mozart Posted September 16, 2017 Share Posted September 16, 2017 In the absence of a 1/32nd scale Harvard I I decided to convert Monogram's 1/48th offering using MDC's resin bits and pieces: I'm going to finish it as one that Dad flew in 1943 in S Rhodesia, in fact I thought it could have been him leaning against the forward edge of P5976 but an enquiry to the IWM told me that this picture was taken in 1941, before he went out there. MikeC and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
mozart Posted September 16, 2017 Author Share Posted September 16, 2017 (edited) The main difference between the Mk I and subsequent Mks is the fuselage construction which was steel tube covered by fabric, replaced subsequently by a light alloy covering in the Mk IIs onwards. The Mk Is had a vicious tendency to spin/stall, in fact the first one to sent to the UK (N7000) for evaluation in 1938 did exactly that, killing both occupants: Other differences include rounded wing tips, a straight wing trailing edge from tip to tip and a larger curved rudder. The plan drawings in AirBritain's Harvard file don't show the correct wing trailing edge shape: but to achieve it on this model requires quite a bit of surgery! This picture shows the straight trailing edges very clearly: Edited September 16, 2017 by mozart MikeC 1 Link to comment Share on other sites More sharing options...
mozart Posted September 16, 2017 Author Share Posted September 16, 2017 (edited) So, wingtips removed and replacement MDC ones glued on. The MDC instructions say "align the new tip with the leading edge of the wing. The tip will be approximately 1mm short at the trailing edge: this is correct. The outer wing panel trailing edge needs to be filed back in a straight line from the raised ridge just outboard of the wheel wells to the new tip." I don't understand this; to my mind it exaggerates what is already wrong in the Mk II wing in trying to represent a Mk I, not to mention shaving off quite a bit of the aileron: My solution was to cut out a narrow triangular fillet from the leading edge to the aft on the outer wing section, to cut the new wing tip in two and insert a piece of plastic card to fill the gap. The starboard side complete below (except for the plastic card insert) showing the difference with the port: Note the difference in angle of both trailing and leading edges. I understand it was this acute angle on the leading edge of the Mk I that caused the spin problems, slats were fitted on some. Edited September 16, 2017 by mozart Gazzas, LSP_Kevin and TorbenD 3 Link to comment Share on other sites More sharing options...
mozart Posted September 17, 2017 Author Share Posted September 17, 2017 (edited) The cockpit assembly was straightforward though it was a very tight fit in the resin fuselage and took a lot of fiddling and fettling: I know the IPs are wrong for the Mk I Harvard but since they can hardly be seen, especially the front one which is the most wrong, I wasn't too bothered! Edited September 17, 2017 by mozart LSP_Kevin 1 Link to comment Share on other sites More sharing options...
brahman104 Posted September 17, 2017 Share Posted September 17, 2017 Nice! I like your creative surgery Should look great all said and done. Craig mozart 1 Link to comment Share on other sites More sharing options...
Gerhard Posted September 17, 2017 Share Posted September 17, 2017 Make it into this. I dare you!! mozart and Gazzas 2 Link to comment Share on other sites More sharing options...
mozart Posted September 17, 2017 Author Share Posted September 17, 2017 That's a Mk II or even later Gerhard......and I'd dare to suggest that my finish is going to be just as tricky! Max Link to comment Share on other sites More sharing options...
mozart Posted September 17, 2017 Author Share Posted September 17, 2017 (edited) Time for more creative surgery Craig When the fuselage was joined up it was too narrow for the space between the wings! And this was meant to be a "5 minute" fun build!! The answer was to cut the whole wing assembly into two halves through the centre section and take out a strip of plastic, re-join and fit the fuselage: so I ended up with this! It's certainly fun.... Edited September 17, 2017 by mozart TorbenD, KUROK, Daniel460 and 3 others 6 Link to comment Share on other sites More sharing options...
Daniel460 Posted September 17, 2017 Share Posted September 17, 2017 Great start Max, I always enjoy your builds! You back your builds with historical facts and documentation. Dan mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted September 22, 2017 Author Share Posted September 22, 2017 Great start Max, I always enjoy your builds! You back your builds with historical facts and documentation. Dan Thanks Dan. The models that I make are solely related to areas of my main aviation interest which is research, specifically Bomber Command in the latter stages of the war so in every case the documentation pre-dates the models. It makes the models more meaningful to me, even dare I say, perhaps whisper, the Bf110G4! Daniel460 1 Link to comment Share on other sites More sharing options...
mozart Posted September 22, 2017 Author Share Posted September 22, 2017 (edited) Moving on, I wasn't very happy with the definition of the panel on the nose behind the engine cowl, shown clearly here: so I cut a template from masking tape then used thin lead foil to make the panels: then add the empennage and prime: Edited September 22, 2017 by mozart Daniel460, Shawn M, Kendzior and 1 other 4 Link to comment Share on other sites More sharing options...
Gazzas Posted September 22, 2017 Share Posted September 22, 2017 Great result on some serious surgery. Gaz mozart 1 Link to comment Share on other sites More sharing options...
Daniel460 Posted September 23, 2017 Share Posted September 23, 2017 (edited) Very nice work correcting that nose fairing! Your about to put the color on the old girl..... I just got a week voluntary lay off.....i'm going to work on my BF-110G conversion...... Dan Edited September 23, 2017 by Daniel460 mozart 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 23, 2017 Share Posted September 23, 2017 Lovey work, Max! Kev mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted September 23, 2017 Author Share Posted September 23, 2017 Great result on some serious surgery. Gaz Thanks Gaz, I love chopping planes up and putting them back together again, hopefully in the right place! The kit wings started off as 3 pieces, in my modified wings there are 12! Very nice work correcting that nose fairing! Your about to put the color on the old girl..... I just got a week voluntary lay off.....i'm going to work on my BF-110G conversion...... Dan Thanks Dan, good luck with your, um.....project! Lovey work, Max! Kev Cheers Kev, I love Harvards, it's so sad that there's no a single surviving Mk I anywhere in the world. Daniel460 1 Link to comment Share on other sites More sharing options...
