Iain Posted March 11, 2018 Author Share Posted March 11, 2018 Yup - just a plain rubber seal/edge on the pot - it just sits on top. Acrylic sheet is 15mm thick. Forms a strong vacuum - down to -0.95 bar is as far as I've had it. You can safely lift the perspex lid - and the pot + any contents underneath. Advantage is a very quick on/off (with valves open to atmosphere) - and easy to see what's going on. I normally have to go down in pressure in stages - otherwise the cup would just 'froth over' with liquid rubber. My pressure pot is nothing like as friendly Iain Tony C, Harold and Phartycr0c 3 Link to comment Share on other sites More sharing options...
Iain Posted March 18, 2018 Author Share Posted March 18, 2018 Juggling projects this afternoon - but a few update images on the Spit. Some more internal detail - plus seat straps and rear instrument panel to do - but test fit this afternoon. Note the new metalwork on upper rear cockpit frames - to go with the new seat strap routing on the two-seater - made from etched brass spares, brass rod and stainless hyperdermic syringe tubing. Engine and frame all dry fitted - a lot more detail in progress... Iain TorbenD, williamj, Greg W and 7 others 10 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 18, 2018 Share Posted March 18, 2018 Starting to really look like a Spitfire now Iain. Carl Link to comment Share on other sites More sharing options...
alaninaustria Posted March 18, 2018 Share Posted March 18, 2018 Nice Iain!! Such a great project and you're doing a superb job! Cheers Alan Link to comment Share on other sites More sharing options...
Iain Posted March 18, 2018 Author Share Posted March 18, 2018 Meant to post this one too - canopy castings done so will be cutting up and splicing over next few days... Note - the interior grey-green looks very odd here - I had to up the contrast/colour saturation quite a bit so you could see the resin castings! Have fun! Iain Bruce_Crosby, Greg W, Starfighter and 4 others 7 Link to comment Share on other sites More sharing options...
tomprobert Posted March 18, 2018 Share Posted March 18, 2018 Loving this, Iain! I was speaking to Kevin Nunn of Brigade Models at Southern Expo today and he's currently working on a 1/32nd two-seat conversion to make the Revell MkIX a TR9. It'll be a drop-in double cockpit with a few other bits and bobs. He's doing the blown cockpit glazing as seen on the Irish machines as well as a full decal set with both Irish Air Corps and a modern day "warbird" twin seater as options. Too late for you, but thought others might be interested. Tom MikeC and Iain 2 Link to comment Share on other sites More sharing options...
williamj Posted March 18, 2018 Share Posted March 18, 2018 This is definitely cool...great project. Iain 1 Link to comment Share on other sites More sharing options...
Iain Posted March 18, 2018 Author Share Posted March 18, 2018 Loving this, Iain! I was speaking to Kevin Nunn of Brigade Models at Southern Expo today and he's currently working on a 1/32nd two-seat conversion to make the Revell MkIX a TR9. It'll be a drop-in double cockpit with a few other bits and bobs. He's doing the blown cockpit glazing as seen on the Irish machines as well as a full decal set with both Irish Air Corps and a modern day "warbird" twin seater as options. Too late for you, but thought others might be interested. Tom Hi Tom, Wasn't aware they were working on a conversion - but I'd probably have gone the route I have anyway... They're going to have to do a new fuselage to do it properly IMHO? I should be able to provide canopy mouldings to anyone that wants to do a Grace type airframe (there are a few now) based on this new conversion. Iain MikeC and Greg W 2 Link to comment Share on other sites More sharing options...
Mark M Posted March 18, 2018 Share Posted March 18, 2018 just caught up mate, shes looking great Iain 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 18, 2018 Share Posted March 18, 2018 :popcorn: :popcorn: :popcorn: Link to comment Share on other sites More sharing options...
Iain Posted April 29, 2018 Author Share Posted April 29, 2018 With apologies to my ace client for the delay - a little update on where I'm at - a lot of background work, and third time lucky on patterns... We left the story with the casting of copies of the Tamiya canopy parts - the plan being to produce extended versions of the kit parts as masters for vaccing new components in clear PETG on my vac-forming machine. It's taken three goes so far to get it right - but now have something I'm happy to share. Note the cut outs at the rear of the frames - to clear the aerial post on standard marks - these will need filling... Castings were cut in appropriate places, surfaces dressed off on wet and dry paper - on a flat surface, with that classic 'circular motion'. Resulting components 'tack-welded' with cyanoacrylate glue - followed by a 'filler' of freshly mixed resin. 'Tunnel' section still needs a little resin 'filler' to make good. Next job on these is to bond the sliding component to the tunnel and fair together as per the original. I need to be in the right frame of mind to do that! The 'tunnel' section *is* too long here - but I'll trim back the resulting clear vacced part. Now - on the full size airframe - the rear canopy is 4 inches longer than the front, but based upon the same patterns. By my calculations that's 3.175mm in 1:32 - close enough for Government work? Hope that's been of interest - off to finish the cockpit (hopefully today)... Have fun! Iain KiwiZac, airscale, LSP_Kevin and 6 others 9 Link to comment Share on other sites More sharing options...
airscale Posted April 29, 2018 Share Posted April 29, 2018 man that looks good Iain - I can't help shuddering every time I see a canopy being vac-formed - you make it look so easy Peter Link to comment Share on other sites More sharing options...
Kagemusha Posted April 29, 2018 Share Posted April 29, 2018 Very impressive, and not a sign of Jack Frost... Link to comment Share on other sites More sharing options...
Iain Posted April 29, 2018 Author Share Posted April 29, 2018 Thank goodness! I'm going to try and avoid repeating that one! Iain Link to comment Share on other sites More sharing options...
Starfighter Posted May 16, 2018 Share Posted May 16, 2018 Excellent job, Iain! Link to comment Share on other sites More sharing options...
