simon417 Posted April 27, 2017 Share Posted April 27, 2017 (edited) Hey everyone, I got this one wrapped last week. I'm pretty happy with the way it turned out. I learned a lot on this build. I use Model Master guns and pitot tube, they are great looking and fairly easy to use (as long as you get everything in straight before the CA sets). It was also my first time using Eagle Cals. I used them with Microsol and Microset, and I'm thinking I did something wrong as they began to eat through the paint, when I was putting the no step dashes down. Needless to say, the decals got trashed so I masked it off and painted them on (they're a bit too thick). The Eagle Cal decals for the cowling went down very well for me, I only need to touch up a few with paint after the fact. i put all decals on after a few coats of Testors Laquer Glossy Clear (worked really well, I was out of the Tamiya X-22). Construction was pretty straight forward but I screwed up the left gear leg, it's angled too far forward. I also missed a few seams at the wing root, I'm still getting the hang of putty and sanding everything smooth. The cockpit was only okay painting wise, so I opted to have the canopy closed. Painting. Well, this was interesting. I used Badger Stynlrenz black primer and it's excellent. Goes on great, smooth and doesn't pull up when it's masked. I tried to use Doog's black basing technique for all but i think it only really turned out well on the bottom. The biggest issue I had was with the Vallejo Model Air colours I used. I used the Model Air RLM's (Upper 75/74, Lower 76) as per the Eagle Cal information but to me they just don't look correct. I'm not an experten by any means but they just look off. Finished up with the testor gloss coat, then used Tamiya's panel liner (worked great). I also used a few Mig pigments (black, earth) but I don't have the hang of them yet, so they are barely noticeable. The other valuable lesson (read mistake) learned was to not partially unmask the canopy and then shoot the flat coat on. The lesson learned was that Testors Lacquer Airbrush cleaner takes off Tamiya Flat Clear with no issues what so ever. Aerials are E-Z line. How do you guys make the various insulators etc on German planes? I've seen blobs of glue but I've seen some that look identical to period pictures. So I'm assuming scratch building them. That's it. I'm interested to hear what you all think of the build. Thanks! Simon Edited April 27, 2017 by smoke417 Shaka HI, Rocat, Shawn M and 21 others 24 Link to comment Share on other sites More sharing options...
109 Posted April 27, 2017 Share Posted April 27, 2017 Beautiful Würger!! Link to comment Share on other sites More sharing options...
Mark M Posted April 27, 2017 Share Posted April 27, 2017 Link to comment Share on other sites More sharing options...
Shaka HI Posted April 27, 2017 Share Posted April 27, 2017 Very nice! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 27, 2017 Share Posted April 27, 2017 Terrific build, Simon! Looks great. Love that chequered cowl. May I publish it on the website? Kev Link to comment Share on other sites More sharing options...
simon417 Posted April 27, 2017 Author Share Posted April 27, 2017 Sure thing Kev. Thanks! Simon LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Joe66 Posted April 27, 2017 Share Posted April 27, 2017 Nice build ! Very "Racey" with the checkerboard nose.....I like it a lot ! Joe Link to comment Share on other sites More sharing options...
Shawn M Posted April 27, 2017 Share Posted April 27, 2017 well done, looks like a great build Link to comment Share on other sites More sharing options...
Jim Barry Posted April 27, 2017 Share Posted April 27, 2017 Love it! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 27, 2017 Share Posted April 27, 2017 Sure thing Kev. Thanks! Simon Thanks, Simon. I just need your full name so I can credit the article properly. Kev Link to comment Share on other sites More sharing options...
alaninaustria Posted April 27, 2017 Share Posted April 27, 2017 Very nice!! Always liked that one!! Cheers Alan Link to comment Share on other sites More sharing options...
simon417 Posted April 27, 2017 Author Share Posted April 27, 2017 It's Simon Turnock. Thanks again. Link to comment Share on other sites More sharing options...
Mikester Posted April 27, 2017 Share Posted April 27, 2017 Simon, Good looking build! Since you requested some feedback: 1. You colors look OK to me, your pictures are just a little dark so it's hard to tell for sure but Vallejo is usually pretty good. 2. Next build watch the flaps, Hasegawa got this wrong on the kit. The flaps fully deployed only extended to 65 degrees but the mounting pegs are molded so that they extend nearly to 90 degrees. You can fix this easily with a little minor surgery. The interior portions should be painted RLM 02 just like the landing gear bay. 3. I just use the white glue method for the insulators and small gague steel springs for the tensioner. Some people use plastic rod and then shape it to a cone for the insulators but I've never been able to get them small enough to where they look right. Link to comment Share on other sites More sharing options...
simon417 Posted April 28, 2017 Author Share Posted April 28, 2017 Thanks for the feedback Mike, it's greatly appreciated (especially the flaps, I had no idea). Simon Mikester 1 Link to comment Share on other sites More sharing options...
mark31 Posted April 28, 2017 Share Posted April 28, 2017 nice work Mark Link to comment Share on other sites More sharing options...
