DoogsATX Posted April 14, 2016 Author Share Posted April 14, 2016 So close to being able to lock away all the cockpit detail in the fuselage...flat coated last night. Still need to finish off the backrest for the turret seat - that's literally the only thing holding me back from closing up the fuselage at this point. Also went back and addressed the cold air vent at the bottom of the instrument panel. Trumpeter put a weird bump there, so I drilled it out and tossed in a disc of acetate as the valve. Uncarina, Out2gtcha, dutik and 4 others 7 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 14, 2016 Share Posted April 14, 2016 Cockpit and IP look wonderful Link to comment Share on other sites More sharing options...
monthebiff Posted April 14, 2016 Share Posted April 14, 2016 Very, very nice looking cockpit. Regards. Andy Link to comment Share on other sites More sharing options...
ClumsyDude Posted April 14, 2016 Share Posted April 14, 2016 Jeez Matt, that IP looks like the real thing. Cockpit as a whole is looking great too. Jim Link to comment Share on other sites More sharing options...
DoogsATX Posted April 16, 2016 Author Share Posted April 16, 2016 And then the fuselage was closed. Despite the hassle of getting all the side-load elements in the cockpit to align, once I did, everything closed up very well. Even the firewall and the paneling around the accessory area aft of the cowl fit well. Now I have to deal with the wingroot gaps... Martinnfb, tomv87, BiggTim and 1 other 4 Link to comment Share on other sites More sharing options...
theseeker Posted April 16, 2016 Share Posted April 16, 2016 Looking great as usual! Link to comment Share on other sites More sharing options...
scvrobeson Posted April 16, 2016 Share Posted April 16, 2016 Is there any way to spread the fuselage out a little bit at the bottom? That might handle the gap without the need to fill it Matt Link to comment Share on other sites More sharing options...
Guest Posted April 16, 2016 Share Posted April 16, 2016 Coming along really well! Great looking cockpit. Link to comment Share on other sites More sharing options...
Ironwing Posted April 17, 2016 Share Posted April 17, 2016 Matt, As usual, done at a quality level we've all come to expect from you...just lovely. Geoff Link to comment Share on other sites More sharing options...
DoogsATX Posted April 18, 2016 Author Share Posted April 18, 2016 Time to sort the wings! First, I decided to glue the upper wings the fuselage. Both the upper wings and fuselage have some nice vertical slabs to ensure dihedral, and there's an "up and under" tab things to lock the wings in close to the right position. Using these plus a few strips of styrene sanded to the right thinness, I was able to solvent weld the wings where they needed to be and keep the gaps to a minimum. Not perfect, but way, way easier to clean up. Next - the lower wing. I'm glad I thought about the PE flaps before I glued it down, since the whole center flap portion needed to be cut away. Hello JLC saw! This also gave me room to use a piece of sprue to wedge the lower fuselage at the proper angle for welding shut. The rest was a cinch. Starting at the outside and getting the wingtips aligned, the more central portions toward the wingroot fell into place, though the fit on the port side took some, uh, persuasion. I've got some leading edge overbite to clean up, but it's nothing too bad. Uncarina, Martinnfb, dutik and 3 others 6 Link to comment Share on other sites More sharing options...
Youngtiger1 Posted April 18, 2016 Share Posted April 18, 2016 Looking nice. Does this kit provide folding wings option? Since it was USN a/c during WW2 I would think it had to have folding wings. Link to comment Share on other sites More sharing options...
DoogsATX Posted April 18, 2016 Author Share Posted April 18, 2016 Looking nice. Does this kit provide folding wings option? Since it was USN a/c during WW2 I would think it had to have folding wings. It doesn't provide the option, no. I'm not sure that any Dauntless kit does out of the box. Link to comment Share on other sites More sharing options...
Hubert Boillot Posted April 18, 2016 Share Posted April 18, 2016 (edited) IIRC, the SBD was one of the few monoplane naval aircrafts that did not have any folding wing provision (with the Buffalo, the Skyhawk and the Harrier ) Hubert Edited April 18, 2016 by MostlyRacers scvrobeson 1 Link to comment Share on other sites More sharing options...
DoogsATX Posted April 18, 2016 Author Share Posted April 18, 2016 IIRC, the SBD was one of the few monoplane naval aircrafts that did not have any folding wing provision (with the Buffalo, the Skyhawk and the Harrier ) Hubert Yep - how about that - in all these years I've never stopped to think on it, but sure enough, no wingfold. Makes sense - that wing needed to be beefy for the divebombing duties. Link to comment Share on other sites More sharing options...
Youngtiger1 Posted April 19, 2016 Share Posted April 19, 2016 Thanks for the info Matt. I don't have this kit so sure do appreciate it. I had a wild idea to get this kit and put it next to another WW2 USN a/c as a hanger deck dio...all folded up and stored away. Well, there are plenty of other subjects to do such Link to comment Share on other sites More sharing options...
