AlexM Posted January 8, 2018 Author Share Posted January 8, 2018 Currently, I use HIPS Extrafil "Natural" from Filamentum. It is polystyrene, and can be glued with normal modelling glue like Revell Contacta. I tried other HIPS materials from other brands. Others are softer, and easier to sand smoth after printing. But those softer filamenst tend to stress crackings with higher objects while cooling down, probably due to shrinkage. With the Filamentum material, I have no real problems with shrinkage so far. The most difficult part for me is to persuade the material to stick on the printing plate. Therefore, I use a special foil (BuildTak). Check out "our" thread about 3d printing . http://forum.largescaleplanes.com/index.php?showtopic=70571 Cheers Alex Link to comment Share on other sites More sharing options...
AlexM Posted January 13, 2018 Author Share Posted January 13, 2018 So, after some coats of Mr. Surfacer and subsequently sanding, the fuselage surface started to look smooth. But then, I somehow managed that the fuselage fell to the ground, and the forwart part in front of the cockpit area broke apart into four pieces I was able to glue the parts back on the fuselage, and puttied the seams. In the meantime, I started to print some parts of the wings. The recess is for the bomb bay. It took some trimming to fit, and I got some warping at the edges, but hopefully this should be easy to handle with putty and sanding. Alex BradG, LSP_Kevin, Trak-Tor and 5 others 8 Link to comment Share on other sites More sharing options...
BiggTim Posted January 13, 2018 Share Posted January 13, 2018 (edited) Damn, that is cool!! You're really making me want that printer even more! If you made molds of the parts, you could sell copies and pay off the printer fast. Edited January 13, 2018 by BiggTim AlexM 1 Link to comment Share on other sites More sharing options...
AlexM Posted January 21, 2018 Author Share Posted January 21, 2018 I just received this book, which should be very helpfull: One mystery about the PZL.37 is the dihedral of the wings, since many original construction plans apparently were destroyed during the war. On many plans including the plan in the book, the wings show a noticable dihedral from the engines outwards. Photos of the real thing are hard to interprete. On other plans including the plan of the paper model, the upper line of the wings is totally straight in the front view. Here is a apparently restored manual showing a straight upper line of the wings in the front fiew, too. In the book I bought, there is a photo of the real aircraft from the front during construction, which also shows a pretty straight upper line of the wings. Therefore, the wings of my model will have a straight horizontal upper contour, but I'm totally aware that this might be wrong. As soon as the wings got a nice smooth surface (Mr. Surfacer, sanding, Mr. Surfacer, sanding, ...), I'll post some pictures. Cheers Alex Alain Gadbois, BradG, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
AlexM Posted January 26, 2018 Author Share Posted January 26, 2018 Allright, the wings are glued to the fuselage. Still much clean-up to do, but it starts to have a distant resemblance to the real thing Cheers Alex Trak-Tor, dora9, LSP_Kevin and 7 others 10 Link to comment Share on other sites More sharing options...
dora9 Posted January 26, 2018 Share Posted January 26, 2018 Wow! It is taking shape nicely! Always loved the lines of the "Los". Keep it coming! AlexM 1 Link to comment Share on other sites More sharing options...
florin13 Posted January 26, 2018 Share Posted January 26, 2018 Is there a chance for serial production? Florin AlexM and krzy65siek 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 26, 2018 Share Posted January 26, 2018 Brilliant! Kev AlexM 1 Link to comment Share on other sites More sharing options...
Artur Posted January 27, 2018 Share Posted January 27, 2018 Fantastic work AlexM 1 Link to comment Share on other sites More sharing options...
Lee White Posted January 27, 2018 Share Posted January 27, 2018 Wow. Being an old-school scratch builder, I feel like the proverbial John Henry watching this build unfold. AlexM 1 Link to comment Share on other sites More sharing options...
AlexM Posted January 28, 2018 Author Share Posted January 28, 2018 Thanks a lot, guys. Damn, that is cool!! You're really making me want that printer even more!If you made molds of the parts, you could sell copies and pay off the printer fast. Is there a chance for serial production? Florin That would be cool, but is rather unlikely. Maybe If I would start to play the lottery, win a huge jackpot, and were no more dependet to my fulltime job. Until then, I find hardly enough time to finish anything In the meantime, I sprayed some more filler on the model, and the ugly seams where the front fuselage broke apart are no more visible. And I printed the vacuform mould for the canopy. It still needs some coats of "future" to make it smoother. chukw, TorbenD, BradG and 6 others 9 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted January 30, 2018 Share Posted January 30, 2018 This is shaping up beautifully! Fantastic techniques and work quality! Alain AlexM 1 Link to comment Share on other sites More sharing options...
Ohm-men Posted February 5, 2018 Share Posted February 5, 2018 Fantastic project! I always liked the elegant lines of the PZL 37. I think it's one of the most beautiful medium bombers ever made. AlexM 1 Link to comment Share on other sites More sharing options...
SCRATCH BUILDER Posted February 9, 2018 Share Posted February 9, 2018 Good work Alex! AlexM 1 Link to comment Share on other sites More sharing options...
AlexM Posted February 18, 2018 Author Share Posted February 18, 2018 Hi there, time for a little update. The nacelles are separate parts, that will later be glued onthe wings. The lower parts got cut-outs for the landing gear. In the meantime, the fuselage was separated into two parts to start interior detailing. The inner surface has recesses where the individual frames now get glued on (I already started at the rear). Cheers Alex Kagemusha, florin13, RBrown and 4 others 7 Link to comment Share on other sites More sharing options...
