Fancherello
F-14B UPGRADE 1/32 Tomcat
Thanks you very much !
I also have skills ... to fail ! I set the skulls too low on tails tonight and decided to remove them as a spare sheet is already on the way ( due to a failed NAVY decal a few days ago on an engine nacelle....luckily i managed to find them as they are quite rare now )
I'll have to dind another area to work on...walkways, maybe !
Thank you !
So, I decided to turn my skull decals fail into an opportunity to make my own ones and pick the color they had on their return. Zotz decals provides grey skulls, which is correct ( some other brands made them white ) but I am making an aircraft on cruise's return and these tail skull where rather bleached.
27073153_1987822008125522_75245781586296
FAIL !
27073157_1987822068125516_11088449602498
27337191_1988762911364765_56331532120507
27331574_1988762871364769_22377512599644
27337322_1989085807999142_94303624345700
next: walkways !
Fanch
hello
here's the work so far. I had set some adhesive walkaways made by Crossdelta as they were included with the tail stiffeners, the latters being the main intersest of the set. They were not that bad, but still couldnt match the effect of home made walways using some surfacer. On such a visible area, it would have be a big mistake not to spend a bit more time on these.
27541106_1989905641250492_16217863876478
27336976_1989905704583819_74595298179684
I took a bit of time to make the fiber glass ECM bluges and used a fine mesh as a template to simulate their texture on weathered areas.
27459297_1989976637910059_53899929436166
27544940_1989976554576734_22477582618638
27072818_1989976607910062_85560151600101
and then gloss, oil wash ( Mars Black, Sennelier fine oil paints ) and flat varnish. I decided to set the flat coat at this moment to be sure that the weathering wouldn't loose too much contrast or need some adjustments. Good news, the AK Ultra flat i've been using for the first time has been very good. Perfectly clear, no whitenig. Excellent product.
27545025_1992047204369669_79602347982218
27545294_1992047254369664_83531232414038
I can now move onto engine nacelles weathering, and fine work ( streaks, leaks, scratches, etc )
best regards
Fanch
