themongoose Posted June 19, 2018 Share Posted June 19, 2018 So I haven't worked with resin a ton. Haven't seen this style mold before and don't want to mess up the leading edge of the tail separating it. Do i cut off the t-shaped rail and then sand the remaining part of the rail(the piece on the bottom in the pic below) down to form the leading edge of the tail? I'm just guessing here(said in Kelsey Grammar's voice from Down Periscope). BiggTim 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 19, 2018 Share Posted June 19, 2018 I normally use a thin blade saw like one of Radu's saws. He makes fine, medium and larger tooth saws. http://www.radubstore.com/index.php?main_page=index&cPath=77_112 MikeC, LSP_Matt, Thunda and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Maxim Posted June 19, 2018 Share Posted June 19, 2018 (edited) What I normally do is run a fin tip marker around where the resin pour stub joins the part. Cut the pour stub off as close as you can to the part with a saw as Brian suggested. Then slowly sand back the remaining pour stub. Use the black line you drew to know when you have removed all the pour stub. Be careful as you'll have to ensure you keep the leading edges contoured as you sand. Edited June 19, 2018 by Maxim Link to comment Share on other sites More sharing options...
BiggTim Posted June 19, 2018 Share Posted June 19, 2018 x2 on Brian's suggestion, saw. The other way is a scoring tool like a panel line scriber. phasephantomphixer and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Stevepd Posted June 19, 2018 Share Posted June 19, 2018 I use a razor saw then a heavy file followed by lesser grades. What ever method you use be aware of the fillings and dust = not good for your health. Steve. BiggTim 1 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted June 19, 2018 Share Posted June 19, 2018 If demarcation line of stub and part is not distinctive, use fine marker as suggested. With a thin edge part like shown, don't risk damage to LE using saw. Resin is brittle enough to just scribe along the marked line with pin, and snap stub off along scribed line. Then clean up edge with sandpaper. BiggTim and Thunda 2 Link to comment Share on other sites More sharing options...
themongoose Posted June 20, 2018 Author Share Posted June 20, 2018 (edited) Please excuse the extra detailed questions here, I want to make sure I don't goof this one up 😃 so I figure to ask twice and cut once lol I drew the line on the backside, opposite of where i think I'll end up sanding. Does this look right? If so then I make the cut just outside of that line to be safe and then sand off the remainder? Edited June 20, 2018 by themongoose LSP_Kevin and Rick Griewski 2 Link to comment Share on other sites More sharing options...
