Phartycr0c
Tanmodel.
I must admit, I know nothing of the brand. I don't know about overall quality, detail  tooling number of rivets etc, just that the announced subject matter appears to, in most cases, add to rather than directly duplicate the availability of subjects for us 1/32 scale freaks.
IF, the F111 does materialise and assuming a decent level of accuracy and price,  it will be one impressive beast set to grace my shelves, especially with LN or UH markings.
Guest Maxim
I'd certainly be in for an F-111. I'd would prefer to build an F-111C with the longer wings. I'd even be tempted to build the F-111B with AIM-54 Phoenix under the wings!
Let's just hope he holsters the divot gun that he used to ruin his RF-84F.  I can show you closeup photos of one that proves him wrong on that.
I'd rather see photos of anything you built the past 12 months. But I must admit I admire your positive attitude. :whistle:
Cees
No combat history, etc, etc, etc.
Remember this famous footage that "Stormin Norman" used in one of his press conferences?
Buccaneer.
Oh and you might like to read this as well.
https://defenceoftherealm.wordpress.com/2014/12/03/aircraft-gallery-buccaneer-in-the-gulf-91/
F-111 for me too please in 48th TFW markings preferably. Practically live at Lakenheath in my late teens.
One point for Tanmodel though. Looking down the list, I spy a 1/48 Blenheim. I thought that Airfix will probably have that sown up, so if Tanmodel would like to up the scale of their Blenheim to 1/32, I would be very, very happy. Thank you.  :thumbsup:
PHANTOMS
The Tamiya F-4E is ideal for an Edwards ex-Thunderbirds jet, with only minor mods (removing the LCOSS gunsight etc).
I believe Tan Model are planning on both wing types, to facilitate a "hard wing" F-4EJ and RF-4E/EJ.
How they do this is an interesting exercise; it would need, primarily, three types of lower forward wing and carry-through wing torque box:
A/ original wing with BLC flaps and piano hinge (probably retracted, with no blown flaps option)
B/ slat retrofit for the leading edge with the steel beef-up strap across the wing torque box, and
C/ the ab initio slatted wing with the thicker torque box skin (which lent a pronounced lip at its trailing edge, roughly coincident with the MLG bays) that ran under the fuselage and across the lower wings, all the way to the wing-folds.
AARDVARKS
The proposed Tan Model F-111 airframe is the F-111A/E which were identical apart from the translating cowl vs Triple Plow inlets. F-111Es flew from Incirlik during Proven Force (G1) and are obviously of interest to Turkish modellers too.
With longer wings and bigger wheel hubs you could make an F-111C. With the Spark'Vark mods you could build an EF-111A Raven. With longer wings, bigger wheel hubs, different dump mast, Mk.IIB cockpit IP and dorsal nasal mods for Astrocompass you could make an FB-111A. The dorsal nose bump could also be made, along with revised IP, to create AMP F-111A/E aircraft.
The F-111D/F used a slightly different airframe with revised ECS venting and slight changes to the rear empennage to accommodate TF30-P-100 engines (which only the F got).
You could probably get an F from the A/E if you change the ECS to the bumpy type, add a Mk.IIB cockpit IP, add the Pave Tack pod and cradle, and change the engine nozzles.
You could get away with making a D from the A/E if you change the ECS and add the Mk.II cockpit IP and twin HUDs.
Fun times ahead if you get to see this stuff,
Tony
Well Jennings, for every Buccaneer you don't buy, I'll buy two.....
Yes indeed, me too, I have fond memories of seeing them at Honington in the 1970s.  Shiny Twelve in the early scheme and a Germany-based one (XV or 16 Sqn) in wrap-around camo for the other.  Perhaps I'd better get 3, and do the 208 Sqn ship that was desert-camouflaged for Red Flag one year.
Edited by MikeC
I'd buy two Buccs as well:
overall dark sea grey FAA bird from the Ark, and one of the desert pink 'Spike jets with the ladies and Scotch whisky artwork.
Tony
I'd definitely be up for the F-5, F-111 and F-4E kits. I'd also go for the Buccaneer as I remember beating the old Airfix 1/48th scale kit into submission a few years ago and wishing at the time, that someone would produce a nice, accurate and well detailed kit of the same :D!
Don't get me wrong, the Airfix kit turned out nicely, but it was definitely not a fun-filled project.
