Doing `Dremeling´ I recognized that the openings for the optional weapons panels are quite thin:
http://20180514_070250.jpg
http://20180514_070303.jpg
I was thinking of opening on one side and do the inside from scratch.
But in the end I decided not to, because the lines of the Gina would have been ´destroyed´ and the solid casting of the intake makes it much more difficult.
Maybe an very attractive option for another model....?
The opened hatches had to be scratchbuilt using sheet, copper wire and lead foil.
Here it goes:
http://20180316_165147.jpg
http://20180316_171552.jpg
http://20180320_121044.jpg
http://20180320_121314.jpg
http://20180320_122251.jpg
and the original one
http://li_Hydrauliktank_und_%C3%96l.jpg
As you can see there are two lockings, painted red (inside only). These have to be added to the parts.
What the photos of the replicas don´t Show - there was some bending to align them to the fuselage.
Next task is scratching the engine....
Really enjoying seeing all the detailed scratch-building going on - great use of lead foil over the wire base for those inspection panels, an interesting technique.
Torben  :popcorn:
Very innovative building, I am learning some new techniques.
Cheers,
Marcel
Well done Isar! Very interesting wip!
I've collected some "walkaround style" photos (one album from mine and the other one from a portuguese blog) about the G91, so if could help you can see those into my facebook profile https://www.facebook.com/tiberio.riva
Cheers
Tiberio
Great reference pics Tiberio!!
Thanks for sharing!
@Reimund...I think I have to come over and pick up my Gina. Before you start a second one ;-)
Marcel,
thank you very much for you comment!
That is the great challenge doing modelling: Never stop searching for solutions trying to build the ´best´ model I can!
Give it a try - it doesn´t work it should be? Ok, next try!
Doing and learning - I love this hobby!
Tiberio,
YOU make my day! Thank you very much for sharing these pics!
There are of course some ??? in specific areas, such as: what´s behind the ejection seat!
Thanks for helping me out!
Alex,
do you still think, your Gina is UNSTARTED???
Cheers
Reimund
Next stop: the engine!
As usual some pics of the real one...
http://IMG-20180317-WA0000.jpg
http://IMG-20180317-WA0003.jpg
http://IMG-20180317-WA0004.jpg
But how much would you see looking through the hatches?
right side
http://Kartuschenzugang.jpg
http://Kartuschenbeh%C3%A4lter.jpg
left side:
http://li_Hydrauliktank_und_%C3%96l_2.jpg
As I had no idea of the size of the engine, I did it and checked it over and over.
So, as long as it looks OK to my eyes, I´m happy with it:
First, I was looking for a tube acting as a base. As I couldn´t find any porper size one, I used a tube and glued some sheet around it.
Sounds easy but bending a 1mm sheet is not that easy. Once the CA has set, the tube has a rippled surface.
Lot of sanding next.
Did a lot of research in my spare parts boxes but couldn´t find any parts that would be helpful. So, all parts hat to be done scratch using sheet, strips, tubes, lead foil, copper wire and electrical wire:
http://20180515_075054.jpg
The result after three hours of work. 118 parts glued togehter so far. But there is something wrong...
http://20180515_075042.jpg
THIS is far to close!!! What to do now? Can I live with this mistake? No.
http://20180515_080512.jpg
Adding a spacer ring from a part found in the spare parts box. (this I had to cut as it was too wide)
http://20180515_080906.jpg
Yes, this looks much better now!
http://20180515_081548.jpg
Next step was doing the hydraulic tank. Base was the curved part of the front fender of a Königstiger.
Using sheet, putty, and later a lot of sanding it looks a little like the real one.
To do the reinforcing ribs I glued some thin sheet/strips onto and sanded them again.
http://20180515_075137.jpg
Next step was to cover with some lead foil. A friend of mine works at a dentist. The X-Ray films they are using are protected by a very thin lead foil - perfect for this task.
http://20180515_094322.jpg
Slightly pressed onto the styrene part and the ribs are done easily.
A little bit of detailing later
http://20180515_135512.jpg
http://20180515_135522.jpg
http://20180515_135536.jpg
Referring to the original, hardly there will be seen anything later.
Next - the starter cartridges containers:
http://20180515_135606.jpg
http://20180515_135630.jpg
When painting is done, there are some wires to be fitted.
Taking a close look into the fuselage through the hatches, one can see some framework inside.
Ok, this was photo was taken using some flashlight, but framing is inside.
Did this on the insides just to know that there is some structure inside.
http://20180515_135700.jpg
By constructing the engine I was thinking of placing a light inside the fuselage so that a little bit more is to see once the model is finished.
But - where to hide a battery, even a small one?
What do you think about this? Any ideas where to place a power supply? I don´t want to place the model on a diorama or so, so the options are limited.
Auxiliary tanks and rocket pods are no choice either. Gear wells? Maybe...
And at last: The framing on the fuselage openings:
http://20180515_135649.jpg
Thanks for looking
Reimund
