Shaka HI Posted June 10, 2016 Share Posted June 10, 2016 Geez..finally and update. Some higher res picts please. Link to comment Share on other sites More sharing options...
Azgaron Posted June 10, 2016 Author Share Posted June 10, 2016 Thanks Shaka! I'll see what I can do about the pics. HÃ¥kan Link to comment Share on other sites More sharing options...
Azgaron Posted June 17, 2016 Author Share Posted June 17, 2016 I've been working a bit with the engine and some other stuff. The front of the engine cowl doubles as part of the exhaust system, and needed to be thicker. Some touch up and tested in place. I did some valve springs. 36 of them took a while. Double Browning looked nice, and I nearly started mounting it, until I realised this one, had none. I removed things from the rear and made a new seat. A new backrest and a box was also made. A few more things to do like the belt attachment points, and the belts, then I think it has to be enough. HÃ¥kan BradG, MikeC, shbemo13 and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 17, 2016 Share Posted June 17, 2016 Impressive work, HÃ¥kan! Kev Link to comment Share on other sites More sharing options...
Shaka HI Posted June 18, 2016 Share Posted June 18, 2016 Nice progress! Link to comment Share on other sites More sharing options...
Azgaron Posted June 18, 2016 Author Share Posted June 18, 2016 Thanks Kev and Shaka! HÃ¥kan Link to comment Share on other sites More sharing options...
dmthamade Posted June 18, 2016 Share Posted June 18, 2016 That's amazing work!! How did you do the valve springs? Don Link to comment Share on other sites More sharing options...
Azgaron Posted June 19, 2016 Author Share Posted June 19, 2016 Thanks Don! They're made with thin lead wire on the same size plastic rods that can be seen in the pic. The rod was glued into holes, and then then top was heated with hot screwdriver, to secure the springs. HÃ¥kan Link to comment Share on other sites More sharing options...
dennismcc Posted June 19, 2016 Share Posted June 19, 2016 Impressive, love the engine work, my poor Lysander has been sitting patiently in the stash for years, which is a bit sad for such an amazing subject. Cheers Dennis Link to comment Share on other sites More sharing options...
Azgaron Posted June 19, 2016 Author Share Posted June 19, 2016 Thanks Dennis! HÃ¥kan Link to comment Share on other sites More sharing options...
mikeblack Posted June 19, 2016 Share Posted June 19, 2016 Lovely work, Hakan - I'm very impressed Mike Link to comment Share on other sites More sharing options...
Azgaron Posted June 22, 2016 Author Share Posted June 22, 2016 Thanks Mike! I decided to make a new intake for the cowl. Then on with some interior green on the cowls and the box. I did a dry fit of the interior. Might need some adjustments, but other than that I'm pretty okey with how it looks. So on with some color. Still a few things to do like the seat belts. Not sure what to use yet, but I'll solve that somehow. HÃ¥kan MikeC, Shaka HI, shbemo13 and 1 other 4 Link to comment Share on other sites More sharing options...
monthebiff Posted June 24, 2016 Share Posted June 24, 2016 Really nice progress. Regards. Andy Link to comment Share on other sites More sharing options...
Azgaron Posted June 25, 2016 Author Share Posted June 25, 2016 Thanks Andy! I've done some more. The IP is in place. Still need to sort the belts, but once they're done, I can start assemblying the body. The prop and spinner got some color. As did the tank and the engine. Gonna add some more colors to the engine once it has dried a bit longer. HÃ¥kan MikeC, Shaka HI, BradG and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 25, 2016 Share Posted June 25, 2016 Terrific work, HÃ¥kan! Looks great so far. Kev Link to comment Share on other sites More sharing options...
