Guest Peterpools Posted July 8, 2018 Share Posted July 8, 2018 Thanks Anthony Just love them Sea Fury's. Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 8, 2018 Share Posted July 8, 2018 Thanks Brian .. right with you on the wing issue and look. Both of my Sea Fury's have to be the latest runs as they have the open cowl for the Centaurus engine but the wing might be from an earlier run. A bit of tweaking and the wing is on and the CCA drying. Later today, I'll reinforce the interior seams with JB Weld Epoxy for extra strength. Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 8, 2018 Share Posted July 8, 2018 Anthony I live on Long Island and we'll absolutely get together when you're on the Isalnd Peter Link to comment Share on other sites More sharing options...
KUROK Posted July 8, 2018 Share Posted July 8, 2018 Hey Peter, Looks like you are doing the Oxford blue Sea Fury from RAAF? I'm doing that one too, someday. One thing I cannot find is the color of the wheel bay interiors although I know the restored version flying today is light gray. Also, I'm paying attention to the colors you use in the cockpit too because my sources are scant in that area too.... Vince Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 8, 2018 Share Posted July 8, 2018 Vince I'm kind of winging it but my researched showed early Sea Fury's left the factory with the yellow/green chromate color for the wheel wells and then later aircraft were finished with the underside color of Sky. Aircraft repainted in the field also had the wheel wells painted Sky. Since I'm going after the RAN 805 Sq of 1968, I'm assuming the wheel wells were still Sky but I do not have any definitive info or photos so prove it one way or another. If you are going to model the restored Sea Fury, then I would follow his colors to the T. I normally knock myself out with the colors but I'm already committed as the wheel wheels are painted and the wing is glued into place. Peter Link to comment Share on other sites More sharing options...
Anthony in NZ Posted July 9, 2018 Share Posted July 9, 2018 13 hours ago, Peterpools said: Anthony I live on Long Island and we'll absolutely get together when you're on the Isalnd Peter Wonderful Peter, it will be one of my highlights. Will keep in touch and let you know more closer to the time Cheers Anthony Link to comment Share on other sites More sharing options...
LSP_Ray Posted July 9, 2018 Share Posted July 9, 2018 Seafury is looking good, Peter! Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 9, 2018 Share Posted July 9, 2018 Clean and precise as always Peter. I took a look at my kit last night and I'd have to agree with you about the longevity of the wing fold. I'll be doing mine unfolded as well I think. Carl Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 9, 2018 Share Posted July 9, 2018 Anthony Absolutely and looking forward to meeting you after all these years Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 9, 2018 Share Posted July 9, 2018 Thanks Ray Getting everything now to fit is going to be a bit tricky - a bit too much zeal in sanding the wing to fuselage surfaces. Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 9, 2018 Share Posted July 9, 2018 Carl Right choice for sure and completely agree. I can just see a wing coming loose overtime with a bit of rough handling when dusting the models in the display. Peter Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted July 9, 2018 Share Posted July 9, 2018 Stunning, Peter, just stunning! i think you made the right move on the wing as there is not much of anything holding the folded sections together other than tiny resin hinge points. You can make steel support braces I suppose, but the real trick would be to cast the hinges in bronze with long anchor points to go in the wings, and then epoxy them in place. But that's beyond my ability You're on track to blow your previous RCN build away with how this is looking. Awesome! Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 10, 2018 Share Posted July 10, 2018 Hi Ernie Agreed and making slow and some clumsy progress. By working to tighten up the wing - fuselage fit which did go well, I inadvertently made the fuselage a bit too shallow for the cowling to mate up correctly and now have some tricky filling and sanding to do. Sometimes the lesser of the two evils is the better way to go. Ready to break out the Milliput and start filling. Peter Link to comment Share on other sites More sharing options...
LSP_Ron Posted July 23, 2018 Share Posted July 23, 2018 Time for an update! Yes my post is intentional and sincere Ron Anthony in NZ and scvrobeson 2 Link to comment Share on other sites More sharing options...
