BiggTim Posted December 13, 2016 Share Posted December 13, 2016 (edited) I am trying to find some 1/32 tires for my P-38 that more closely represent the ones on the actual aircraft I'm building. The two mains appear to be a sort of herringbone pattern, while the nose wheel seems to be diamond tread (I will attach pics when I am able). I am aware of the block tread tires with solid wheels from GMF, and the smooth ribbed ones from Aires, and there was an old diamond set from Jerry, now OOP, and one from Contact Resine, also OOP. If anyone can point me to some other options, or has any of those listed above that they would let go of, please let me know. Tim Pic of the tire: upload image online free Edited February 20, 2017 by BiggTim David66 1 Link to comment Share on other sites More sharing options...
mhorina Posted December 13, 2016 Share Posted December 13, 2016 Tim, Check your PMs Mike Horina Link to comment Share on other sites More sharing options...
BiggTim Posted February 6, 2017 Author Share Posted February 6, 2017 UPDATE: I think I finally found some better images of this type of tire, but all of them were on B-24 Liberators. Since I would be surprised if the P-38 and B-24 used the same diameter wheel, I must assume they made this tire in a variety of sizes. I don't know if I'll be able to replicate a couple of them for my Lightning, or if I'll even try, but I thought it was interesting enough to post. image hosting 5mb image hosting 5mb image hosting 5mb image hosting 5mb image hosting 5mb David66 1 Link to comment Share on other sites More sharing options...
Shawn M Posted February 6, 2017 Share Posted February 6, 2017 look like lower end modern Potenz'a lol Joe66 and BiggTim 2 Link to comment Share on other sites More sharing options...
Lee White Posted February 6, 2017 Share Posted February 6, 2017 I am trying to find some 1/32 tires for my P-38 that more closely represent the ones on the actual aircraft I'm building. The two mains appear to be a sort of herringbone pattern, while the nose wheel seems to be diamond tread (I will attach pics when I am able). I am aware of the block tread tires with solid wheels from GMF, and the smooth ribbed ones from Aires, and there was an old diamond set from Jerry, now OOP, and one from Contact Resine, also OOP. If anyone can point me to some other options, or has any of those listed above that they would let go of, please let me know. Tim Pic of the tire: upload image online free Huh. Pirelli P7's on a Lightning. Shawn M, Mister J, Joe66 and 1 other 4 Link to comment Share on other sites More sharing options...
BiggTim Posted February 6, 2017 Author Share Posted February 6, 2017 They sure do look like car tires. Link to comment Share on other sites More sharing options...
Shawn M Posted February 6, 2017 Share Posted February 6, 2017 thats what they were P7s!!! I knew that I'd seen that tread pattern Lee White, BiggTim and Rick Griewski 3 Link to comment Share on other sites More sharing options...
thierry laurent Posted February 7, 2017 Share Posted February 7, 2017 In the worst case, simply use other tires as they were regularly replaced. If a plane had a service life of at least some dozens of missions, this becomes a certainty. BiggTim 1 Link to comment Share on other sites More sharing options...
Joe66 Posted February 7, 2017 Share Posted February 7, 2017 This guy tried using some of those Low Profile Goodyear Eagle S1's......they didn't handle the rough landing surface so well....... BiggTim, D.B. Andrus, Mister J and 2 others 5 Link to comment Share on other sites More sharing options...
BiggTim Posted February 7, 2017 Author Share Posted February 7, 2017 In the worst case, simply use other tires as they were regularly replaced. If a plane had a service life of at least some dozens of missions, this becomes a certainty. You're right, and I may choose to do exactly that. Since I am trying to model that particular bird at that particular time, I figured it was worth trying to find the right tires, but I may decide not to sweat that detail. Link to comment Share on other sites More sharing options...
BiggTim Posted February 20, 2017 Author Share Posted February 20, 2017 So I took a stab at making one of these tires from a casting of the rubber tire included in the Trumpy kit. It's not bad, but for some reason the pattern makes it look too fat, even though it isn't. In fact, it's slightly narrower than the Trumpy tire, since I flattened the side walls a bit and squared the tread slightly to more closely match the picture I posted earlier. What do you guys think? image hosting 10mb limit image hosting 10mb limit Piprm, Derek B and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
phoenix 54 Posted February 20, 2017 Share Posted February 20, 2017 Afternoon Morning Tim! bloody time zones!!! Tyres look good to me, if I may be so bold? the tyres on the B-24 (to my eye's) look to be over inflated / carrying no weight, so your going to get the 'odd' look, as yours will be perceived to be load bearing. Just a thought........... Paul BiggTim 1 Link to comment Share on other sites More sharing options...
BiggTim Posted February 20, 2017 Author Share Posted February 20, 2017 I was hoping that they would look a bit loaded, though I wasn't able to get a bulge in the tire. However, the one in the period pictures of my P-38 seem taller and thinner to my eye. Link to comment Share on other sites More sharing options...
D.B. Andrus Posted February 20, 2017 Share Posted February 20, 2017 So I took a stab at making one of these tires from a casting of the rubber tire included in the Trumpy kit. It's not bad, but for some reason the pattern makes it look too fat, even though it isn't. In fact, it's slightly narrower than the Trumpy tire, since I flattened the side walls a bit and squared the tread slightly to more closely match the picture I posted earlier. What do you guys think? image hosting 10mb limit image hosting 10mb limit Is there an extra row of treads in the Trump tire? 5 instead of 4, can't quite tell from the photos of the prototype which is correct. Nice job of molding & casting, BTW. Cheers, D.B. BiggTim and DougN 2 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted February 20, 2017 Share Posted February 20, 2017 Profile of actual tire appears to be more rounded in cross-section than flat. HTH, D.B. BiggTim and LSP_K2 2 Link to comment Share on other sites More sharing options...
