cbk57 Posted October 22, 2018 Share Posted October 22, 2018 (edited) I looked at the Copper state sprues and parts at my earliest opertunity. When I firsat saw the CAD images, I actually thought it was a WNW kit. It took a while to figure out that it was not. Even looking at early sprue shots, I thought it WNW based upon the style layout of the sprues, runners and gates. One thing I noticed early on are the fine gates at the attachment points and the overall attention to detail in the molding design. My expectation is that this kit will fit togther just as well as a WNW kit. At one time we would have expected a newer maker’s parts to not fit well etc however that is not as much the case anymore. When WNW came out no one could believe how well they fit together and actually their problem was that in some cases their design tolerances were too fine making it hard to fit wings into designed slots and things like that. If you have built their Albatros D.V. and fit the rods that holds together the cockpit frames you will also understand. Getting that cleaned up enough to go through the required holes is a minor miracle in itself. Now we see this more often with new manufacturers like Takom, Meng Rye Field and others. Out of the gate their models are highly detailed well engineered and fit together well. With contemporary design standards, poor fit on fully engineered kits is becoming less of an issue. Instead it is more likely to find design errors resulting from research mistakes or other basic mistakes than can happen in any design process. In the end I have the highest confidence that Copper State is going to deliver a first class Nieuport kit if I were in a position to buy one now I would, I just have too many other things going on. I am going to add another point about the Copper state kit, when you look at the panels that make up the back of the plane, it looks like the sides and top assemble onto some sore of frame. This means there will be no seems to fill in places that would not have one. Even WNW have not tried this in their kits. We will have to await a review but it looks like the Nieuport all the panels fall on natural panel lines so in that regard there will be a much easier build up. I do see a lot of ejector tabs or something on the parts, those are easy to nip off and clean up. The runner gates to the parts are really fine so that will make clean up go better. Give this thing a chance, it looks like it is going to be a great model. Edited October 22, 2018 by cbk57 Out2gtcha and Jan_G 2 Link to comment Share on other sites More sharing options...
DeanKB Posted October 22, 2018 Share Posted October 22, 2018 6 hours ago, cbk57 said: I looked at the Copper state sprues and parts at my earliest opertunity. When I firsat saw the CAD images, I actually thought it was a WNW kit. It took a while to figure out that it was not. Even looking at early sprue shots, I thought it WNW based upon the style layout of the sprues, runners and gates. One thing I noticed early on are the fine gates at the attachment points and the overall attention to detail in the molding design. My expectation is that this kit will fit togther just as well as a WNW kit. At one time we would have expected a newer maker’s parts to not fit well etc however that is not as much the case anymore. When WNW came out no one could believe how well they fit together and actually their problem was that in some cases their design tolerances were too fine making it hard to fit wings into designed slots and things like that. If you have built their Albatros D.V. and fit the rods that holds together the cockpit frames you will also understand. Getting that cleaned up enough to go through the required holes is a minor miracle in itself. Now we see this more often with new manufacturers like Takom, Meng Rye Field and others. Out of the gate their models are highly detailed well engineered and fit together well. With contemporary design standards, poor fit on fully engineered kits is becoming less of an issue. Instead it is more likely to find design errors resulting from research mistakes or other basic mistakes than can happen in any design process. In the end I have the highest confidence that Copper State is going to deliver a first class Nieuport kit if I were in a position to buy one now I would, I just have too many other things going on. I am going to add another point about the Copper state kit, when you look at the panels that make up the back of the plane, it looks like the sides and top assemble onto some sore of frame. This means there will be no seems to fill in places that would not have one. Even WNW have not tried this in their kits. We will have to await a review but it looks like the Nieuport all the panels fall on natural panel lines so in that regard there will be a much easier build up. I do see a lot of ejector tabs or something on the parts, those are easy to nip off and clean up. The runner gates to the parts are really fine so that will make clean up go better. Give this thing a chance, it looks like it is going to be a great model. I believe that the Junker D.I kit does this? Link to comment Share on other sites More sharing options...
cbk57 Posted October 23, 2018 Share Posted October 23, 2018 (edited) Most of their kits though have a seem running through the center of the rear fuselage. I remember my Sopwith pup had a pretty nasty gap in it, might have been my fault though. The runner gate on the pup was also on the large side and ran right on the surface that needed to be glued, in one spot I got too much plastic as I recal and had a divot. The whole seem on the central spine had to be filled and I think on the lower as well. Edited October 23, 2018 by cbk57 Out2gtcha 1 Link to comment Share on other sites More sharing options...
