TorbenD Posted September 20, 2016 Share Posted September 20, 2016 Lovely bit of sustainable modelling Mr H Link to comment Share on other sites More sharing options...
Azgaron Posted September 21, 2016 Author Share Posted September 21, 2016 Great tip Shawn! I'll see if I can apply it. Thanks Torben! HÃ¥kan Link to comment Share on other sites More sharing options...
Azgaron Posted September 23, 2016 Author Share Posted September 23, 2016 Just a minor update. I'll apply some detail painting and wash too. HÃ¥kan Shaka HI, mikeblack, Sparzanza and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2016 Share Posted September 23, 2016 I'm amazed at the quality of work you've done on this kit. Bravo.....Harv Link to comment Share on other sites More sharing options...
Azgaron Posted September 23, 2016 Author Share Posted September 23, 2016 Thank you Harv! I'm glad you like it! I mounted the engine to the firewall and did a dryfit. More dry fitting. Gonna sort some detail painting and weathering. HÃ¥kan CANicoll, Sparzanza, Shaka HI and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 24, 2016 Share Posted September 24, 2016 This brings back so many memories. I built this kit many, many years ago, and had a lot of fun with it. Link to comment Share on other sites More sharing options...
Azgaron Posted October 2, 2016 Author Share Posted October 2, 2016 I bet it does! I never built it when I was younger, so I'm doing it now! My first try at metal work! Gonna adjust it some, and make 3 more! HÃ¥kan rafju, BradG, Alain Gadbois and 6 others 9 Link to comment Share on other sites More sharing options...
Guest Posted October 2, 2016 Share Posted October 2, 2016 Pretty dam good !.....Harv Link to comment Share on other sites More sharing options...
Azgaron Posted October 2, 2016 Author Share Posted October 2, 2016 Thanks Harv! HÃ¥kan Link to comment Share on other sites More sharing options...
Shawn M Posted October 3, 2016 Share Posted October 3, 2016 looks great! Not a hard part to fab up but the difference is HUGE! Dont forget the door actuator as well. Link to comment Share on other sites More sharing options...
mozart Posted October 3, 2016 Share Posted October 3, 2016 Agreed, the difference is huge! I have a real bee in my bonnet about "scale thickness". I was looking at somebody's Tiger Moth build this morning, it looked pretty good till I saw the shot from the rear into the cockpit. He'd used the Revell windshields which are horrible, probably about 6" thick in scale measurements. I always thin every visible edge unless I use a substitute thinner material, size matters! Max MikeC and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Azgaron Posted October 4, 2016 Author Share Posted October 4, 2016 Thanks Shawn and Max! Yes it sure does a lot! Just checking pics on the actuator, how it's fastened and so on. HÃ¥kan Link to comment Share on other sites More sharing options...
Azgaron Posted October 5, 2016 Author Share Posted October 5, 2016 I did some more metal work. One of the cooler fronts was missing, so I made a new one. Just need to adjust it a bit. I've started with the actuators too. HÃ¥kan mozart, Shawn M, BiggTim and 5 others 8 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 5, 2016 Share Posted October 5, 2016 HÃ¥kan WOW, some mighty nice progress and your newly found metal working skills look perfect. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
mikeblack Posted October 7, 2016 Share Posted October 7, 2016 Coming along nicely, Hakan! Mike Link to comment Share on other sites More sharing options...
