Sign in to follow this
GrahamF
Anyone know what images LSP will accept now?
Hi, I don't now seem to be able to include an image in any posts that I want to put in, I used to be able to fiddle around with the bb code from Flickr [ never easy ] but I've drawn a blank it just will not work.
Any ideas?
Thanks Graham
Guest Peterpools
Hi Graham
My image files downloaded from Image Shack are 1280x1024 with no problems at all. I've never used Flickr but I assume the process is very similar and maybe the same as IS or PB. Can you explain the procedure you are using and hopefully we can help
Peter
Thanks Peter, So below is the bb code I get from my image:-
1-32 Scale Dambuster Upkeep Mine Parts
I've knocked out bits of this code before and used just this I think?
img][url=https://farm1.staticflickr.com/901/40600411110_55dc7f88af_z.jpghttps://farm1.staticflickr.com/901/40600411110_55dc7f88af_z.jpg[/img
And this used to work.
Graham
Guest Peterpools
Graham
The img link seems to be missing the URL at the start and end and is a lot shorted then the links on IM. I would double check to make sure it is the complete code
Peter
Thanks Peter, I've just made the post without clicking the image symbol and put the whole code in and it's worked you probable can't see the original code but it's a whole load of repetitive scribble.
Thanks
Graham
Hi Graham,
You were using url tags - just use img and /img (in square brackets) either side of image link and it should work.
Alternatively, just paste the image URL into the 'insert image' tool.
Then link the text back to your website if required using the link tool/icon in the post toolbar above...
Or is the link from Flickr including the url tags?
Iain
Guest Peterpools
Thanks Iain for being a lot clearer then I was. Glad the problem is resolved.
Peter
l tried image shack the other day to post a Neiuport and got no can do and it was not that big
Hacker
Just checked my Lanc MkII build and all the previous images are gone only my last post is there.
Graham
Edited by Lancman
