Bstarr3 Posted April 3, 2018 Share Posted April 3, 2018 Fantastic work in the engine! Link to comment Share on other sites More sharing options...
1to1scale Posted April 8, 2018 Author Share Posted April 8, 2018 I am finally ready for primer and paint, wrapped everything up and glued it all together. BradG, Shaka HI, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
1to1scale Posted April 9, 2018 Author Share Posted April 9, 2018 White undercoat for the markings has been sprayed, I spent about two hours applying the masks. Hopefully, one night this week I will finish painting. I also spent about 2 hours building and sanding seams off of the HVAR rockets, bombs are also ready for paint. So far this build has been great, no real fit problems. My only problem has been sprue hunting, being the third issue, there are a lot of duplicate parts with small differences. I have made a few wrong part goofs, but was able to correct all but one. The biggest mistake was that I built the wrong early prop, luckily, I had a birdcage in the closet and I was able to swap the prop into, and steal the prop hub out. johncrow, BloorwestSiR, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
1to1scale Posted April 9, 2018 Author Share Posted April 9, 2018 I have been studying pictures I could find of the Brooklyn Butcher, and have come to the conclusion that the weathering on this squadron's aircraft was very light. Early on, while on the carrier, they looked almost new with no scratches or fading. Later when moved to land, they collected a few scratches and dirt, but still pretty light. On my build, I will be doing very minimal weathering, keeping it in like new, carrier condition. Gazzas, Shaka HI and patricksparks 3 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 9, 2018 Share Posted April 9, 2018 Great progress there. It looks kind of odd with the stars and bars as negative shapes vs what we're used to seeing. Carl Link to comment Share on other sites More sharing options...
1to1scale Posted April 9, 2018 Author Share Posted April 9, 2018 (edited) Great progress there. It looks kind of odd with the stars and bars as negative shapes vs what we're used to seeing. Carl Yes, you have to re-wire your brain for it. It was hard at first, but this is the 5th one I have painted using masks and I am getting used to it. The hardest Masks to use are British roundels, figuring out the color order is rough. Edited April 9, 2018 by 1to1scale BloorwestSiR 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 9, 2018 Share Posted April 9, 2018 The hardest Masks to use are British roundels, figuring out the color order is rough. Interesting. I found the stars and bars much harder than the RAF roundels. I think it's because I've done more of them. Either way, nothing beats their look that's for sure. Carl Link to comment Share on other sites More sharing options...
Kagemusha Posted April 9, 2018 Share Posted April 9, 2018 Very nice Corsair, great to see the period pictures. Link to comment Share on other sites More sharing options...
RLWP Posted April 11, 2018 Share Posted April 11, 2018 I have been studying pictures I could find of the Brooklyn Butcher, and have come to the conclusion that the weathering on this squadron's aircraft was very light. Early on, while on the carrier, they looked almost new with no scratches or fading. Later when moved to land, they collected a few scratches and dirt, but still pretty light. On my build, I will be doing very minimal weathering, keeping it in like new, carrier condition. I wonder if carrier based planes got a lot more attention because they got folded and stored under the deck. Sailors don't like mess, so chances are they got cleaned each time they were taken down Richard Gazzas 1 Link to comment Share on other sites More sharing options...
1to1scale Posted April 16, 2018 Author Share Posted April 16, 2018 (edited) I spent a week deliberating and researching this, and it drove me nuts. I researched chipping and scratching on corsairs and found an anomaly with early GSB corsairs in WW2...chips always look either gray or aluminum, not zinc chromate. It was as if the primer underneath was gray or clear, and GSB was painted without Yellow Zinc, but then it seems that post war, the yellow primer came back it seems after the color change or possibly with the F4U-4 model. So I made the decision to primer with silver Stynylrez, and then spray a chipping medium over it. Edited April 16, 2018 by 1to1scale RLWP, BradG, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
BradG Posted April 16, 2018 Share Posted April 16, 2018 I see you having some fun with the weathering. Link to comment Share on other sites More sharing options...
1to1scale Posted April 16, 2018 Author Share Posted April 16, 2018 Painted and masks removed. I have a few touch ups to get to before I start weathering. To,word here is going to be restraint. TorbenD, BloorwestSiR, Trak-Tor and 5 others 8 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 16, 2018 Share Posted April 16, 2018 MOST excellent! The white really makes the rest of the DSB scheme really pop. Link to comment Share on other sites More sharing options...
1to1scale Posted April 16, 2018 Author Share Posted April 16, 2018 The white is a little too white, but after a wash, it will dirty up a bit. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted April 16, 2018 Share Posted April 16, 2018 Very nice! Link to comment Share on other sites More sharing options...
