Gazzas Posted April 4, 2018 Share Posted April 4, 2018 I feel your Pain. Except for Zimmerit paste, I've given up on milliput unless I want to make a large, solid shape. Gaz TorbenD 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted April 4, 2018 Share Posted April 4, 2018 Not sure if you have solved the milliput problem yet, but you could super glue a thin, curved (to follow the float shape) 0.010" styrene sheet under the milliput fairing to give them strength. The lip would not be brittle, as it would now be styrene. Hope this helps! TorbenD 1 Link to comment Share on other sites More sharing options...
TorbenD Posted April 4, 2018 Author Share Posted April 4, 2018 I feel your Pain. Except for Zimmerit paste, I've given up on milliput unless I want to make a large, solid shape. Gaz Still gotta love it Gaz - in my case it was user error - green did the job second time around... Not sure if you have solved the milliput problem yet, but you could super glue a thin, curved (to follow the float shape) 0.010" styrene sheet under the milliput fairing to give them strength. The lip would not be brittle, as it would now be styrene. Hope this helps! Thanks Alain, I did consider that as a back up - possibly even using a thin brass sheet instead but in the end I think Milluput alone should hold up. On with these pesky shoes... Unfortunately I didn't take any photos of the first attempt at the shoes or the twist fix. Of the latter the front port leg just required a firm, gentle twist which carefully adjusted the inner brass core without stressing the CA and plastic outer. The Rear port leg require extra persuasion but fortunately the rod at the top was malleable enough to rotate to exactly the right degree. These minor adjustments left the original shoes slightly lifted (and twisted) so after replacing the cling film with small squares of clear sellotape the next task was to squeeze some slivers of green Milliput under these gaps before again giving the all shoes a thin over coat of more of the same. As you can see I carefully drew guidelines in pencil so that when I started carving/filling back the teardrop shape would be correctly aligned - much tricker than I originally thought to achieve. What followed was a long session filing, carving, checking (repeat ad infinitum) in front of as much photographic reference as I could gather. Most of this done with everything in situ on the floats. I had to laugh as almost all the green Milluput was removed as I ended up with far smaller shoes based on the photos but combination of green and white seems to have given enough strength and finesse. When almost there I very carefully removed the legs and even more carefully gave a final finesse concentrating and on the edges with curved scalpel blades and a fine rat tail files. Once reassembled I'm much happier with the result. Hopefully after a coat of primer not much more refining will be needed. Phew! Just got to sort the top of the legs now Torben Leaning_Dog, LSP_Kevin, Trak-Tor and 3 others 6 Link to comment Share on other sites More sharing options...
TorbenD Posted April 4, 2018 Author Share Posted April 4, 2018 (edited) One more post - couldn't resist a quick dry fit check progress so far and to remind myself of the fact I'm building a whole plane not just some sticks on floats! All seems stable so far and the stance looking nice and accurate. Double phew!! Cheers for looking, Torben Edited April 4, 2018 by TorbenD Alain Gadbois, Gazzas, LSP_Kevin and 7 others 10 Link to comment Share on other sites More sharing options...
RLWP Posted April 4, 2018 Share Posted April 4, 2018 Hey, that's becoming quite a looker now! Richard TorbenD 1 Link to comment Share on other sites More sharing options...
Leaning_Dog Posted April 5, 2018 Share Posted April 5, 2018 Hi Torben - Brilliant modelling skills on display right there! Cheers! John. TorbenD 1 Link to comment Share on other sites More sharing options...
Trak-Tor Posted April 5, 2018 Share Posted April 5, 2018 Great effort and result too! Juraj TorbenD 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted April 5, 2018 Share Posted April 5, 2018 Wonderful result. You have earned yourself a double of your favorite brew ! As a side note, your build has complelely convinced me ... No way I will add this one to the stash. In as much as I love racers and Schneider Cup racers especially, the kit is just not fine enough to warrant the expense. I might just as well scratchbuild one ... Can't wait to see the build finished and some paint on it ... Hubert TorbenD 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 5, 2018 Share Posted April 5, 2018 Terrific work, Torben! Kev Link to comment Share on other sites More sharing options...
modelman182 Posted April 8, 2018 Share Posted April 8, 2018 Torben Will you please stop doing so well with this! It's putting me right off getting my own build sorted!! Only joking - she's looking beautiful. The stance is perfect and the surface finish is great (once I can stop "seeing" the polka dots of filler, of course! ). Looking forward to seeing it with some paint on. Kev TorbenD 1 Link to comment Share on other sites More sharing options...
ssculptor Posted April 8, 2018 Share Posted April 8, 2018 "Bondo", automobile body putty, is good for these things, rather than milliput or other type of filler because the resin based putty is much much stronger and a bit more flexible. Problem is the resin based filler is a bear to file. You have to be very careful as it is easy to file away the polystyrene parts next to it. But then you can use a filler like milliput to fill in that part. I would suggest an initial undersize fillet of resin putty (bondo) and then the softer weaker putty over that for the final shaping. Yes it is a lot of work. TorbenD 1 Link to comment Share on other sites More sharing options...
dmthamade Posted April 10, 2018 Share Posted April 10, 2018 Man, that's a huge amount of work you're putting into the build. I get a better idea of the plane with the upper and lower halves together, looks like it's all motor with a minimal amount of plane attached. Don TorbenD 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted April 10, 2018 Share Posted April 10, 2018 (edited) Man, that's a huge amount of work you're putting into the build. I get a better idea of the plane with the upper and lower halves together, looks like it's all motor with a minimal amount of plane attached. Don That's what these Schneider racers were : big engine, minimal frontal area and weight. The epitome of this design concept was the Macchi MC-72 ... But then, it was incredibly efficient, and remained the fastest prop-driven floatplane or flying boat for decades ... Hubert Edited April 10, 2018 by MostlyRacers TorbenD 1 Link to comment Share on other sites More sharing options...
williamj Posted April 10, 2018 Share Posted April 10, 2018 Spectacular "Rebuild" of this kit,so much better looking by a mile ....It will be resplendent when it's all gloss blue. Shawn M and TorbenD 2 Link to comment Share on other sites More sharing options...
Shawn M Posted April 10, 2018 Share Posted April 10, 2018 truly is a rebuild TorbenD and monthebiff 2 Link to comment Share on other sites More sharing options...
