TorbenD Posted August 8, 2016 Share Posted August 8, 2016 When I grow up I want to model like this... Inspirational scratching Max, I'm learning lodas... more please Torben Lee White 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 8, 2016 Share Posted August 8, 2016 Those tail planes look super, Max! Kev Link to comment Share on other sites More sharing options...
Hubert Boillot Posted August 9, 2016 Share Posted August 9, 2016 Nice progress Max And congrats on the engagement Hubert Link to comment Share on other sites More sharing options...
mikeblack Posted August 9, 2016 Share Posted August 9, 2016 Great work on those tailplanes, Max - and congrats on your engagement as well Mike Shaka HI 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted August 13, 2016 Share Posted August 13, 2016 Nicely done Max. And congrats to your engagement as well. Troy Link to comment Share on other sites More sharing options...
mozart Posted August 13, 2016 Author Share Posted August 13, 2016 Thank you all, busy times right now so once again modelling time is scarce but tomorrow looks more promising. I'm looking forward to doing the wings using the same technique, the underlying rib structure was very distinctive on the fabric covered wings. Other areas like the aft engine nacelles need more planning and thought to achieve the desired effect. More soon I hope! Max mikeblack, Shaka HI and TorbenD 3 Link to comment Share on other sites More sharing options...
mozart Posted August 16, 2016 Author Share Posted August 16, 2016 (edited) A cancelled golf match (it's too hot anyway!) has given me an unexpected day's modelling . I've been doing some work with the starboard wing, lots of sanding and adding internal ribs for strength etc. It's glued together quite well, I've given it an initial coat of primer to highlight blemishes, areas for filling etc so the next job will be to do the ribbing as shown in the drawings. These are the Warpaint ones by Mike Keep which I scan as required and enlarge to 1/32nd scale: Eagle eyes amongst you may notice that there's a mismatch in the length of aileron between the drawing and my wing. This is because the early Ansons had long-span ailerons as shown in the drawing but later and subsequent ones had short-span ailerons. On with the masking........ Max Edited August 16, 2016 by mozart MikeC, BradG, Shaka HI and 2 others 5 Link to comment Share on other sites More sharing options...
The1971Show Posted August 16, 2016 Share Posted August 16, 2016 That's some very fine work on the tailplanes, I'm looking forward to seeing what you do with the wings here! Darren Link to comment Share on other sites More sharing options...
Azgaron Posted August 16, 2016 Share Posted August 16, 2016 Nice work, Max! HÃ¥kan Link to comment Share on other sites More sharing options...
Shaka HI Posted August 16, 2016 Share Posted August 16, 2016 Keep going Max...deadline's around the corner! Link to comment Share on other sites More sharing options...
mozart Posted August 16, 2016 Author Share Posted August 16, 2016 (edited) Keep going Max...deadline's around the corner! Oh there's absolutely no chance of making the deadline Shaka, not even contemplating it. I hope to take it, in whatever form it is, to IPMS Telford but there's so much to do still including a completely scratch-built undercarriage. Edited August 16, 2016 by mozart Shaka HI 1 Link to comment Share on other sites More sharing options...
tomprobert Posted August 16, 2016 Share Posted August 16, 2016 Oh there's absolutely no chance of making the deadline Shaka, not even contemplating it. I hope to take it, in whatever form it is, to IPMS Telford but there's so much to do still including a completely scratch-built undercarriage. Good to see a little more progress, Max. Small steps and all that... I'd love to see this at Telford - there's nothing like seeing projects like this in the flesh to appreciate the amount of work involved. Tom mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted August 16, 2016 Author Share Posted August 16, 2016 Fingers crossed for Telford Tom. I'd appreciate your advice regarding the fluted/ribbed part of the aft nacelles, the ribs converging to a point. Any thoughts about a good way to replicate this.....I've a few ideas but not sure which to try first! Max Shaka HI, BradG, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted August 16, 2016 Share Posted August 16, 2016 Max Nice progress and a build is always an accumulation of little steps. Very interesting note on the aileron length Keep 'em coming Peter Link to comment Share on other sites More sharing options...
BloorwestSiR Posted August 17, 2016 Share Posted August 17, 2016 Lovely work Max. For the nacelles, maybe use some very fine masking tape to mark out the low points. This way you can overlap them at the aft end. Then spray Mr Surfacer over top and build it up a bit. After you remove the tape, the Mr Surfacer hopefully will replicate the ribs. Aizu tape is available in 0.4mm widths. If you need some, let me know. Carl mozart 1 Link to comment Share on other sites More sharing options...
