That's a vent.  The piping is indicative of a later block P-51D.
Thank you for the clarification. Does that mean that earlier block P-51D didn't have the piping?
Gizmo :   I1ap0ll.jpg
Mike, did the pilots time the use of their drop tanks when selected, or did the drop tanks feed fuel into the main tanks? Am unfamiliar with the P-51 system... or, were the drop tanks a direct feed system?
Cheers
Alan
No, it means that the piping went only aft.  The forward portion (small diameter tubing) wasn't there in earlier aircraft.  Below is a snip from the P-51D/K IPC. You see the vent pipe (item 33) and the two tubing connections.  The forward tube was added on later block P-51D's (I didn't read far enough to determine the serial number break for early vs. late) but the P-51D-5 would definitely have the early version of the vent.
Edited by Juggernut
Guest
Cheers
Alan
Yep, all 5 tanks were independent feed. Earlier a/c (again, no specific
cutoff date) had a fuel vapor return that lead to the left wing tank. Later,
they moved it to the fuselage tank (probably that pipe Juggernaut was
pointing out.) The pilot would find out which by asking his crew chief.
The tank that received the vapor would need to be used first so there
was room in the tank for the vapor overflow.
hth
Guest
I'm guessing the vapor overflow vent was moved to the
fuselage tank because pilots liked to use the fuselage tank
first as it affected the balance of the a/c.
:shrug: ?
DEALING WITH THE CLEAR PARTS
We all agree that the main issue of the Revell Mustang is in the clear parts, notably the canopy and the windshield which present some awful distorsion in their transparency.
While the Revell canopy can be replaced by one of the three optional canopies included in the Tamiya 1/32 P-51D kit, the main problem resides in the windshield, particularly the central panel which has to be optically flat, i.e. without distorsion, There is no other solution than to replace it.
This is how I did it.
Original kit windshield
57_BB4395_4725_411_A_A68_F_A2_CB3_B89903
A piece of Scotch Magic Tape is stuck over the windshield and the central panel contour traced over it
05_FCEA09_5_D26_48_D3_BB60_FF4_ABD92_AB3
The Magic Tape is removed and stuck on a suitable piece of clear polystyrene, in this case a CD case.
It's our template for the new central panel
F187_D901_E81_F_4648_B6_F1_56_DE18753314
100179_E1_3059_452_E_980_C_F0_F9_A28_DED
Now, the nerve-wrecking part: holes are drilled around the contour of the central panel. Masking tape is used to protect the remaining part of the windshield from scratches.
09669_B4_C_8_A92_4_F8_F_849_D_9_C17_E1_B
Center part is removed and ready to be cleaned-up and adjusted.
F7287_D22_85_CD_4_BBF_B982_88_C8_B9030_E
Windshield ready for new central panel
7_D2_A9_E4_C_ABA1_48_A2_BA04_2_DB83_E000
New central panel is cut using the Magic Tape template.
AC05_A390_AF9_F_47_AE_B5_F8_68101_D4179_
After numerous adjustments, the new panel and the receiving windshield are joined and secured with UV-curing glue.
B4376_D62_01_C1_420_C_BAA4_9_F4_A202_DD5
The modified windshield in-situ
4_E6761_B2_D764_4_E3_D_BD99_7833_D688_A6
77_ADFD23_F9_BF_48_AF_9540_9_D38_FD9142_
That's it for now, folks. Hope you like it.
Hasta la vista,
Quang