Pup7309 Posted October 24, 2018 Share Posted October 24, 2018 Have only purchased WNW kits but if CS bring out a comparable quality subject and it’s the only one available they have my $. Rick Griewski 1 Link to comment Share on other sites More sharing options...
Pup7309 Posted November 3, 2018 Share Posted November 3, 2018 They are showing 0 stock now. Just have to wait... Link to comment Share on other sites More sharing options...
Pup7309 Posted November 14, 2018 Share Posted November 14, 2018 When are these likely to go on sale? Link to comment Share on other sites More sharing options...
ringleheim Posted November 14, 2018 Share Posted November 14, 2018 51 minutes ago, Pup7309 said: When are these likely to go on sale? The pre-order kits are shipping now. A few modelers have already received them in the mail. Very early word is that the kit is perhaps even better than a WNW offering. Link to comment Share on other sites More sharing options...
CANicoll Posted November 14, 2018 Share Posted November 14, 2018 I kind of saw the kit on their table at Telford but to be honest completely forgot this was coming out or I would have stopped and asked them about it. I have had good luck with CSM customer service in the past. I have two WNW kits (well, the Green Tailed Trilogy and the Richthofen Albatross) to build, but not sure I'd go for the CSM Nieuport. If it gets good reviews I might give it a go. I'm kind of burned out on WWI subjects due to HobbyCraft/Roden build issues but hoping WNW revitalizes me. Chris LSP_K2 and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 14, 2018 Share Posted November 14, 2018 Man, after seeing CAD images and all the hype, Im really looking forward to picking up a "Late" 17 Bill_S 1 Link to comment Share on other sites More sharing options...
monthebiff Posted November 14, 2018 Share Posted November 14, 2018 I picked up a late bixing at Telford on Saturday and have to say it's a little gem. I will post some spruce shots later if people would like but it looks fantastic! Regards. Andy LSP_K2, CANicoll, scvrobeson and 2 others 4 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted November 14, 2018 Share Posted November 14, 2018 31 minutes ago, monthebiff said: I picked up a late bixing at Telford on Saturday and have to say it's a little gem. I will post some spruce shots later if people would like but it looks fantastic! Regards. Andy Yes. I, for one, would love to see them. Bill_S 1 Link to comment Share on other sites More sharing options...
petrov27 Posted November 14, 2018 Share Posted November 14, 2018 The posting I have seen from someone with it already in hand was extremely positive - I preordered but not sure when I will see them delivered - hopefully soon! Link to comment Share on other sites More sharing options...
mattlow Posted November 14, 2018 Share Posted November 14, 2018 I suppose we'll see the contents soon enough, but I haven't seen any images of whatever the PE included comprises? PE is still mentioned on the CSM website today, but I've never seen it portrayed. I'm very glad to see another high quality manufacturer join WNW in mining the rich seams of WWI subjects out there. These two could keep going for years and not tread on each other's toes. May they both continue to supply top notch 1/32 kits. Matt Jan_G 1 Link to comment Share on other sites More sharing options...
petrov27 Posted November 14, 2018 Share Posted November 14, 2018 19 minutes ago, mattlow said: PE is still mentioned on the CSM website today, but I've never seen it portrayed. Seatbelts & windscreen frame looks like: KiwiZac, mattlow, MikeMaben and 3 others 5 1 Link to comment Share on other sites More sharing options...
Bill Cross Posted November 14, 2018 Share Posted November 14, 2018 Not crazy about film windscreens, but this one definitely has my interest. Love WNW, but they ignore the French!! Rick Griewski and Bill_S 2 Link to comment Share on other sites More sharing options...
