mpk Posted September 30, 2016 Share Posted September 30, 2016 (edited) Hi guys. I managed to sand a line out of a radial engine cowling just near the front end. How should I prepare it for re-scribing? I tried a couple of things that went awry so have filled the poor lines with putty to sand smooth later. It is the line under the chin of a Shidenkai George. The top was easily worked on due to my remembering how to approach the mold line. Just use a knife and sand smooth. Bloody fool. Edited September 30, 2016 by mpk Link to comment Share on other sites More sharing options...
Bill_S Posted September 30, 2016 Share Posted September 30, 2016 I keep a roll of very thin Chartpak graphic tape handy. I've seen it is thin as .4mm - generally available at office supply stores. https://www.amazon.com/Graphic-Chart-Matte-Black-CHABG6201M/dp/B001E65NLA/ref=sr_1_6?ie=UTF8&qid=1475203096&sr=8-6&keywords=chartpak+chart+tape mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted September 30, 2016 Author Share Posted September 30, 2016 I keep a roll of very thin Chartpak graphic tape handy. I've seen it is thin as .4mm - generally available at office supply stores. https://www.amazon.com/Graphic-Chart-Matte-Black-CHABG6201M/dp/B001E65NLA/ref=sr_1_6?ie=UTF8&qid=1475203096&sr=8-6&keywords=chartpak+chart+tape Brilliant! Thanks so much. When I go to the Dr later I will call into an office supply shop. I am sending the link to my phone so as to avoid forgetting via chemo brain. You're a legend Bill! Thanks again. Dale Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 30, 2016 Share Posted September 30, 2016 If you have wobbly hands (like I do), you might also try Dymo tape. Cut into thin strips, it will be easier to bend in a lateral direction. It's sticky enough to stay put, and thick enough to act as a straightedge. Bill_S, lawman56, Rick Griewski and 1 other 4 Link to comment Share on other sites More sharing options...
mpk Posted September 30, 2016 Author Share Posted September 30, 2016 If you have wobbly hands (like I do), you might also try Dymo tape. Cut into thin strips, it will be easier to bend in a lateral motion. It's sticky enough to stay put, and thick enough to act as a straightedge. Thank you Sir. I ordered both! Cannot go wrong now. Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted September 30, 2016 Share Posted September 30, 2016 I to use Dymo tape, it works very good. Succes Dale. Greetz Danny Link to comment Share on other sites More sharing options...
ClumsyDude Posted September 30, 2016 Share Posted September 30, 2016 Dymo tape is great stuff. You can cut it with a template (circle, curve etc) using a #11 blade, then apply that to do complex curves. Jim mpk 1 Link to comment Share on other sites More sharing options...
DeanKB Posted September 30, 2016 Share Posted September 30, 2016 Not sure if it's been mentioned, but Dymo tape - or the cheaper generic Chinese rip-offs - is very handy.... Link to comment Share on other sites More sharing options...
Bill_S Posted September 30, 2016 Share Posted September 30, 2016 Admittedly, I use a LOT more Dymo tape than Chartpak. mpk and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Bryan Posted September 30, 2016 Share Posted September 30, 2016 I too use Dymo tape. mpk 1 Link to comment Share on other sites More sharing options...
Shawn M Posted September 30, 2016 Share Posted September 30, 2016 For complex curves I cut thin strips of masking tape to mark then line. Then just slowly and very gently build up the line depth. mpk 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 30, 2016 Share Posted September 30, 2016 (edited) Agreed 110%. Dymo tape (if you can find it as it can be scares in some places) is great. Just like K2 indicated, cut it into 1/2 stripes length wise, to get it to better conform with any complex/compound curves. Also I would recommend when cutting the tape lengthwise, make the cut wavy, so you can make sure you are applying the "straight" edge of the tape, as when you cut them in half like that, there will only be 1 side on each that is actually 100% straight. I've applied it a couple times with the cut side to the panel line and wondered why it wasnt straight in the end. Edited September 30, 2016 by Out2gtcha mpk, LSP_K2, Shawn M and 1 other 4 Link to comment Share on other sites More sharing options...
phantomdriver Posted September 30, 2016 Share Posted September 30, 2016 for anything complex, try the new Tamiya tape, you can pretty well turn it into curves without fear of wrinkling... mpk 1 Link to comment Share on other sites More sharing options...
zak Posted September 30, 2016 Share Posted September 30, 2016 This works for me virtually every time for curves e.g fuselage 1. draw the line you want to scribe in pencil on the model, make this as accurate as possible 2. Place tamiya tape on top of this and ensure there is no creases 3. Remove the tape, the pencil line should now be on the tape and will have a curve to it 4. Put the tamiya tape on top of a length of dymo tape 5. Carefully cut with an xacto or scissors along the pattern on the tamiya tape 6. Put the dymo tape on the model, follow the pencil line you drew earlier 7. I scribe using a pin in a drill vice very lightly at first getting progressively firmer Hope this helps! mpk 1 Link to comment Share on other sites More sharing options...
airscale Posted September 30, 2016 Share Posted September 30, 2016 i use dymo tape (the old stiff stuff) for anything in a straight line over a curved surface but for curved lines I use electrical insulating tape - it's quite thick and flexible - I have no trade names I can give you, but I do have a pic - I just slice it int strips and it will take pretty tight curves no problem, it is also thick enough to use a scriber against.. like this.. HTHPeter LSP_K2 and mpk 2 Link to comment Share on other sites More sharing options...
