I'm an organised worker too Shaka (a place for everything and everything in its place) but it doesn't slow me down because I can instantly put my hand on any tool, paint pot, piece of plastic/metal sheet, wire etc etc instead of spending ages rummaging looking for it. Can't stand clutter!! :)
Max
Thanks Max, but I think I'm a bit different in that I get involved in the "collateral" stuff more in an attempt to avoid the real work somehow..not sure how to explain it. It's like doing taxes and gathering all your paper work, filing them, cleaning your desk, cleaning your keyboard (try getting crud off between the keys!) and bunch of other stuff when you should be filing your taxes!
Anyway, I'm curious on how I should correct a part that was twisted in the sprue..it's the rear portion of the prop. After snipping the part of and doing a little sanding, I noticed that there's a slight indentation:
I'm amazed how fast you're progressing on the build and doing such a clean job on it!! I have to ask, is the black strictly a primer or are you using it as a preshade?
Don
You know I'm not sure TBH....someone here posted some pictures of what is a restored Spitfire and I thought: "Well, that looks really nice". Until I discovered it's an actual Spitfire. So I thought I do something to add some "dimension". Not exactly, "weathering" like how I see some folks here do (and I am completely awed by their execution), but I feel it needs something? When I get confused with a real Spitfire for a model, I'll definitely need to do something to make a model look more real.
I added some nicks/chips/highlights to the IP with a graphite pencil...not sure if it looks OK, but whatever...I'm experimenting a little.
I sometimes do a dark base coat in my cockpits, usually German aircraft which have an RLM66 finish and then spray the top coat from above at a constant angle. This creates a "shadow" which gives depth to the cockpit.
Max
Edited by mozart
[..Pict Link Removed..]
Max
I like that..I might have to "borrow" that idea!
Edited by Shaka HI
More color coats...waiting for it to dry for detail brush painting. Experimenting with the exhaust a bit....
No plans to add paint the "NMF" stuff in the interior, but looks like it's fairly visible. LHS did not have AS12, so I used what ever "Aluminum" paint I had which kinda sucks, but it's barely visible...
I think I spent more time cleaning the AB after the silver compared to masking/painting this "colour".
Edited by Shaka HI
Neat progress Shaka.
Major Engine components assembled/painted...this is a lot of fun, I hope I don't lose any steam...I'll need to somehow add some dept/interest to all that black!
Black can be a challenge to bring depth to. Many modellers choose a dark grey as a base and work back up to black. Because scale can help with the illusion, dark grey can still look like black.
If you were to airbrush a very dark grey over the black but spray it from the top down it would automatically create natural shading. The top of the rocker covers would be pretty much dark grey but the undercuts would remain black and accentute the shadow effect. Use a thin wash of black all over to re-instate the detail then a final subtle dry-brush of very dark grey to make the highlights "pop". Some guys even dry-brush with a light grey or white which really gives an artistic, high contrast effect. A bit of experimentation should give you a chance to see what you prefer.
HTH
Cheers.
HTH
Cheers.
All very sound advice!
Max
HTH
Cheers.
Tried to mist a thin dark grey which definitely looks better (top-down)  -- scale-wise. I should follow up with some black washes and dry brushing to get some detail out. It does look better, just harder to convey through photography...Thanks for the ideas (even if my execution is lacking).
Edited by Shaka HI
