Gazzas Posted December 16, 2017 Share Posted December 16, 2017 Too good! Link to comment Share on other sites More sharing options...
Madmax Posted December 16, 2017 Share Posted December 16, 2017 Nick, this is a most enjoyable build to follow. Not only your scratch-building abilities, but sharing your thought processes, which ring true for many of us when trying to find the "right" answer to a Luftwaffe question. Great stuff! Link to comment Share on other sites More sharing options...
dodgem37 Posted December 16, 2017 Share Posted December 16, 2017 Good stuff. Great weaving. Sincerely, Mark Link to comment Share on other sites More sharing options...
Daniel460 Posted December 17, 2017 Share Posted December 17, 2017 Great work Nick, really like the seat webbing! Is your MG-81z bulkhead going to fit over the MG/FF switching unit? Keep it coming, you are getting close! Dan Link to comment Share on other sites More sharing options...
Cheetah11 Posted December 17, 2017 Author Share Posted December 17, 2017 Hi Everyone, thanks for all the compliments and interest in the build. Jim, You guessed it correctly, I did use Tamiya tape, but there is a small trick to it. Kev and Harvey, I used 2mm styrene rod to make the frame, and strengthened each joint with a small copper pin. The Tamiya tape was taped together with the glued sides towards each other. The 6 long strips were added first and secured with super glue. The shorter strips were then weaved thru. Quite easy till the last two which I used a blade point to nudge thru. Madmax welcome to the forum and thanks for the compliment. Dan, yes it will hopefully fit . I just hope the whole puzzle will go together after all the changes. Thanks for enjoying the build. I am busy with work for the next week, and should then be able to progress a bit more. Nick ClumsyDude, LSP_Kevin and Daniel460 3 Link to comment Share on other sites More sharing options...
Cheetah11 Posted January 12, 2018 Author Share Posted January 12, 2018 Hi Everyone After three weeks of intense work at the office and five days visiting family,(At least i got a Silhouette Cutter for a present. I have a bit of time for modeling again. I see Andy is also doing the G-4 from Pastor John's conversion. He seems to have done in three days the same progress that took me a month to scratch build. Definitely the easier way to go. I am at the point of closing the fuselage, so things should speed up a bit. I did some of the add-on pieces just to do a bit of painting. I could not confirm on the two photos I have of the actual aircraft if the armor panels were fitted. Nine out of ten aircraft of the period I could find had them, so I decided to fit them using 0,25 mm plastic card. I used Tamiya tape to make a template and then transferred it onto the card. Holes were drilled from the back to ensure thin glue seeped into the whole area. The result. Next I have to do the under wing radiators. I will see how to streamline the kit parts. I will use the Revell 1/48 as a reference . Nick Gazzas, MikeMaben, Shawn M and 2 others 5 Link to comment Share on other sites More sharing options...
monthebiff Posted January 12, 2018 Share Posted January 12, 2018 Very nice progress Nick and looking good!, Have you an exact airframe/ colour scheme in mind on this build yet? Regards. Andy Link to comment Share on other sites More sharing options...
Cheetah11 Posted January 13, 2018 Author Share Posted January 13, 2018 Hi Andy Have you an exact airframe/ colour scheme in mind on this build yet? I intend to do C9+AA as flown by Jochim Jabs. Nick Shawn M 1 Link to comment Share on other sites More sharing options...
Cheetah11 Posted January 29, 2018 Author Share Posted January 29, 2018 (edited) Hi Everyone I have been distracted since Dec when I received a Sillouette cutter and have been playing with the software. Hopefully the build will progress a bit faster. Andy and Max asked about the route I am taking on the cockpit. Because of a few extra pieces I decided to fit the side if the cockpit to the side of the fuselage and cut the top decking in half. I also fitted this to the side of each fuselage and painted everything before joining the fuselage together. Dry fitting showed a few parts were interfering and I had to adjust those. Here is the fuselage joined up. The bottom The radar and Vhf radio still needs to be detailed with wires and the radio rack but this is how it will fit Any suggestions and comments welcome Nick Edited January 29, 2018 by Cheetah11 monthebiff, mozart, Gazzas and 3 others 6 Link to comment Share on other sites More sharing options...
mozart Posted January 29, 2018 Share Posted January 29, 2018 It's all looking good Nick, thanks for putting up those pictures. You've obviously given all of the stages of your construction a lot of thought so I'm sure the upper cockpit add-ons will be just fine. I really admire all the scratch building and re-modelling you've done, very impressive! Max monthebiff 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted January 29, 2018 Share Posted January 29, 2018 Looking great! I really like the small details! Man, what a power house of firepower in this bird! Cheers Alan Link to comment Share on other sites More sharing options...
monthebiff Posted January 29, 2018 Share Posted January 29, 2018 Nice work Nick, I like your idea of cutting the top panel in half as it gives a very nice clean join around the fuselage edges with the cuts covered by other parts of the build. Regards. Andy Link to comment Share on other sites More sharing options...
Ohm-men Posted January 30, 2018 Share Posted January 30, 2018 That's really great work! Love the detailed work you did and your painting looks spot on! The armour is also a very nice addition. I see you are going to use the Revell 1/48 scale kit as a guide for the engine's radiator baths. If I recall correctly, I think the whole engine compartment of the Revell kit is a bit undersized. Though I'm not sure if this was also the case for the specific parts you want to use for a guide. Not sure how Eduard did them on their 1/48 "G". mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted January 30, 2018 Share Posted January 30, 2018 I see you are going to use the Revell 1/48 scale kit as a guide for the engine's radiator baths. If I recall correctly, I think the whole engine compartment of the Revell kit is a bit undersized. Though I'm not sure if this was also the case for the specific parts you want to use for a guide. Not sure how Eduard did them on their 1/48 "G". Yes this is true, whilst the Mongram Revell kit was in my opinion the best 1/48th scale offering and a very pleasant kit to build, the engine nacelles were too "slim" hence the Cutting Edge correction set which made a significant difference. Max Link to comment Share on other sites More sharing options...
Cheetah11 Posted February 2, 2018 Author Share Posted February 2, 2018 (edited) Hi Everyone The build is picking up speed again. Just a lot to do as many parts need to be modified. Yesterday I managed to get the under-wing radiators done. The Me 110 G series had slightly larger radiators and they were also streamlined more. I looked at as many photos as I could get on the internet and the modified the kit radiators with plastic card. Some of the photos on the net showed the radiators from an angle not seen in the SS reference. I also used the 1/48 Monogram/Revell kit part as a reference to get a feel for the part. Here is the kit part with plastic card added. After a bit of sanding the final result This is how it will fit onto the wing The other part I was not satisfied with was the roll bar and seat . I scaled the roll bar up from the 1/48 kit, but when complete it did not match exactly with the kit parts. The top part also seems to be two pressed parts welded together, so the only way I could replicate this was to cut and sand it out of solid plastic card. I get the impression the seat is also slightly undersized and tapers too much to the top. This might be just the angle of the photos, so I will still ponder a bit more on this. The old seat with the new card frame for a size comparison. The top part of the roll bar Next will be the radio rack and some small details. Then the dreaded part....... The vacu-form canopy Comment welcome. Nick Edited February 2, 2018 by Cheetah11 Gazzas, Rocat, fab and 2 others 5 Link to comment Share on other sites More sharing options...
