockpit but in this case, the Avionix set had not arrived in the mail yet. Therefore, since the Eduard exterior photoetch set was in my possession, I decided to tackle the job of cutting and folding the tiny vortex generators on the wings first. These delicate tabs are going to be left off the wings until just before paint. Evident in the above photo is the recess Trumpeter engineered into the front of the wing to accommodate the leading edge slats, in the closed position. There is not a step on the wing like that on the real aircraft. Since the slats will be deployed on my model, this area is exposed. Edited May 6, 2021 by GDW Marcel111, Alain Gadbois, NukerDan and 3 others 6 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) A length of Evergreen strip, underneath the rear edge of the photoetch piece, eliminated the step. I used the Photoetch Rolling Set (made by The Small Shop), to put a gentle curve in the flat Eduard parts. Edited July 29, 2019 by GDW Whitey, LSP_Kevin, Starfighter and 3 others 6 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) Next task, the AMS intakes which are a vast improvement over what comes in the kit. Edited July 5, 2018 by GDW Eagle Driver, Whitey, Harold and 7 others 10 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 5, 2018 Share Posted July 5, 2018 Looking good! I've taken the liberty of editing your last post, and directly pasting in an image from the link you posted. I'm not that familiar with Imgur, and couldn't find a way to grab an individual image's URL from the Imgur page they were on. You must have to be the logged-in user to access those things. Kev Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) The tail needed some surgery and I robbed a Wolfpack conversion set for the top of the vertical stabilizer and rudder. Edited September 14, 2020 by GDW Gigant, Starfighter, HerculesPA_2 and 3 others 6 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 Thanks Kevin! Yeah, I have been attempting to post images from my Kindle because my laptop is down and out. I'll be gosh darned if I can figure it out. The very first link was a HTML image option on the IMGUR drop down list. I thought maybe once I hit post, the image it is linked to might appear on my LSP post... nope LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) A little more work on the tail. I super glued a pattern made from plastic sheet to a section of photoetch fret. Cut it out and cleaned it up with a Tamiya diamond file. Edited July 5, 2018 by GDW Gigant, Marcel111, Eagle Driver and 5 others 8 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 Gigant, LSP_Kevin and HerculesPA_2 3 Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) Sweet! Finally managed to post an image. Thanks again Kevin for your help. For those of you reading this after the fact, when I started this, I only knew how to post links to the photos you now see. Edited September 14, 2020 by GDW LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted July 5, 2018 Share Posted July 5, 2018 Great work. Do you have decals? Link to comment Share on other sites More sharing options...
Greg W Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) Sort of. I have a beautiful set of 1/48 FCM decals which has the markings I want (FCM48-044). Also on the instructions are FS numbers for the paint scheme. Felipe Miranda, the man behind FCM Decals, told me he will be releasing this set on 1/32 down the road. At this point in time, I believe I will have to make my own. www.fcm.eti.br http://www.fcm.eti.br/48.html Edited July 26, 2018 by GDW Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 5, 2018 Share Posted July 5, 2018 Terrific start on the Scooter and looking forward to following your progress Keep ‘em comin Peter Link to comment Share on other sites More sharing options...
HerculesPA_2 Posted July 5, 2018 Share Posted July 5, 2018 Its a great build! A great aircraft for brazilian Navy - Marinha do Brasil.!!!! Im brazilian and great onour for this navy... What you need I be here for help you about more informations this A-4. great job! Congratulations!! Greg W 1 Link to comment Share on other sites More sharing options...
