Gene
Scratchbuilders 1/32 Staggerwing
On the shelf-of-doom for seven years - it is about time that I pay some attention to it!!
If possible Kevin, the old link is: http://forum.largescaleplanes.com/index.php?showtopic=31208&hl=staggerwing
I've merged your two topics, Gene, so now they both form part of this thread. The old link will no longer work.
Kev
Thanks Kevin for shifting the link, etc!!! And thanks guys for the encouragement.
Pulling out all the parts to inventory where I am and thankfully I had kept many notes and pic refs & found a few more along the way.
So, I'm starting with this:GiWai8.jpg
With my initial post to get this restart going – one wise LSP’er queried if the wingspan was to scale.  I did recall during my previous work that the rib count was short but didn’t recall about the wingspan.  Sure enough, the SCR model measures (in scale) 31’3’’ upper & 31’4†lower – D17 wingspans should both be 32’0â€.  Using the reference drawings in ‘The Staggerwing Story’ by Edward H Phillips (ISBN: 0-911139-27-3 pbk), the need for several adjustments are indicated.  In the SCR wing, each half contains 18 ribs – the actual count should be 25 ribs.  This closer spacing would also help negate the deep sag between ribs that occur on the kit.  Actual aircraft manage to achieve a nearly flat appearance between ribs – thus will be my goal!
Well Thomas, after digging into the problem more there was an explosion of worms!  I decided to sand off all the existing ribs, add Milliput to the trailing edge and wingtip to satisfy the overall dimensions, then add the correct number of ribs in a more subtle detail.  There is also a considerable area of the wing covered with a wood veneer resulting in a very smooth surface.  Now, to work - it will be awhile before the next update. You might need buckets of popcorn william!
