F-15E --- 1/32 --- Tamiya
Slowly slowly... So the situation with the DN models` masks - apply, paint, remove, repeat....
...While the Eduard`s PE masks - something way more different....
I cut the needed plate, then i rounded/sanded its edges to avoid scratching the surfaces:
Then the attachment is very tricky, the proper alignment more exactly:
After using 1 plate for the two intakes (6 application in total), the paint really started building up on the pe plate. So some cleaning is mandatory as well. The paint dissolves very easily.
And the same plate is ready for further applications.
Hi F's, Beautiful work on your F-15 and an unbelievable amount of work you're putting into it.
As you've strived so hard to get so much right, I hope it's not too nit-picking to point out that those numbers in front of that intake overflow door are actually the aircraft serial number, for the tanker crews' 'account book'.
For a Lakenheath 492nd FS bird in their adopted style, yours would read 91308.
(Some other units would use the last FY number with the four digit serial)
Edited by Chek
