CANicoll Posted February 24, 2018 Share Posted February 24, 2018 Hi Jan, Eagerly watching your build as this will be the next Mustang I build, from the Revell kit. Looks amazing and the level of detail you are pulling out of the kit is really awesome - looks great. Can you remind me what paints you are using for the interior green? ThanksChris Jan_G 1 Link to comment Share on other sites More sharing options...
Jan_G Posted February 24, 2018 Author Share Posted February 24, 2018 Having just done that bit, isn't that cockpit assembly clever. Mine slotted itself together beautifully Same here Richard, didn't have any issues so far Eagerly watching your build as this will be the next Mustang I build, from the Revell kit. Looks amazing and the level of detail you are pulling out of the kit is really awesome - looks great. Can you remind me what paints you are using for the interior green? Thanks Chris, really apreciate for the interior green I'm using Mr. Paint MRP-131 Interior green ANA 611 I'm not sure if it's the best match available with original color but I can live with it jan CANicoll 1 Link to comment Share on other sites More sharing options...
Jan_G Posted February 24, 2018 Author Share Posted February 24, 2018 small progress brassin exhausts are really nice and easy replacement Didn't have any problems with gluing cockpittogether and close the fuselage there will be some filler and sanding needed but nothing significant thanks for looking jan Model_Monkey, MikeMaben, Uncarina and 6 others 9 Link to comment Share on other sites More sharing options...
mhorina Posted February 25, 2018 Share Posted February 25, 2018 You are doing a great job,it looks very good. Can you tell me what you used for the battery cable. It looks likre its some stranded material. Thanks. Mike Horina Jan_G 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 25, 2018 Share Posted February 25, 2018 Nice work. Sincerely, Mark Jan_G 1 Link to comment Share on other sites More sharing options...
Wackyracer Posted February 25, 2018 Share Posted February 25, 2018 Excellent work and great photos as well. Jan_G 1 Link to comment Share on other sites More sharing options...
Bomber_County Posted February 25, 2018 Share Posted February 25, 2018 Absolutely stunning Jan, wish I could build at this sort of pace, I'd have only cleaned up the cockpit components by now.......... Jan_G 1 Link to comment Share on other sites More sharing options...
Beaconroot Posted February 25, 2018 Share Posted February 25, 2018 Looking great so far. I do have a question about the markings. What decals sheet has the markings you are going to use? Really like the Hurry Home Honey markings. Jim Root Jan_G 1 Link to comment Share on other sites More sharing options...
Jan_G Posted February 25, 2018 Author Share Posted February 25, 2018 On 2/25/2018 at 4:08 PM, mhorina said: You are doing a great job,it looks very good. Can you tell me what you used for the battery cable. It looks likre its some stranded material. Thanks. thank you Mike. The stuff used is piece of cable braided shield, as far as I remember it's from old iphone power cable On 2/26/2018 at 3:10 AM, Beaconroot said: Looking great so far. I do have a question about the markings. What decals sheet has the markings you are going to use? Really like the Hurry Home Honey markings. Thank you Jim. Regarding the markings, I still didn't decide whether I will use masks for insignias or decals. For the rest I will go with Zoukei Mura extra set SWS04-D01. It's printed by Cartograf so it should be fine. jan Beaconroot, LSP_Kevin, Rick Griewski and 1 other 4 Link to comment Share on other sites More sharing options...
Jan_G Posted February 25, 2018 Author Share Posted February 25, 2018 I have added some PE stuff and started to play with PE wheel wells. When I consider that I want to keep central wheel covers closed, I'm not sure if it's worth the effort. brassin propeller assembled. Better and crisp detail overall Unfotunately even it should be the direct replacement of kit part, spinner diamter is 0,5-1mm smaller than the original part. I'm not expert to say in terms of accuracy which one is correct. I have sanded down front engine cowlings to get good alignment and will rescribe some lost panel lines later. thanks for looking jan CANicoll 1 Link to comment Share on other sites More sharing options...
Beaconroot Posted February 25, 2018 Share Posted February 25, 2018 Thank you Jim. Regarding the markings, I still didn't decide whether I will use masks for insignias or decals. For the rest I will go with Zoukei Mura extra set SWS04-D01. It's printed by Cartograf so it should be fine. jan Thank you Jan Model_Monkey 1 Link to comment Share on other sites More sharing options...
Jan_G Posted March 9, 2018 Author Share Posted March 9, 2018 small update finished wheel wells, the PE stuff makes difference I didn't want to spend more time with detailing it cause it will be mostly hidden by central wheel covers and the wings and fuselage glued together thanks for looking jan CANicoll, Kahunaminor, Out2gtcha and 13 others 16 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 9, 2018 Share Posted March 9, 2018 Wow, the wheel wells turned out excellent looking. The PE parts are noticeably thinner. I do also like the color combo of the NMF and the YZC as well. CANicoll and Jan_G 2 Link to comment Share on other sites More sharing options...
alaninaustria Posted March 10, 2018 Share Posted March 10, 2018 Outstanding! Cheers Alan Jan_G 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 10, 2018 Share Posted March 10, 2018 Those braces are paper thin. Nice improvements. Sincerely, Mark Jan_G 1 Link to comment Share on other sites More sharing options...
