RLWP Posted April 23, 2018 Share Posted April 23, 2018 Really, I have too many projects on the go. This is the WNW Roland C.II lightly modified to be one of the 'planes in the gap between the two kits Trying to keep this one simple Richard Gazzas, Iain, Pfuf and 6 others 9 Link to comment Share on other sites More sharing options...
dutik Posted April 23, 2018 Share Posted April 23, 2018 Nice beginning! - dutik RLWP 1 Link to comment Share on other sites More sharing options...
Uncarina Posted April 23, 2018 Share Posted April 23, 2018 (edited) Richard, It looks like a good start! Have you considered adding a dark wash around some of the details? This would make them stand out more, especially once you seal up the fuselage. Cheers, Tom Edited April 26, 2018 by Uncarina Link to comment Share on other sites More sharing options...
RLWP Posted April 23, 2018 Author Share Posted April 23, 2018 Richard, It looks like a good start! Have you considered adding a dark wash around some of the details? This would make them stand out more, especilally once you seal up the fuselage. Cheers, Tom Probably not more than I already have. Richard Link to comment Share on other sites More sharing options...
RLWP Posted April 25, 2018 Author Share Posted April 25, 2018 (edited) What a lovely thing the engine is. Shame so little will be visible, I could have saved a lot of time by not modelling the bits that can't be seen Engine is loose in it's frame at the moment My fingers are itching to detail the top of that carburettor and wire up the magnetos - I shall resist Richard Edited April 25, 2018 by RLWP USMC Herc, LSP_Kevin, Iain and 1 other 4 Link to comment Share on other sites More sharing options...
RLWP Posted April 26, 2018 Author Share Posted April 26, 2018 TorbenD, Vandy 1 VX 4, Trak-Tor and 2 others 5 Link to comment Share on other sites More sharing options...
RLWP Posted April 27, 2018 Author Share Posted April 27, 2018 Richard Gazzas, LSP_Kevin, Gigant and 3 others 6 Link to comment Share on other sites More sharing options...
TorbenD Posted April 27, 2018 Share Posted April 27, 2018 Lovely looking build Richard - top drawer Torben Link to comment Share on other sites More sharing options...
karimb Posted May 1, 2018 Share Posted May 1, 2018 Superb! I keep putting off starting on mine. Richard your build is very inspiring! Looking forward to more. And don't forget not to fill the seam line when you join the two fuselage halves! That's how they were actually built and assembled in two halves! Karim Uncarina 1 Link to comment Share on other sites More sharing options...
RLWP Posted May 1, 2018 Author Share Posted May 1, 2018 And don't forget not to fill the seam line when you join the two fuselage halves! That's how they were actually built and assembled in two halves! Karim Yep, got that one. There's a covering strip between the two sides, and it's causing a bit of a headache. I'll primer it first to see what it looks like before deciding if it will clean up, or if I'm going to sand it off and glue a strip in place Richard Link to comment Share on other sites More sharing options...
RLWP Posted May 2, 2018 Author Share Posted May 2, 2018 It's going to have to be paint soon If I were building another of these, I'd join the tail parts B14 and B13 to the sides before closing the fuselage. It would reduce the small gap before and behind the tailplane. Not that it was hard to fill On the other hand, following the suggested sequence (sort of) I could glue the two D14 parts together to make the tailplane then join that to the fuselage before fitting the B13/B14 assembly Other parts: Richard LSP_Kevin, Out2gtcha and Vandy 1 VX 4 3 Link to comment Share on other sites More sharing options...
RLWP Posted May 4, 2018 Author Share Posted May 4, 2018 OK, I need some help I'd like to use a very light blue-grey paint, something that is difficult to work out if it is blue or grey What I could do with is a selection of paint charts - I think - or some ideas on how to achieve this Richard Link to comment Share on other sites More sharing options...
karimb Posted May 14, 2018 Share Posted May 14, 2018 Richard, the blue gray is quite hard to get... I often have thought about this when trying to choose my next kit to build and the Roland was in the list and always ended up skipping that. At the end of the day as long as you think it looks good it should work, i don't know if there are any paint chips remaining from that specific color floating around... Link to comment Share on other sites More sharing options...
RLWP Posted February 16, 2020 Author Share Posted February 16, 2020 Oh dear, nearly two years... Never mind, this one is done! Wingnut Wings Roland C.II with Gaspatch Spandau and Parabellum, plus bomb rack and sliding windows. It's OK, the wing to fuselage joints really needed a lot more attention before painting. And using black undercoat underneath, grey on the sides and white on the top made touching up the blue paint an absolute nightmare! I'm very pleased with the 'long' turnbuckles. Amazing what you can do with a bit of twisted copper wire and some paint... Richard USMC Herc, Vandy 1 VX 4 and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
