blackbetty Posted December 14, 2017 Author Share Posted December 14, 2017 (edited) as seen here. now the fit is better. cut down trumpy flaps to get an idea of placement of these. the -7 (as the AU-1) had the exhaust located further down as the -5, so i will have to grind a recess (black marked) and fill the lower cutouts pretty flimsy at the moment, but i think i can make it work 07 by karl holubar, auf Flickr Edited December 14, 2017 by blackbetty Out2gtcha, BradG, LSP_Paul and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 14, 2017 Share Posted December 14, 2017 Great progress Karl! blackbetty 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 14, 2017 Share Posted December 14, 2017 Looks good so far Karl, it is going to be fun to get the ducting correct, I know you can do it. All the best, Paul Link to comment Share on other sites More sharing options...
blackbetty Posted December 14, 2017 Author Share Posted December 14, 2017 i will see how the ducting of the eyhaust is routed. i have pics of Bordellons plane that show some kind of square tubing around the exhaust pipes. good that its hard to see it i filled the cutouts with superglue and micropearls, then ground the new recesses i have a lot of more doubts about the cheek intakes. i only have one chance with the resin, if i mess up i´m screwed. i tried to vacform the cowl, but its too deep 08 by karl holubar, auf Flickr Out2gtcha, Harold, Shawn M and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 14, 2017 Share Posted December 14, 2017 I had thought about making a 5N conversion but I was going to modify the kit cowl with Milliput or Apoxie Sculpt. Draw an outline of the side scoops on a piece of white plastic. When you have the shape you like cut it out, make a duplicate. Glue the new scoop patterns onto the kit cowl and build up with plastic and putty until you have faired in chin scoops. Create the intake cavities for the new sculpted scoops as the epoxy putty is drying with sculpting tools, toothpicks etc. Paul Harold and blackbetty 2 Link to comment Share on other sites More sharing options...
blackbetty Posted December 14, 2017 Author Share Posted December 14, 2017 (edited) i do want to use the resin cowl as it allread has the bulges on the sides and i only have to create the intakes. i have some good pics, we will see how that works out... Edited December 14, 2017 by blackbetty LSP_Paul and Harold 2 Link to comment Share on other sites More sharing options...
Tailspin Turtle Posted December 15, 2017 Share Posted December 15, 2017 what on earth is a "tri prism retro reflector" ? "For night-fighter gunnery training purposes the F4U-5N had three retro-reflector devices (trihedral prisms): one on the upper surfaces of each wing tip and a third located on the tail cone. The prisms were used in conjunction with a light projector and the gun camera of the pursuing aircraft." Shawn M, blackbetty, KiwiZac and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Maxim Posted December 15, 2017 Share Posted December 15, 2017 Great progress! Looking forward to seeing the build progress. Link to comment Share on other sites More sharing options...
blackbetty Posted December 15, 2017 Author Share Posted December 15, 2017 thanx Shawn for the explanation Link to comment Share on other sites More sharing options...
alaninaustria Posted December 15, 2017 Share Posted December 15, 2017 Great work so far Karl! Which conversion is this? Cheers Alan blackbetty 1 Link to comment Share on other sites More sharing options...
RLWP Posted December 15, 2017 Share Posted December 15, 2017 "For night-fighter gunnery training purposes the F4U-5N had three retro-reflector devices (trihedral prisms): one on the upper surfaces of each wing tip and a third located on the tail cone. The prisms were used in conjunction with a light projector and the gun camera of the pursuing aircraft." That makes sense. Googling for "tri prism retro reflector" brings up lots of stuff about devices that reflect light back in the direction it came from. Thank you Richard Shawn M 1 Link to comment Share on other sites More sharing options...
blackbetty Posted December 15, 2017 Author Share Posted December 15, 2017 (edited) Great work so far Karl! Which conversion is this? Cheers Alan i think the guys name that made the conversion is Olivier Pinsolle i got the kit with the conversion from steve (fightersweep), i think its OOP Edited December 15, 2017 by blackbetty Harold and alaninaustria 2 Link to comment Share on other sites More sharing options...
blackbetty Posted December 19, 2017 Author Share Posted December 19, 2017 (edited) worked on the cowling and the cheek intakes. located them first (not easy) and drilled holes that i made into slits 08a by karl holubar, auf Flickr then i formed the bumps with miliput. used water and various sharp and round objects to get it in the ballpark. after drying over night some sanding and grinding with the dremel took me near the final shape. first coat of a guidecoat here 09 by karl holubar, auf Flickr 10 by karl holubar, auf Flickr still have to work on the shape though Edited December 19, 2017 by blackbetty Dragon, Shawn M, LSP_Paul and 6 others 9 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 19, 2017 Share Posted December 19, 2017 Nice Work Karl, Looks like you're almost there! Keep at it! Paul blackbetty 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted December 19, 2017 Share Posted December 19, 2017 Nicely done. Sincerely, Mark blackbetty 1 Link to comment Share on other sites More sharing options...
