KUROK Posted March 30, 2017 Share Posted March 30, 2017 (edited) Well, it's time to stop lurking and get to work on my stash. Life gets in the way but maybe posting my build here will help with my "mojo" and keep me motivated. As for true LSP, I have a ZM Mustang and a Tamiya Corsair to do. Also there's a T-6 Texan. However, those have a lot of parts and I need a simpler build to get my juices flowing again. I really should do "out of the box" but.... Nah! This Mauve kit is really nice. The True Details cockpit is sweet in it, I can tell. Edited March 30, 2017 by KUROK Girlscanplay2, mustang1989, Shaka HI and 2 others 5 Link to comment Share on other sites More sharing options...
KUROK Posted March 30, 2017 Author Share Posted March 30, 2017 The first order of business is the Curtiss Electric prop. I am very picky about this. There are some really good resin replacements that have only recently come out. However, the old Monogram P-38 had some very pretty and accurate ones. This is what you are seeing. I have it coated with Mr. Surfacer. I plan to mold in in rubber. Then I can use it on other builds like the really good Airfix P-40B. coogrfan, Girlscanplay2 and Shaka HI 3 Link to comment Share on other sites More sharing options...
Shaka HI Posted March 30, 2017 Share Posted March 30, 2017 Nice. Looking forward to your build as you seen to have a lot of knowledge in this particular aircraft! Link to comment Share on other sites More sharing options...
LSP_K2 Posted March 30, 2017 Share Posted March 30, 2017 Very cool. I'll be looking forward to more. Link to comment Share on other sites More sharing options...
LSP_K2 Posted April 1, 2017 Share Posted April 1, 2017 This Mauve kit is really nice. Yes they are. I got four of them in a trade a few months back. KUROK 1 Link to comment Share on other sites More sharing options...
KUROK Posted April 4, 2017 Author Share Posted April 4, 2017 Thanks guys. I have been fiddling around with that propeller blade. I have a coat of Mr. Surfacer and some coats of Fine Surface Primer. It looks good but up close I can see scratches. I've tried polishing cloths but I think I need to wet sand with extreme fine paper. The good news is I found some Micro Mark casting rubber in my freezer. It's still good! So I plan to mold this blade soon and move on to the cockpit. Link to comment Share on other sites More sharing options...
KUROK Posted April 5, 2017 Author Share Posted April 5, 2017 Those Ultracast blades are good...but I'm a stubborn man. Maybe that is why I don't get a lot of models done. LSP_K2 1 Link to comment Share on other sites More sharing options...
KUROK Posted April 24, 2017 Author Share Posted April 24, 2017 (edited) Hi All, Here's some progress as I steal what spare time I can get to work on this. I have my Curtiss Electric prop ready to mold with rubber for casting. In this photo, I'm experimenting with interior green. The top is Testors Acryl Interior Green and other is Humbrol Bronze Green. I knew I'd like the Humbrol better and this just seals the deal on that: In this photo I'm ready to pour in the rubber. I hope to get away with a one part mold due to the slender nature of the prop blade: Near disaster! The ten year old mold rubber I have kept in the freezer was acting fine when I thawed it a few weeks back. Not is started to kick right when I needed a slow, bubble popping pour. At this point the rubber is full of bubbles and is not settling. So I managed to get the original out. I did try a cast or two in it but the baby powder (talc) I put in has settled at the tip. The good news is that there are not any bubbles around the blade. The bad news is the item is so thin it is not hardening very fast. I may have to put the mold into hot water and try that next... Edited April 24, 2017 by KUROK Shaka HI, coogrfan and Maurice 3 Link to comment Share on other sites More sharing options...
KUROK Posted May 4, 2017 Author Share Posted May 4, 2017 Production of mini Curtiss Electric blades is going well. My one part mold is tricky. I use a thin piece of wire to "plunge" out bubbles before the resin kicks. I have to be careful as if I plunge too aggressively, I can create more bubbles. So far it's about a 50% rejection rate. I have enough for this project as of now. The resin is soft due to a very thin part. However it is stiff enough after about a week or two. Out2gtcha, Gazzas, MikeMaben and 3 others 6 Link to comment Share on other sites More sharing options...
KUROK Posted May 10, 2017 Author Share Posted May 10, 2017 (edited) Slow progress folks but that's okay. Having fun. I got about five good resin cast prop blades before I broke one off in the mold. This was due to a large bubble weakening the blade. I took the best three and have primed them with Krylon Matte Aluminum: Edited May 10, 2017 by KUROK coogrfan, Girlscanplay2, Shaka HI and 1 other 4 Link to comment Share on other sites More sharing options...
KUROK Posted June 27, 2017 Author Share Posted June 27, 2017 Just a little update. More pics coming soon. Tough to get time at the bench! I have mounted the spinner on a brass rod like I do often. The holes were filed to make room for my new cast blades. Here it is just before a coat of Tamiya fine surface primer white. Good thing as Lope's Hope had a white spinner! mywifehatesmodels, Shaka HI, Maurice and 1 other 4 Link to comment Share on other sites More sharing options...
KUROK Posted June 30, 2017 Author Share Posted June 30, 2017 I'd like to share with you a new tool I have from CB Model Products. At first I thought a wheel sanding tool was frivolous but have you ever been frustrated trying to sand a flat spot just right? The tool can handle angled wheel situations like a Bf-109 or Spitfire. Rubber O-rings are provided if you wheel has protrusions and my True Details wheels did. You attach them with white glue. In short order, you get perfectly prepared resin or styrene wheels. Maurice, Kahunaminor and Shaka HI 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 30, 2017 Share Posted June 30, 2017 Interesting tool! I've always had trouble creating usable flat spots on the bottoms of tyres - they usually end up anything but flat, and anything but perpendicular. How much is this device? Looks expensive, I have to say. Kev Shaka HI 1 Link to comment Share on other sites More sharing options...
KUROK Posted June 30, 2017 Author Share Posted June 30, 2017 A google search found this! http://www.largescaleplanes.com/reviews/review.php?rid=351 Shaka HI and Out2gtcha 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 30, 2017 Share Posted June 30, 2017 Ha, now that's funny! No date on that review, but I suspect it's quite old, so the quoted price of US$25 is probably no longer applicable. Still, looks a worthwhile tool for a klutz like me. Kev Shaka HI and Kahunaminor 2 Link to comment Share on other sites More sharing options...
