Guest Peterpools Posted December 7, 2016 Share Posted December 7, 2016 Peter Super progress on the Matchbox SBD. Still seems like yesterday when the kit first hit the shelves with the multi colored plastic. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
R Palimaka Posted December 7, 2016 Share Posted December 7, 2016 Such fine work on this! Amazing how good these kits can look with some (a lot!) of elbow grease and care. Richard mgbooyv8 1 Link to comment Share on other sites More sharing options...
Cees Broere Posted December 8, 2016 Share Posted December 8, 2016 (edited) Nice job Peter, Goed gedaan. Cees Edited December 8, 2016 by Cees Broere mgbooyv8 1 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted December 8, 2016 Author Share Posted December 8, 2016 (edited) Thanks guys! The engine bulkhead was added. The detail there is will be gone forever as soon as the nose panels are added, so nothing was painted there. The nose panels were temporarily taped in place to ensure that the engine bulkhead was at the right position after the glue had dried. The antenna was cut off from its base and the latter glued in the port nose half. Otherwise, it would never withstand the handling. It's easy to add the antenna later in the build. Another small thjng to add were boxed-in shell ejector openings of the guns in the nose panels. On the parts, they are just represented by raised lines. After the nose panels were glued in place, it was time for the wing outer panels. Fit is sloppy here, so some kind of jig had to be made. According to an internet source (can't remember where), the dihedral angle of a Dauntless outer wing panel is 9 degrees, 16 minutes. This meant that the drawing in the D&S book was correct. The dihedral angle is defined at the chord of the airfoil and not at the outer surfaces. So, measuring the angle at the lower wing surface in the same drawing yielded a value of 11 degrees. A paper template was cut out of a pizza box. One wing panel is supported by the template while the glue is drying. Next, the other wing panel will be added after the glue has dried. Cheers, Peter Edited December 8, 2016 by mgbooyv8 KiwiZac, rafju, BradG and 2 others 5 Link to comment Share on other sites More sharing options...
Shaka HI Posted December 9, 2016 Share Posted December 9, 2016 Nice...and excellent idea! mgbooyv8 1 Link to comment Share on other sites More sharing options...
mozart Posted December 9, 2016 Share Posted December 9, 2016 Super, careful and logical work which is well researched, well done Peter. Max mgbooyv8 and R Palimaka 2 Link to comment Share on other sites More sharing options...
Azgaron Posted December 9, 2016 Share Posted December 9, 2016 Very nice progress! HÃ¥kan mgbooyv8 1 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted December 13, 2016 Author Share Posted December 13, 2016 Thanks guys! I made some progress the past days. Other wing located: Tailplanes added. Fit is OK: And it's starting to look like a Dauntless: The upper nose panel and the engine cowl are just taped in place to check the fit. The forward part of the fuselage needs to be widened a bit with a piece of plastic strip to obtain a good fit: You all probably note that the cockpit floor is already in. It was done by the previous owner. He even closed off the sides with a few strips and inserted a rear bulkhead. So that's nice. It will not be detailed further, The kit items will be used and the crew will hide the big void. However, something needs to be done about this: It is in view and it is simplistic. The part tries to represent an instrument panel wit two gun greeches next to it. And it fails. The corners will be cut off and simple representations of the gun breeches will be made. No, the instruments will not be drilled etc, to keep the nature (and speed! ) of this build by only adding some simple enhancements. That's for the next time. Cheers, Peter mozart, R Palimaka, BradG and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_Ron Posted December 14, 2016 Share Posted December 14, 2016 Looking like a Dauntless! that inst. panel is hilarious. mgbooyv8 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted December 14, 2016 Share Posted December 14, 2016 Are you going to do anything to represent rivets? Looking good! mgbooyv8 1 Link to comment Share on other sites More sharing options...
marauderdriver Posted December 14, 2016 Share Posted December 14, 2016 Super work so far Sir! I got one at a contest raffle and see an A-24 with mine. Keeping a Mark 1 on this one jack mgbooyv8 1 Link to comment Share on other sites More sharing options...
simon64 Posted December 14, 2016 Share Posted December 14, 2016 mgbooyv8 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 15, 2016 Share Posted December 15, 2016 Peter Terrific progress on the Dauntless. Sureliy am enjoying the ride Keep 'em coming Peter Link to comment Share on other sites More sharing options...
mgbooyv8 Posted December 30, 2016 Author Share Posted December 30, 2016 Thanks guys! Shaka, I'm afraid I'm not going to add any rivet detail to this kit. I try to finish this kit relatively quickly and keep it more or less OOB like Matchbox intended with just a few small enhancements. By the way, I admire what you are doing with your Hellcat! The blank sections of the instrument panel were cut off and a few strips of card were added to deepen the panel as seen on pictures: After a lick of paint and some drybrushing, it looked like this: The glass of the instruments is simulated with drops of Klear. In the fuzzy background, you see the other parts which go into the cockpit. The two on the left are scratchbuilt gun breeches, made from a few layers of strip and pieces of rod. Everything has got some paint. For Interior Green I used Humbrol 225, which is too dark, lightened with a little white. Now, the cockpit looks like this: The rear guns and the crew will be added later in the build to fill things up. The forward decking was glued on and taped down. After that, some filling and sanding will be needed. That's for the next time. For now, I wish everybody a very good and happy 2017!!! Peter kkarlsen, R Palimaka, Shaka HI and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 30, 2016 Share Posted December 30, 2016 Fantastic progress. Nothing like the Oldies Happy New Year Peter Link to comment Share on other sites More sharing options...
