Vynce804
HK Models 1/32 B17G
Where did you get the decals, and what sizes are the perspex sheets? That is brilliant.
Hi it's the kitsworld sheet Kw 132074
The cover is 800mm square By 250mm deep. With a hardboard base which I painted white.
Cheers
Matt
Matt, do you have any photos of the mounting process?
I love how this looks up on your wall, but I'm not sure I understand exactly how you did it.
What is the "HK wall mount" you mentioned?
Guest Maxim
What a stunning model! Your B-17 would have to be the best and most realistic I've seen to date. Almost makes me want to go out and buy one.
Hi, the kit comes with a wall mount, which is actually a small frame which attaches to the inside of the bomb bay. It. Was designed to work with the model mounted either horizontally or vertically so mounting my kit on an angle required more support. I had uses resin wheels so was able to drill and embed some 5mm nylon threaded rod (. You can get nylon nuts and bolts from amazon and then cut off the bolt head) into the wheels and then use a nylon nut on the opposite side to the base board in a countersunk hole to secure the model. In hindsight I would have used metal landing gear legs and resin wheels and then I think I could have securely mounted the model without the Hk models wall mount which would make things look a bit neater. Sorry no photos as I was so intent on doing it I forgot! Hope the above helps. Matt
Guest Peterpools
Terrific build and some mighty nice weathering
Peter
Guest Maxim
Just imagine, B-17, B-24, and the Lancaster all mounted on the wall together. How impressive would that look!
S
Stop it !!!! Dont give me ideas, my wallet wont handle it.
