dennismcc Posted November 5, 2018 Share Posted November 5, 2018 Looks grand to me Cheers Dennis Link to comment Share on other sites More sharing options...
Madmax Posted November 5, 2018 Share Posted November 5, 2018 It is just as satisfying for the viewer to see you finally achieve perfection. Cheers! Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 5, 2018 Share Posted November 5, 2018 30 minutes ago, Madmax said: It is just as satisfying for the viewer to see you finally achieve perfection. X2!!!! Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted November 6, 2018 Share Posted November 6, 2018 Vey impressive. Magnifique... Link to comment Share on other sites More sharing options...
TorbenD Posted November 6, 2018 Share Posted November 6, 2018 Bob on Iain Torben Link to comment Share on other sites More sharing options...
mozart Posted November 7, 2018 Share Posted November 7, 2018 I reckon that looks absolutely brilliant Iain, I admire your tenacity in producing such a flawless work of art. Link to comment Share on other sites More sharing options...
Iain Posted November 7, 2018 Author Share Posted November 7, 2018 Thanks guys - support really appreciated! Since last post things have moved on a little. Ignition leads on the Merlin are all done and I'm now working on the cowling frames. Windshield is bonded in place and ready to mask - so we *may* get primer on at the weekend - I suspect that will throw up some areas for rectification - most likely around the canopy rails. Photos at the weekend. Iain KiwiZac, Trak-Tor and dennismcc 3 Link to comment Share on other sites More sharing options...
Iain Posted November 12, 2018 Author Share Posted November 12, 2018 Primer on - and progress made... Initial rub-down with 2000 grit wet and dry - so looking a bit dusty! Overall though - a few areas were I need to re-scribe - but the 'cut and shut' on the fuselage isn't obvious at all. Decided to add the tunnel glazing after the paint. Ignition leads added - lower leads already attached to the tubular conduit (stainless steel tubing) - upper leads need a conduit making and then cutting back. Also started on the cowl framing - here loosely placed in position: The material used for ignition wires is a fine beading wire I found in a craft shop. Multi-stranded it looks good when used for plug wires - but comes sheathed in a clear plastic outer... Whatever I tried I couldn't remove the plastic coating - until I had a eureka moment and cut 24 over-length leads for the Merlin. Holding the end of one lead at a time in a pair of tweezers, I set light to the other end with a match - the plastic burning back along it's length like a fuse leaving just the core strands of metal, suitably distressed! Nice when a 'plan' comes together! Iain LSP_Kevin, Uncarina, Starfighter and 10 others 13 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 12, 2018 Share Posted November 12, 2018 Nice work Iain! Im betting its going to be a gooooooood feeling to get this one completed and off the bench; for many reasons. The finish is in sight! Iain 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted November 12, 2018 Share Posted November 12, 2018 Ian, that looks awesome! I am loving this build, keep up the great work, the finish line is getting close Iain 1 Link to comment Share on other sites More sharing options...
monthebiff Posted November 13, 2018 Share Posted November 13, 2018 Looks really nice Iain. Keep up the good work as nearly there! Regards.Andy Iain 1 Link to comment Share on other sites More sharing options...
dennismcc Posted November 13, 2018 Share Posted November 13, 2018 16 hours ago, Iain (32SIG) said: The material used for ignition wires is a fine beading wire I found in a craft shop. Multi-stranded it looks good when used for plug wires - but comes sheathed in a clear plastic outer... Whatever I tried I couldn't remove the plastic coating - until I had a eureka moment and cut 24 over-length leads for the Merlin. Holding the end of one lead at a time in a pair of tweezers, I set light to the other end with a match - the plastic burning back along it's length like a fuse leaving just the core strands of metal, suitably distressed! Nice when a 'plan' comes together! Iain Likes it Cheers Dennis Iain 1 Link to comment Share on other sites More sharing options...
Bobsyouruncle Posted November 14, 2018 Share Posted November 14, 2018 Amazing work. Just found this. Love what you've done here. Iain 1 Link to comment Share on other sites More sharing options...
KiwiZac Posted November 16, 2018 Share Posted November 16, 2018 Excellent stuff Iain! It's great to see the wiring going in. And I'm glad you pointed out the odd finish was thanks to sanding, I was dreading that it would be panel shading. I'd hate to see such an amazing build ruined like that! Iain 1 Link to comment Share on other sites More sharing options...
Iain Posted November 16, 2018 Author Share Posted November 16, 2018 6 hours ago, KiwiZac said: And I'm glad you pointed out the odd finish was thanks to sanding, I was dreading that it would be panel shading. I'd hate to see such an amazing build ruined like that! Nah, not my style Zac! Thanks for looking in everyone - should be some more progress over the weekend. Iain KiwiZac 1 Link to comment Share on other sites More sharing options...
