TimHepplestone Posted May 21, 2018 Posted May 21, 2018 New project will be the somwhat maligned Eduard 1/32 BF 109 E-4. Haven't decided on the markings yet but it iwll be a Battle of Britian era plane. Will be building basically OOB with just what Eduard provides. Which looks like quite a lot. MikeC, sandokan, LSP_Kevin and 1 other 4
Iain Posted May 21, 2018 Posted May 21, 2018 I'm quite a fan of the Eduard 109's Tim! I've had no real issues with the ones I've built - and with a few tweaks can look superb. Funnily enough - just acquired another copy of the boxing you've got there - I fancy doing Galland's to go with a signed print I have. Iain TimHepplestone and Kagemusha 2
TimHepplestone Posted May 21, 2018 Author Posted May 21, 2018 Decided to start woth the engine. Every review says the upper cowlings have a poor fit. So the decision was easy.. build it with the engine displayed. What comes with the kit with a bit of wring started: Detail is a bit soft for my liking but paints up nicely and added some more wiring as per some reference photos. Eduard calls out for the engine silver to be bare metal, but I found a rare period colour photo which looks more light RLM 02 so thats what I went with. The serial number is completly ficticious as I just cobbled it together from spare decals. Heres the period photo: MikeC, Kahunaminor, LSP_Kevin and 4 others 7
TimHepplestone Posted May 21, 2018 Author Posted May 21, 2018 I'm quite a fan of the Eduard 109's Tim! I've had no real issues with the ones I've built - and with a few tweaks can look superb. Funnily enough - just acquired another copy of the boxing you've got there - I fancy doing Galland's to go with a signed print I have. Iain Nice to hear!!
Iain Posted May 21, 2018 Posted May 21, 2018 Had no problems with cowl fit on mine - but did change the way the engine was mounted and cheated - with everything closed up. Really enjoyable build. Iain coogrfan 1
G-Man Posted May 21, 2018 Posted May 21, 2018 I've done the 1/48 and 1/32 version of this kit, both in Galland's scheme. The main complaint I had was how they designed the nose. It has a nasty looking seam you have to fill along the bottom. And if you're putting the upper cowling on, it may give you fit issues. It turns out really nice in the end though. I would suggest getting Master gun barrels for it as I knocked the kit ones off several times during the 1/48 build. Iain and TimHepplestone 2
LSP_K2 Posted May 21, 2018 Posted May 21, 2018 Always nice to see another '109 in the works, such a cool aircraft.
LSP_Kevin Posted May 22, 2018 Posted May 22, 2018 Great work on that engine, Tim! Kev TimHepplestone 1
ringleheim Posted May 24, 2018 Posted May 24, 2018 I built this kit myself. It went together fine, though it did leave that slightly bad taste in my mouth that all Eduard modeling experiences leave! Your kit will look great when its done.
Greif8 Posted May 27, 2018 Posted May 27, 2018 Nice start on a nice kit Tim. I built this kit a few years ago to resemble Helmut Wick's aircraft circa late October 1940. I thought it went together nicely, though, like Ian, I did modify the engine and MG Tray assembly a bit to get the cowling to fit well. Ernest TimHepplestone 1
TimHepplestone Posted June 17, 2018 Author Posted June 17, 2018 Finally a bit of time to get back to the 109. Fitted the PE and a bit of scrathched extra wiring to the cockpit. Painted Hatakals RLM 02 with some light drybrushing. Then a burnt umber with a smidge of lamp black oil wash. LSP_Kevin 1
TimHepplestone Posted June 17, 2018 Author Posted June 17, 2018 Engine added.Nearly ready to start buttoning up. Kahunaminor, LSP_Kevin, Kagemusha and 1 other 4
TimHepplestone Posted July 22, 2018 Author Posted July 22, 2018 After nearly a month away from the bench , finally got some modelling in today. Closed up the fuselage and gatting the airframe closer to the paint shop A few seams to tidy up,then off to the paint shop. MikeMaben, LSP_Kevin, Out2gtcha and 4 others 7
TimHepplestone Posted August 12, 2018 Author Posted August 12, 2018 Little more progress: Assemble , painted and weathered the undercarriage. Will add a pigment wash to higlight the tread methinks. While I was doing that assembled the Eduard IP. Pretty simple, just a flat coat on the prepainted eduard followed by some future to bring out the instrument dials. Just added a cable for the revi gunsight from lead wire And here it is installed into the cockpit. MikeMaben, Out2gtcha, Dany Boy and 1 other 4
