quang Posted June 25, 2016 Author Share Posted June 25, 2016 I don't know how Urszula Bargiel (Mrs Yahu) makes her IPs nor which technology she used but at very close scrutiny, I can tell that each of the 4 colours used on the IP is printed on a separate film then the different films are stuck/laminated together on a metal (steel?) plate. The register is spot-on and gives a subtle 3-D effect. Also note the screw heads (each with a different angle) on the central panel. Just amazing! Looking back at my photo, I just noticed I forgot to make a switch for the ON/OFF panel on the far right! I first used Radu Brinzan's harness on my P-39 build. What I like is the material (a paper made from 100% rag) which behaves like cloth yet has more 'heft' than the microweave cloth used by HGW. More of a headache are the 18 individual brass grommets one is supposed to stick around pre-cut holes. It took me a whole evening but I guess it was worth it! The bear, well not much to comment except that it's much smaller than how it looks in the photo. It would fit inside a green pea Thank you all for your comments, Cheers, Q dennismcc, allthumbs, Zero77 and 3 others 6 Link to comment Share on other sites More sharing options...
Chek Posted June 25, 2016 Share Posted June 25, 2016 I don't know how Urszula Bargiel (Mrs Yahu) makes her IPs nor which technology she used but at very close scrutiny, I can tell that each of the 4 colours used on the IP is printed on a separate film then the different films are stuck/laminated together on a metal (steel?) plate. The register is spot-on and gives a subtle 3-D effect. Also note the screw heads (each with a different angle) on the central panel. Just amazing! Looking back at my photo, I just noticed I forgot to make a switch for the ON/OFF panel on the far right! I first used Radu Brinzan's harness on my P-39 build. What I like is the material (a paper made from 100% rag) which behaves like cloth yet has more 'heft' than the microweave cloth used by HGW. More of a headache are the 18 individual brass grommets one is supposed to stick around pre-cut holes. It took me a whole evening but I guess it was worth it! The bear, well not much to comment except that it's much smaller than how it looks in the photo. It would fit inside a green pea Thank you all for your comments, Cheers, Q Believe me I have tried and am trying using vector graphics to produce similar standard artwork, but even with laser printing at 1200 dpi. it doesn't come out with Yahu clarity. It's passable, but nowhere near that good. I did read somewhere once that HP had hobbled (or been made to hobble) their colour print engine to make life harder for currency counterfeiters, so I don't know how it's done unless 2400 dpi has somehow been unleashed by Yahu on an unsuspecting world and we modellers. Despite the eyeball ache, I think what irritates me about the HGW harness is that only one set of the eyelets is supplied. On a P/E sheet containing 30% blank space how hard would another set be? Fantastic looking panel Quang, although from my own design I'd darken down the U/C panel indicator lights on the top left panel with the tiniest drops of Tamiya clear red and green if no pilot is aboard.. And just remember - the mascot stays safe, and so do you. Or so I understand from those who believe such things. Link to comment Share on other sites More sharing options...
dodgem37 Posted June 25, 2016 Share Posted June 25, 2016 That is a seriously nice I. P. Sincerely, Mark Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 25, 2016 Share Posted June 25, 2016 This is brilliant! And that instrument panel is just jaw-dropping: Kev Zero77 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted June 25, 2016 Share Posted June 25, 2016 Wow, Link to comment Share on other sites More sharing options...
monthebiff Posted June 26, 2016 Share Posted June 26, 2016 Very nice progress Quang, your cockpit looks superb with nice restrained weathering. Regards. Andy Link to comment Share on other sites More sharing options...
quang Posted June 26, 2016 Author Share Posted June 26, 2016 Thank you Andy. I've just been to a friend's place to inspect his SH Tempest but I won't be distracted from my current project. Repeat: I won't be distracted from my current project. Repeat: I won't be distracted from my current project. At least I'm trying hard. Cheers, Quang monthebiff and Uncarina 2 Link to comment Share on other sites More sharing options...
monthebiff Posted June 26, 2016 Share Posted June 26, 2016 I recieved my SH Tempest kit this week and itching to crack on with it, but I have my PCM Hurricane to finish.......nearly there with just a little weathering to do and my HpH Moskito I'm working on while trying not to be distracted!! Regards. Andy Link to comment Share on other sites More sharing options...
zaxos345 Posted June 26, 2016 Share Posted June 26, 2016 Quang, really very nice work so far my friend!! I follow your build cause i am interested in this kit!! And as you mention it....is this SH Tempest so good? Pass any info you can!! Thanks, and...don't be distracted...finish this one first!!!! John Link to comment Share on other sites More sharing options...
LSP_Ray Posted June 27, 2016 Share Posted June 27, 2016 That is crazy-good work on that cockpit, Quang! That Yahu panel is amazing! Going to have to find one. Link to comment Share on other sites More sharing options...
Spaced Marine Posted June 27, 2016 Share Posted June 27, 2016 Again, as others have said, excellent work. You have sold me on getting a Mk.I when it comes out. That is my favorite Hurricane version. Link to comment Share on other sites More sharing options...
alaninaustria Posted June 27, 2016 Share Posted June 27, 2016 Outstanding! I love that Instrument Panel!! Cheers Alan Link to comment Share on other sites More sharing options...
109 Posted June 27, 2016 Share Posted June 27, 2016 Beautiful work, mate! I just bought the Sea Hurricane 😀 Link to comment Share on other sites More sharing options...
quang Posted June 27, 2016 Author Share Posted June 27, 2016 Should I waited I would have bought the Sea Hurricane too. But I was in a hurri Uncarina, 109 and Shoggz 2 1 Link to comment Share on other sites More sharing options...
Lothar Posted June 27, 2016 Share Posted June 27, 2016 I'm watching this with interest, so far everything looks excellent Lothar Link to comment Share on other sites More sharing options...
