Out2gtcha Posted September 9, 2016 Share Posted September 9, 2016 Love it! I cant WAIT till I get to use my Portrait cutter and Oramask 810 on an actual model of my own LSP_K2 and Zero77 2 Link to comment Share on other sites More sharing options...
David Hansen Posted September 9, 2016 Share Posted September 9, 2016 Wow, I am simply amazed. Do the AK metallic finishes HAVE to go onto a primed surface, or can they go directly onto bare plastic if its smooth enough? Apologies in advance if the question has been asked before. Also, the idea of using rub-n-buff for the intake throat is genius. -d- Zero77 1 Link to comment Share on other sites More sharing options...
Guest Posted September 9, 2016 Share Posted September 9, 2016 Buddy, she looks great ! Can't wait for more !......Harv Link to comment Share on other sites More sharing options...
Zero77 Posted September 9, 2016 Author Share Posted September 9, 2016 (edited) Thanks a lot guys ! Wow, I am simply amazed. Do the AK metallic finishes HAVE to go onto a primed surface, or can they go directly onto bare plastic if its smooth enough? Apologies in advance if the question has been asked before. Also, the idea of using rub-n-buff for the intake throat is genius. -d- They can go on bare plastic, and it's even better for the shine if the plastic is perfectly smooth (ie : on plastic spoon, where you can test the paint. On these plastic spoon, the chrome just look like a miror), however, it's better to first coat with primer for paint adhesion. (i know some people had chipping issues when painting AK without priming). And gloss black base also helps for the reflection. For small parts i usually dont prime them, but for a whole aircraft i think it's less risky to spray a coat of primer. I also use Alclad paints, and they are great too, but for hi shine finish i think the AK ones are way stronger than the Alclad polished aluminium or airframe aluminium, though the AK ones are less reflective. For really mirror finishes, Alclads is still at the 1st place, but the model is then so fragile that it's very difficult to handle or place decals. That's why i used the AK paints. Edited September 9, 2016 by Zero77 Link to comment Share on other sites More sharing options...
ClumsyDude Posted September 9, 2016 Share Posted September 9, 2016 That looks really good Nic. Great work on the masking and the NMF. Jim Zero77 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted September 9, 2016 Share Posted September 9, 2016 Nicolas WOW! terrific work and the NMF looks tremendous Keep 'em coming Peter Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 9, 2016 Share Posted September 9, 2016 Excellent work, Nicolas! Count me as one who had adhesion problems with AK's Xtreme Metal without priming: http://www.largescaleplanes.com/reviews/review.php?rid=1510 Kev Zero77 1 Link to comment Share on other sites More sharing options...
Zero77 Posted September 12, 2016 Author Share Posted September 12, 2016 Kev you were the one i was thinking about, as i just re-read your review. I've almost finished the decals. Unfortunately they are not only very soft and hard to place, but they also have a matt finish (a bit like the Revell ones). It's useless, as anyway, on a matt paint modellers usually apply a gloss coat and then a matt coat over all. But on NMF any coat would modify the metallic sheen, so i cannot gloss coat them. Too bad i can live with it (it's not that noticeable at a distance). Regarding the Stars-n-bars, the decal color was not my taste, so i decided to paint them. Here is the difference. The blue on the decal dont match the correct dark blue in my opinion : On the nose, there are small air scoops, but one of them is just under the nice State of Texas emblem, and i thought it would be a problem. So i added a small piece of plastic to make it closed (it is on most pictures anyway... Maybe the other one should be closed, too, but too bad. ). A few pictures with decals on : Starfighter, F`s are my favs, Hubert Boillot and 1 other 4 Link to comment Share on other sites More sharing options...
Zero77 Posted September 12, 2016 Author Share Posted September 12, 2016 I also had problems with the walking area lines. The decals were a PITA to set. So after a day i decided to remove them and paint the line. At the moment i just finished masking it. I used some tamiya tape cut to width to keep a constant and parallel width with my masking. johncrow, Starfighter, Rainer Hoffmann and 2 others 5 Link to comment Share on other sites More sharing options...
jgrease Posted September 12, 2016 Share Posted September 12, 2016 Awesome work on what by many accounts is a tough kit. And your masking/painting is just off the hook! John Zero77 1 Link to comment Share on other sites More sharing options...
Winnie Posted September 12, 2016 Share Posted September 12, 2016 Are you sharing your cut-files? Star-and-bar in particular... I made a cut file for the Hawk-115 MDC, but I have not run it yet through the machine. Your work is flawless, and I could only dream about doing anything that fine! Zero77 1 Link to comment Share on other sites More sharing options...
David Hansen Posted September 14, 2016 Share Posted September 14, 2016 Thanks for the info. I will follow your advice. Brilliant paint work. I just love it!! david Zero77 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 14, 2016 Share Posted September 14, 2016 This is looking so excellent. I regret now not grabbing the kit Saturday, as I saw one for a good price, right as I was leaving the show. Zero77 1 Link to comment Share on other sites More sharing options...
Starfighter Posted September 14, 2016 Share Posted September 14, 2016 Wow, lovely - what a finish! Zero77 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 14, 2016 Share Posted September 14, 2016 Wow, that looks wonderful!! Zero77 1 Link to comment Share on other sites More sharing options...
